A friend of mine has some very nice aircraft auxiliary power cables, and
he was going to take it apart and remove the insulation for the scrap copper. After seeing how nice it is (4/0 stranded cable), he put it back together, but he noticed something strange. Inside the plug connector was a 50 ohm resister in series with a diode connected across the two cables. Copper pins were inserted into the braided wire to make the connection. Does anyone know what that is for? Thanks |
Paul Dow (Remove Caps in mail address) wrote: A friend of mine has some very nice aircraft auxiliary power cables, and he was going to take it apart and remove the insulation for the scrap copper. After seeing how nice it is (4/0 stranded cable), he put it back together, but he noticed something strange. Inside the plug connector was a 50 ohm resister in series with a diode connected across the two cables. Copper pins were inserted into the braided wire to make the connection. Does anyone know what that is for? Reverse polarity protecion? Connect it wrong and diode shorts and fuse upstream blows? -- Eduardo K. | Darwin pone las reglas. http://www.carfun.cl | Murphy, la oportunidad. http://ev.nn.cl | | Yo. |
On Thu, 18 Oct 2007 15:17:33 +0000 (UTC), Eduardo K.
wrote: In article , Paul Dow (Remove Caps in mail address) wrote: A friend of mine has some very nice aircraft auxiliary power cables, and he was going to take it apart and remove the insulation for the scrap copper. After seeing how nice it is (4/0 stranded cable), he put it back together, but he noticed something strange. Inside the plug connector was a 50 ohm resister in series with a diode connected across the two cables. Copper pins were inserted into the braided wire to make the connection. Does anyone know what that is for? Reverse polarity protecion? Connect it wrong and diode shorts and fuse upstream blows? I'd guess either a zener or transzorb with 50 ohms to limit current? 50 ohms, 25 volts, 0.5 amp ... |
On Thu, 18 Oct 2007 09:24:42 -0400, "Paul Dow (Remove Caps in mail
address)" wrote in : A friend of mine has some very nice aircraft auxiliary power cables, and he was going to take it apart and remove the insulation for the scrap copper. After seeing how nice it is (4/0 stranded cable), he put it back together, but he noticed something strange. Inside the plug connector was a 50 ohm resister in series with a diode connected across the two cables. Copper pins were inserted into the braided wire to make the connection. Does anyone know what that is for? Thanks It sounds like a surge suppressor or snubber circuit to me. |
That seems to make sense. I wasn't familiar with snubber circuits, nor
even the word snubber, until I looked it up now. You wouldn't want the voltage spike hitting the aircraft when plugging in the outside power, so that probably limits the rate of voltage change. I don't think it protects against reverse polarity since it doesn't look like something that gets replaced easily if it breaks. The parts are quite small for current limiting too. Thanks everyone. I'll put it back in. Larry Dighera wrote: It sounds like a surge suppressor or snubber circuit to me. |
FS: Piper Jumper Cables | Video Man | Aviation Marketplace | 1 | January 29th 07 12:27 AM |
Request: RT459 14V illumination jumper settings | mikem | Owning | 0 | October 17th 06 04:37 PM |
FA: Piper Aircraft Booster Cables | Sk8hard | Aviation Marketplace | 0 | June 13th 06 09:04 PM |
Gen Jumper praises Eurofighter | John Cook | Military Aviation | 6 | July 22nd 04 04:37 PM |
MiG-29 cables | alcatraz | Military Aviation | 0 | March 1st 04 10:01 PM |
