Well IGC are letting in the ASW20 and Discus into Club
Class next year, (and increasing the handicap on the Std. Cirrus at long last!). Which one should I buy - which is likely to be more competetive? or is there an alternative? I would like higher performance for non-competetive distance flying. |
Nick Olson wrote:
Well IGC are letting in the ASW20 and Discus into Club Class next year, (and increasing the handicap on the Std. Cirrus at long last!). Which one should I buy - which is likely to be more competetive? or is there an alternative? I would like higher performance for non-competetive distance flying. Some random thoughts fromsomebody who has flown both Discus and ASW-20: - I find the ASW-20/ASW-19/Pegase cockpit more comfortable for longer flights. The Discus is OK, but after three hours I start to notice that the lower part of the console is slightly too wide, the pedals are slightly too close together and that they lock your my feet very upright. As a result my knees give me hell for a few minutes after landing, but ymmv - the Discus is much easier to fly than an ASW-20. I soloed in an ASK-21, then Junior, Pegase, Discus in that order. I had about 77 hours solo when I converted to the club's Discus and had no problems at all. By contrast I had 226 hours solo when I converted to the ASW-20 and would not have wanted to convert to it any earlier. - ASW-20s are more spin prone than a Discus. - Converting to an ASW-20 after learning on unflapped gliders is like learning to drive on an automatic and then switching to a manual shift: using the flaps is easy enough but always being in the right flap for what you're doing takes time and practice to master - in my case around 40 hours before it became automatic. HTH -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
On Thu, 18 Oct 2007 20:47:22 +0100, Martin Gregorie
wrote: - Converting to an ASW-20 after learning on unflapped gliders is like learning to drive on an automatic and then switching to a manual shift: using the flaps is easy enough but always being in the right flap for what you're doing takes time and practice to master - in my case around 40 hours before it became automatic. .... these 40 hours are really about the time that you need to become familiar with an ASW-20, its incredible flexible wings and the very "soft" feeling. But then one is going to fall in love with the 20. From all the gliders I've flown (including nearly all of the 15m gliders) the 20 has *by far* the best handling characteristics. Bye Andreas |
On Oct 19, 2:47 am, Andreas Maurer wrote:
snip. But then one is going to fall in love with the 20. From all the gliders I've flown (including nearly all of the 15m gliders) the 20 has *by far* the best handling characteristics. Bye Andreas /snip And rather get a "BL" if you can, you will not be sorry! |
On Fri, 19 Oct 2007 04:03:20 -0700, wrote: And rather get a "BL" if you can, you will not be sorry! Nah - the 20 only becomes really sexy when its landing flap setting of 55 degrees is not castrated... really steep landings are half of the fun in the 20. ![]() Agreed. The only other glider I've flown that can match it for steep approaches is a Puchacz. -- martin@ | Martin Gregorie gregorie. | Essex, UK org | |
If the Discus is to be included then as far as I can
see there is nothing in the FAI rules to preclude a Turbo Discus taking part in Club Class competitions or from self retrieving. Is that correct? In a no-water-ballast class the weight of the engine would be an advantage. With both gliders dry my previous Discus BT easily climbed and cruised in the mid range with my friend's ASW 20 - so, if they could, I guess that serious club class pilots would opt for the handicap advantage and self retrieve capability of the Discus BT. John Galloway |
US Win on Day 1 at Club Class WGC | Susan | Soaring | 2 | July 16th 06 06:53 PM |
SPORTS CLASS/CLUB CLASS | 5 ugly | Soaring | 0 | July 2nd 06 11:14 PM |
Does USA need a Club Class? | MC | Soaring | 42 | April 7th 05 08:07 PM |
WGC2004 Club Class | GRETHE R BULUKIN | Soaring | 0 | March 15th 04 06:39 PM |
UK Open Class and Club Class Nationals - Lasham | Steve Dutton | Soaring | 0 | August 6th 03 10:07 PM |
