Well IGC are letting in the ASW20 and Discus into Club
Class next year, (and increasing the handicap on the Std. Cirrus at long last!). Which one should I buy - which is likely to be more competetive? or is there an alternative? I would like higher performance for non-competetive distance flying. |
The most underhandicapped glider in the Club Class
is the DG101 IMHO. My Standard Cirrus glides nothing like as well, despite having the same (2007) handicap. If you want the best performance for non comp flying, get a Discus, a DG300 or an ASW20/24. Del C At 12:06 18 October 2007, Nick Olson wrote: Well IGC are letting in the ASW20 and Discus into Club Class next year, (and increasing the handicap on the Std. Cirrus at long last!). Which one should I buy - which is likely to be more competetive? or is there an alternative? I would like higher performance for non-competetive distance flying. |
Nick Olson wrote:
Well IGC are letting in the ASW20 and Discus into Club Class next year, (and increasing the handicap on the Std. Cirrus at long last!). Which one should I buy - which is likely to be more competetive? or is there an alternative? I would like higher performance for non-competetive distance flying. The Discus is a great ship. I love it but compared with the ASW-24, IMHO it does not handle as well as the Schleicher and the cockpit appointments are not as comfy. If you can swing it, I'd say stretch for the '24. It will probably serve you longer and grow with your abilities longer than the ASW-20 which seems may be getting a little "long in the performance tooth". I must admit tho' I have not flown the '20 yet. -- Message posted via http://www.aviationkb.com |
An AS-W20 "long in the tooth???
Certainly older but give little to nothing away to current generation 15 m ships in most conditions. Look at how many 1000 km / record flights have been done in 20's. I believe Terry Delore flew the first 2000 km flight in one. The -20 is probably the best all-around X-C ship ever built. Excellent performance, good handling, and ergonomics, well crafted and engineered and the flaps allow for outstanding off-field capability. I would never buy a std class ship due to the lack of flaps. If you are not top 20 in OLC or in the racing community,YOU are the weakest link in the performance chain! 20's Rock! |
On Oct 18, 3:10 pm, " wrote:
An AS-W20 "long in the tooth??? Certainly older but give little to nothing away to current generation 15 m ships in most conditions. Look at how many 1000 km / record flights have been done in 20's. I believe Terry Delore flew the first 2000 km flight in one. The -20 is probably the best all-around X-C ship ever built. Excellent performance, good handling, and ergonomics, well crafted and engineered and the flaps allow for outstanding off-field capability. I would never buy a std class ship due to the lack of flaps. If you are not top 20 in OLC or in the racing community,YOU are the weakest link in the performance chain! 20's Rock! One thing I've noticed in aviation history; "they don't build a lot of bad airplanes" Let the ASW-20 numbers speak for themself I think it's the second most built glider in history (the first being the Blanik) It is the most 15 meter ship built There is a reason for this- As Mark says -20's Rock! Dan Rihn ASW-20 WO (and loving it every flight) |
ASW20 and Discus in Club Class next year. | Nick Olson | Soaring | 8 | October 20th 07 10:58 PM |
ASW20 and Discus in Club Class next year. | Nick Olson | Soaring | 0 | October 18th 07 12:59 PM |
SPORTS CLASS/CLUB CLASS | 5 ugly | Soaring | 0 | July 2nd 06 11:14 PM |
Does USA need a Club Class? | MC | Soaring | 42 | April 7th 05 08:07 PM |
UK Open Class and Club Class Nationals - Lasham | Steve Dutton | Soaring | 0 | August 6th 03 10:07 PM |
