Skycatcher IFR?
Old October 13th 07, 12:30 AM posted to rec.aviation.owning
Matt Whiting
Default Skycatcher IFR?
Does anyone know if the Skycatcher will be IFR certified? It doesn't
appear to be from what little I've found at the Cessna web site.
Matt
Old October 13th 07, 12:36 AM posted to rec.aviation.owning
Vaughn Simon
"Matt Whiting" wrote in message
Does anyone know if the Skycatcher will be IFR certified? It doesn't appear
If not, that would certainly limit its usefulness as a trainer. What is
involved is getting a new airframe IFR certified?
Vaughn
Old October 13th 07, 07:02 PM posted to rec.aviation.owning
Dave S
Not with regards to training sport pilots.
Old October 13th 07, 08:39 PM posted to rec.aviation.owning
Vaughn Simon
"Dave S" wrote in message
(One is tempted to say "no ****", but that would not be polite.) To
earn its keep at a flight school/FBO, any trainer needs to be capable of more
than teaching sport pilots.
Vaughn
Old October 14th 07, 04:06 PM posted to rec.aviation.owning
Dave S
Vaughn
Since we are being polite, I will politely point out that most private
pilot proficiency and training items can be accomplished in a light
sport aircraft that is equipped only to LSA requirements.
Exceptions being instrument flight training and night training.
Dave
Old October 13th 07, 01:45 AM posted to rec.aviation.owning
Robert M. Gary
Matt
Will Sport aircraft be allowed to be IFR certified?
-Robert
Old October 15th 07, 02:24 PM posted to rec.aviation.owning
Gig 601XL Builder
Matt
-Robert
There is at least one S-LSA aircraft that is IFR certified.
http://www.newplane.com/amd/amd/601_SLSA/601.html
Old October 15th 07, 06:04 PM posted to rec.aviation.owning
Robert M. Gary
On Oct 15, 6:24 am, "Gig 601XL Builder" wrDOTgiaconaATsuddenlink.net
Matt
-Robert
There is at least one S-LSA aircraft that is IFR certified.http://www.newplane.com/amd/amd/601_SLSA/601.html
So then I assume the pilot would need a current class 3 medical,
correct?
-Robert
Old October 15th 07, 06:27 PM posted to rec.aviation.owning
Matt
-Robert
correct?
Correct, but only when performing those tasks that require use of a Recreational
or higher license. A Sport Pilot can climb into the airplane and fly day VFR,
but if he's going to go on the gauges he needs the appropriate license and
rating (and medical to go with the license).
The FAA made a big terminology mistake with the new rules; they use the same
term for a *definition* as for an aircraft certification category. Any aircraft
meeting the 14 CFR Part 1 definition for "Light Sport Aircraft" can be flown by
a pilot exercising Sport Pilot privileges, whether it's a Private pilot with an
expired medical, or a person with the new Sport Pilot rating. This definition
is summarized at:
http://www.bowersflybaby.com/tech/sportpilot.jpg
However, the FAA also added "Light Sport Aircraft" as a certification category,
both as "Special" and "Experimental." These are aircraft that comply with the
ASTM standards. There's nothing that I know of that precludes aircraft in these
two categories from flying IFR if properly equipped AND with a pilot with
appropriate ratings at the controls. The ASTM standard has a required minimum
for instruments and equipment (which, in fact, requires less instruments than
Part 91 for day VFR) but does not define a maximum.
Old October 15th 07, 07:22 PM posted to rec.aviation.owning
Robert M. Gary
correct?
In this case the task of flying IFR requires at least a private rating
so a class 3 medical seems to be required.
is summarized at:
I understand that. In fact that was my point. A LSA can be IFR
certified but in order to fly it a pilot now must have a medical. So
the idea of letting your medical lapse when you get old and buying an
LSA only works for VFR. For IFR you have to exercise the priv of an
instrument rated private pilot and not the priv of a sport pilot.
-Robert
Cessna's new LSA: "Skycatcher" Jim Logajan Piloting 107 September 23rd 07 01:18 AM
Cessna's new LSA: "Skycatcher" Jim Logajan Owning 110 September 23rd 07 01:18 AM
Cessna's new LSA: "Skycatcher" miffich Piloting 1 July 24th 07 12:04 AM
