Water Ballast in the Mountain Wave
Old November 9th 07, 04:12 PM posted to rec.aviation.soaring
Fox Two
Default Water Ballast in the Mountain Wave
Is there a safe way to carry water ballast when the outside air
temperature is below freezing?
Old November 9th 07, 05:43 PM posted to rec.aviation.soaring
bumper
I bet it depends on how long you stay up there and how much below freezing
OAT is.
No matter, if you fill your ballast tanks with sawdust, worst case you'll
just end up with "piecrete" popsicles.
bumper
zz (lower case)
"Fox Two" wrote in message
ps.com...
Old November 9th 07, 06:48 PM posted to rec.aviation.soaring
Ralph Jones[_2_]
On Fri, 09 Nov 2007 17:43:11 GMT, "bumper"
OAT is.
Pykrete, after its inventor Geoffrey Pyke. It would offer a few
problems:
1) The contents of your tanks would not freeze into Pykrete. They'd
freeze into ice with a layer of sawdust on top. In order to make
Pykrete you have to agitate the mix constantly until frozen, or
freeze it in layers adding the sawdust as you go.
2) If ballast tanks full of Pykrete froze, you'd have the same problem
you would with plain water ice: landing with a load of ballast aboard.
Better yet, since the drain valves are the most susceptible point for
freezing, you'd run the risk of dumping only one side, which would
make your landing REALLY interesting.
3) Pykrete expands on freezing just as water does, maybe a bit less,
so you'd still run the risk of bursting your tanks.
rj
Old November 10th 07, 06:22 AM
bagmaker bagmaker is offline
Senior Member
First recorded activity by AviationBanter: Aug 2005
[/quote]
There are numerous posts on this, do a history search of RAS
keep it moving, keep your feet and head warm, worry not about the ballast
bagger
Old November 9th 07, 07:22 PM posted to rec.aviation.soaring
Mike Schumann
Antifreeze???
Mike Schumann
ps.com...
Posted via a free Usenet account from http://www.teranews.com
Old November 9th 07, 08:12 PM posted to rec.aviation.soaring
Mal[_4_]
I use zinc cream to stop them from leaking.
Who first used water ballast and when? John McCullagh Soaring 9 October 18th 06 09:36 AM
Water Ballast Upgrade P.Corbett Soaring 5 December 5th 05 02:32 PM
water ballast leak Robert Harvey Soaring 2 May 27th 05 03:49 PM
water ballast leak Robert Harvey Soaring 0 May 26th 05 10:33 PM
Std 102 water ballast plug Tom Dukerich Soaring 3 April 12th 05 05:10 PM
