SeeYou Mobile Question (units)
Old November 9th 07, 09:37 PM posted to rec.aviation.soaring
Default SeeYou Mobile Question (units)
I've just started to look a little closer at the features and settings
in SeeYou mobile. What I can't figure out is how to change the units
for the distance numbers that show up next to the waypoints on the
map. These are the ones that get a green box around them when you're
within glide range. I'm assuming the units are kilometers. Anyone know
how to change this? I've been through the user manual, but there's no
reference to this map feature at all. At least not that I can find.
Thanks,
Dave
Old November 9th 07, 09:55 PM posted to rec.aviation.soaring
Thanks,
Dave
Dave
Are you looking at L/D required to reach the waypoint or the Distance.
Look at MenuSettingsWpts labelOne and labelTwo
Distance units are set in MenuSettingsUnits. They can also be set
when you use the Mobile Wizard to synch from SeeYou.
Darryl
Old November 9th 07, 10:05 PM posted to rec.aviation.soaring
On Nov 9, 3:55 pm, "
Thanks,
Dave
Dave
Darryl
Thanks Darryl. I didn't even consider that the numbers shown could be
L/D. I assumed it was a distance number since it counts down as I get
closer. Of course L/D required would do the same. I don't have my PDA
with me right now, but I'll look at those two labels in the waypoints
settings the first chance I get. I know where the units settings are,
and that's what confused me. I was changing the units, but these
numbers on the map were not changing at all. Makes total sense now. I
guess if I would have had the L/D (nav box) displayed, I might have
noticed the correlation.
Thanks again,
Dave
Old November 9th 07, 10:14 PM posted to rec.aviation.soaring
Thanks,
Dave
Dave
Darryl
Another question for you. Do you know if the 302 sends all the
necessary data to SeeYou to calculate wind?
Old November 9th 07, 11:05 PM posted to rec.aviation.soaring
Paul Remde
Hi Dave,
Yes. SeeYou gets airspeed and wind data from the 302. The 302 calculates
the wind - not SeeYou. If SeeYou does not get wind data from the flight
computer it can calculate wind while circling, but the 302 also calculates
wind while cruising.
Let me know if you ever want some one-on-one phone support for SeeYou. I do
that quite often and my customers tell me it is worth every penny.
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.
ps.com...
Thanks,
Dave
Dave
Darryl
Old November 9th 07, 11:57 PM posted to rec.aviation.soaring
On Nov 9, 5:05 pm, "Paul Remde" wrote:
Hi Dave,
Good Soaring,
Paul Remde
Cumulus Soaring, Inc.http://www.cumulus-soaring.com
ps.com...
Thanks,
Dave
Dave
Darryl
necessary data to SeeYou to calculate wind?- Hide quoted text -
- Show quoted text -
Thanks Paul!
Yes, I am already aware of the excellent service you provide. Don't
know if you realize it, but I'm the same Dave that spoke to you
regarding the Dell Axim connectivity today. I'm looking forward to
getting the PDA integrated into my cockpit for next season. I'll be
talking to you soon to follow up on the Axim cabling.
Dave
Old November 10th 07, 12:04 AM posted to rec.aviation.soaring
Greg Arnold
Paul Remde wrote:
Hi Dave,
So the 302A not only is a logger, but also has a computer that
calculates wind?
Good Soaring,
Paul Remde
Old November 10th 07, 01:28 AM posted to rec.aviation.soaring
Marc Ramsey[_2_]
Greg Arnold wrote:
Paul Remde wrote:
Hi Dave,
calculates
calculates wind?
No, the 302 flight computer calculates wind. The 302A flight recorder
does not...
Marc
Old November 10th 07, 12:07 AM posted to rec.aviation.soaring
On Nov 9, 3:05 pm, "Paul Remde" wrote:
Hi Dave,
Good Soaring,
Paul Remde
[snip]
Paul - ah are you sure? SeeYou Mobile also gets true airspeed and
other data from the 302. SeeYou Mobile is quite capable of using those
to guestimate non-circling winds. And it was my impression that it did
this and does not directly use the calculated wind data (that is also
passed from the 302). It certainly appears to behave that way to me.
Dave FYI the Cambridge dataport reference manual is an interesting
read, and SeeYou has a terminal mode (MenuSettingsHardwareTerminal)
you can look at what is going over the wire. That has helped me in the
past at least understand some behavior of SeeYou (and file a bug :-))
- SeeYou support is pretty darn good, check out their Forums. See
http://www.cambridge-aero.com/manual...v517_rev21.pdf
Cheers
Darryl
Old November 10th 07, 01:36 PM posted to rec.aviation.soaring
Paul Remde
Hi,
I stand corrected. Andrej at SeeYou confirmed that SeeYou uses the airspeed
information from the 302 and calculates the wind independently. It does not
use the 302 supplied wind calculation. The 302 calculates only a single
wind number (if I remember correctly). SeeYou calculates winds at several
altitudes (if I remember correctly).
That would explain why some pilots see different numbers in SeeYou than they
do on their 303 display.
Good Soaring,
Paul Remde
Hi Dave,
calculates
calculates
do
Good Soaring,
Paul Remde
[snip]
Cheers
Darryl
Using mobile SeeYou Robert Hart Soaring 3 May 10th 06 09:42 PM
SeeYou MOBILE v2.0! Roy McMaster Soaring 10 July 12th 04 12:25 AM
SeeYou Mobile Robert Fidler Soaring 0 March 17th 04 04:18 PM
SeeYou Mobile question Greg Arnold Soaring 1 February 19th 04 04:24 PM
SeeYou mobile questions Andy Durbin Soaring 5 February 19th 04 12:16 AM
