I've heard that above some altitude, the FARs require the use of an
oxygen mask rather than a cannula in US registered aircraft. Where do I find this requirement? (FAR 91.211 doesn't mention it.) Thanks Stefan |
On Oct 30, 9:18 am, Stefan wrote:
I've heard that above some altitude, the FARs require the use of an oxygen mask rather than a cannula in US registered aircraft. Where do I find this requirement? (FAR 91.211 doesn't mention it.) Thanks Stefan I'm not sure its a FAR but it is a limitation printed on my O2 system. I assume that limitation is a condition of its certification. -Robert |
On Tue, 30 Oct 2007 17:18:00 +0100, Stefan
wrote: I've heard that above some altitude, the FARs require the use of an oxygen mask rather than a cannula in US registered aircraft. Where do I find this requirement? (FAR 91.211 doesn't mention it.) Thanks Stefan I don't know of a equirement for using it, but there is a reequirement for having it available on board. See FAR 23.1447. - Tom |
Tom L. schrieb:
I don't know of a equirement for using it, but there is a reequirement for having it available on board. See FAR 23.1447. Thanks, found it. In simple words: FAR 91.211 requires the use of oxygen above some altitude, FAR 23.1447 requires that the equipment be a mask above 18'000 feet. |
Stefan wrote:
Tom L. schrieb: I don't know of a equirement for using it, but there is a reequirement for having it available on board. See FAR 23.1447. Thanks, found it. In simple words: FAR 91.211 requires the use of oxygen above some altitude, FAR 23.1447 requires that the equipment be a mask above 18'000 feet. It does no such thing. |
Stefan wrote:
Tom L. schrieb: I don't know of a equirement for using it, but there is a reequirement for having it available on board. See FAR 23.1447. Thanks, found it. In simple words: FAR 91.211 requires the use of oxygen above some altitude, FAR 23.1447 requires that the equipment be a mask above 18'000 feet. No, it says if the aircraft is equipped with oxygen installed and certified for flight above 18000 feet then, a mask is required. |
Tom L. wrote:
On Tue, 30 Oct 2007 17:18:00 +0100, Stefan wrote: I've heard that above some altitude, the FARs require the use of an oxygen mask rather than a cannula in US registered aircraft. Where do I find this requirement? (FAR 91.211 doesn't mention it.) Thanks Stefan I don't know of a equirement for using it, but there is a reequirement for having it available on board. See FAR 23.1447. That reg only covers the certification requirements for aircraft with installed oxygen systems. |
Stefan wrote:
I've heard that above some altitude, the FARs require the use of an oxygen mask rather than a cannula in US registered aircraft. Where do I find this requirement? (FAR 91.211 doesn't mention it.) Thanks Stefan The FARs don't care if you suck off the regulator directly. What's effective is another story. |
On Oct 30, 2:06 pm, Ron Natalie wrote:
Stefan wrote: I've heard that above some altitude, the FARs require the use of an oxygen mask rather than a cannula in US registered aircraft. Where do I find this requirement? (FAR 91.211 doesn't mention it.) Thanks Stefan The FARs don't care if you suck off the regulator directly. What's effective is another story. Is the pilot obligated to follow the certification of the O2 system? -Robert |
Robert M. Gary wrote:
On Oct 30, 2:06 pm, Ron Natalie wrote: Stefan wrote: I've heard that above some altitude, the FARs require the use of an oxygen mask rather than a cannula in US registered aircraft. Where do I find this requirement? (FAR 91.211 doesn't mention it.) Thanks Stefan The FARs don't care if you suck off the regulator directly. What's effective is another story. Is the pilot obligated to follow the certification of the O2 system? What certification? |
O2 Mask On Pilot? | fred | Piloting | 26 | August 22nd 05 06:13 PM |
Nasal cannula, flowmeter combinations. | Lord Struthers | Soaring | 0 | May 5th 04 05:04 PM |
Oxygen mask and regulator sale - update | nzuri | Soaring | 0 | October 1st 03 09:31 AM |
Boom-mike cannula | Jay | Products | 3 | September 19th 03 03:10 PM |
Boom mounted O2 cannula | Viperdoc | Instrument Flight Rules | 1 | August 21st 03 02:19 PM |
