Grob 103 weighing
Old October 21st 07, 11:21 PM posted to rec.aviation.soaring
Default Grob 103 weighing
We are going to have our Grob 103 weighed next week. In the flight
manual it says "Level means 600:24 incidence board" set up
horizontial on the top of the rear fuselage. I plead
ignorance....what is a 600:24 incidence board?
Thanks
Kurt
Old October 21st 07, 11:46 PM posted to rec.aviation.soaring
BT
Kurt.. your mechanic that does the weighing will know this.
But an "incidence board" is a "wedge" that would rise 24 inches (or
centimeters) over a distance of 600 of the same inches or centimeters.
It is a "set slope", the back of the grob fuselage just in front of the
curve where the vertical fin starts is not "level", you could not place a
level there to level the fuselage for weighing. Add this incidence board,
place the level on the board, make the bubble level and take the main and
tail wheel weights. Compute the empty CG per the POH.
If thinking "inches", 600:24 = 300:12 = 150:6
divide by 10, a 15in long board placed on the fuselage as directed in the
weighing instructions would rise 6 tenths (0.6) of an inch for the distance.
BT
Thanks
Kurt
Old October 22nd 07, 04:39 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
In other words, an angle of 2.29 degrees.
rj
Old October 23rd 07, 04:41 PM posted to rec.aviation.soaring
nimbusgb
rj
24mm in 600mm or exactly 1:25 ( about the same as the glide angle of
the 103 )
Ian m
Old October 22nd 07, 01:10 AM posted to rec.aviation.soaring
Thanks
Kurt
Kurt:
Look in the maintenance manual section of the G-103 manual, page 13.
There you will find a drawing of the incidence board and its correct
location on the fuselage spine.
Robert Mudd
Moriarty, New Mexico
self-weighing luggage Kyler Laird General Aviation 0 April 11th 06 12:17 AM
Grob Bob O'Rilley Soaring 3 April 29th 05 07:22 PM
Glider weighing scales C AnthMin Soaring 0 July 12th 04 06:53 AM
Glider weighing scales. Terence Beasley Soaring 2 July 7th 04 04:14 AM
GROB 102 Vorsanger1 Soaring 4 July 11th 03 11:34 PM
