The following paragraph is copied from the book "Cessna, Wings for the
World" written by William D. Thompson, an Engineering Test Pilot and later Manager of Flight Test and Aerodynamics at the Cessna Aircraft Co. With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered a nose down pitch in forward slips with the wing flaps deflected. In some cases it was severe enough to lift the pilot against his seat belt if he was slow in checking the motion. For this reason a caution note was placed in most of the owner's manuals under "Landings" reading "Slips should be avoided with flap settings greater than 30° due to a downward pitch encountered under certain combinations of airspeed, side-slip angle, and center of gravity loadings". Since wing-low drift correction in cross-wind landings is normally performed with a minimum flap setting (for better rudder control) this limitation did not apply to that maneuver. The cause of the pitching motion is the transition of a strong wing downwash over the tail in straight flight to a lessened downwash angle over part of the horizontal tail caused by the influence of a relative "upwash increment" from the upturned aileron in slipping flight. Although not stated in the owner's manuals, we privately encouraged flight instructors to explore these effects at high altitude, and to pass on the information to their students. This phenomenon was elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware of its existence and know how to counter-act it if it occurs close to the ground. When the larger dorsal fin was adopted in the 1972 C-172L, this side-slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher-powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed. Karl "Curator" |
And this was posted why?
"karl gruber" wrote in message ... The following paragraph is copied from the book "Cessna, Wings for the World" written by William D. Thompson, an Engineering Test Pilot and later Manager of Flight Test and Aerodynamics at the Cessna Aircraft Co. With the advent of the large slotted flaps in the C-170, C-180, and C-172 we encountered a nose down pitch in forward slips with the wing flaps deflected. In some cases it was severe enough to lift the pilot against his seat belt if he was slow in checking the motion. For this reason a caution note was placed in most of the owner's manuals under "Landings" reading "Slips should be avoided with flap settings greater than 30° due to a downward pitch encountered under certain combinations of airspeed, side-slip angle, and center of gravity loadings". Since wing-low drift correction in cross-wind landings is normally performed with a minimum flap setting (for better rudder control) this limitation did not apply to that maneuver. The cause of the pitching motion is the transition of a strong wing downwash over the tail in straight flight to a lessened downwash angle over part of the horizontal tail caused by the influence of a relative "upwash increment" from the upturned aileron in slipping flight. Although not stated in the owner's manuals, we privately encouraged flight instructors to explore these effects at high altitude, and to pass on the information to their students. This phenomenon was elusive and sometimes hard to duplicate, but it was thought that a pilot should be aware of its existence and know how to counter-act it if it occurs close to the ground. When the larger dorsal fin was adopted in the 1972 C-172L, this side-slip pitch phenomenon was eliminated, but the cautionary placard was retained. In the higher-powered C-172P and C-R172 the placard was applicable to a mild pitch "pumping" motion resulting from flap outboard-end vortex impingement on the horizontal tail at some combinations of side-slip angle, power, and airspeed. Karl "Curator" |
NEW & UNOPENED: Gleim Commercial Pilot Knowledge Test (book AND Commercial Pilot Test Software) | Cecil Chapman | Products | 2 | November 13th 04 03:56 AM |
FA: Cessna Private Pilot and Instrument Pilot Complete Training Kits | Wei-En Tan | Aviation Marketplace | 1 | May 30th 04 07:38 PM |
Cessna 182S flaps | EDR | Piloting | 7 | January 16th 04 02:37 AM |
slipping in turns | John Firth | Soaring | 0 | November 28th 03 11:49 PM |
crabbing and slipping | Nyal Williams | Soaring | 3 | September 15th 03 10:07 AM |
