A question to IR pilots. Suppose we have the following situation: a flight departing from MMU rw 23, cleared as follows: "Morristown 5 dep, vectors to BIGGY, then V3, MAZIE, etc... 2000 feet, expect 4000 10 minutes after departure, dep freq, squawk etc..." Now, during climb-out via heading 210 we lose communication. It is IMC. Standard question: what altitudes and routing you'd fly? The aircraft we're flying is /U, so we can't navigate direct BIGGY. First question: would you keep flying the DP, i.e. left turn 160? If so, for how long would you fly heading 160 after you turn? Lost comm instructions in the DP do not apply to us since we're southbound. In order to get onto V3 you'd probably need to fly direct SBJ, and proceed from there, but SBJ is not part of your clearance? Second question -- the altitude: OROCA in the quadrant is 2900. MSA provided by Jepp for CAT is 2000 in this sector. Would you climb to 4000 right away, or you'd wait for 10 mins? MEAs of the airways in that vicinity are 2300 and 3000 feet. Andrey |
How about Direct SBJ, pick up V3 and be on your way
"Andrey Serbinenko" wrote in message ... A question to IR pilots. Suppose we have the following situation: a flight departing from MMU rw 23, cleared as follows: "Morristown 5 dep, vectors to BIGGY, then V3, MAZIE, etc... 2000 feet, expect 4000 10 minutes after departure, dep freq, squawk etc..." Now, during climb-out via heading 210 we lose communication. It is IMC. Standard question: what altitudes and routing you'd fly? The aircraft we're flying is /U, so we can't navigate direct BIGGY. First question: would you keep flying the DP, i.e. left turn 160? If so, for how long would you fly heading 160 after you turn? Lost comm instructions in the DP do not apply to us since we're southbound. In order to get onto V3 you'd probably need to fly direct SBJ, and proceed from there, but SBJ is not part of your clearance? Second question -- the altitude: OROCA in the quadrant is 2900. MSA provided by Jepp for CAT is 2000 in this sector. Would you climb to 4000 right away, or you'd wait for 10 mins? MEAs of the airways in that vicinity are 2300 and 3000 feet. Andrey |
pgbnh wrote:
How about Direct SBJ, pick up V3 and be on your way "Andrey Serbinenko" wrote in message ... A question to IR pilots. Suppose we have the following situation: a flight departing from MMU rw 23, cleared as follows: "Morristown 5 dep, vectors to BIGGY, then V3, MAZIE, etc... 2000 feet, expect 4000 10 minutes after departure, dep freq, squawk etc..." Now, during climb-out via heading 210 we lose communication. It is IMC. Standard question: what altitudes and routing you'd fly? The aircraft we're flying is /U, so we can't navigate direct BIGGY. First question: would you keep flying the DP, i.e. left turn 160? If so, for how long would you fly heading 160 after you turn? Lost comm instructions in the DP do not apply to us since we're southbound. In order to get onto V3 you'd probably need to fly direct SBJ, and proceed from there, but SBJ is not part of your clearance? Second question -- the altitude: OROCA in the quadrant is 2900. MSA provided by Jepp for CAT is 2000 in this sector. Would you climb to 4000 right away, or you'd wait for 10 mins? MEAs of the airways in that vicinity are 2300 and 3000 feet. Andrey I would wait until 10 min to climb to 4000, and climb initially only to the appropriate minimum IFR altitude for that sector or MSA or whatever was appropriate, if higher than the current vectoring alt. The EAC time is probably to get clear of inbound traffic above, so going there right away may cause ATC to have to reroute traffic over you. You would probably be ok to proceed direct on a 45 deg intercept heading to V3 if that made more sense then direct SBJ. I think that in a comm failure situation where options are presented, you are ok as long as you act reasonably and don't head off in odd unexpected directions. ATC is going to deduce what you are doing pretty quickly and make allowances. John |
I have two doubts about that: First, it seems to contradict item iii of the following reg: FAR Sec. 91.185 - IFR operations: Two-way radio communications failure. ----------- (2) Altitude. At the highest of the following altitudes or flight levels for the route segment being flown: (i) The altitude or flight level assigned in the last ATC clearance received; (ii) The minimum altitude (converted, if appropriate, to minimum flight level as prescribed in .91.121(c)) for IFR operations; or (iii) The altitude or flight level ATC has advised may be expected in a further clearance. ----------- It lists "expected" along with everything else, and doesn't mention anywhere that you should wait for the EFC time to pass before using it. Secondly, while being radar-vectored I have never had to wait for ten minutes: three-four minutes maximum, which makes me think that staying low for that long may not in fact be desirable. In particular, staying at 2000 feet while maneuvering in southerly direction for too long can put me in close proximity to TEB ILS rw 6 approach path. You would probably be ok to proceed direct on a 45 deg intercept heading to V3 if that made more sense then direct SBJ. I think that in a comm I agree with that. My only concern would be the fact that the DP is "obstacle", and it mandates making a turn to 160 after getting to 2000 feet, presumably keeping me away from something. But it doesn't specify for how long I should stay on that heading before resuming enroute navigation. Andrey |
Andrey Serbinenko wrote:
I would wait until 10 min to climb to 4000, and climb initially only to I have two doubts about that: First, it seems to contradict item iii of the following reg: FAR Sec. 91.185 - IFR operations: Two-way radio communications failure. ----------- (2) Altitude. At the highest of the following altitudes or flight levels for the route segment being flown: (i) The altitude or flight level assigned in the last ATC clearance received; (ii) The minimum altitude (converted, if appropriate, to minimum flight level as prescribed in .91.121(c)) for IFR operations; or (iii) The altitude or flight level ATC has advised may be expected in a further clearance. ----------- It lists "expected" along with everything else, and doesn't mention anywhere that you should wait for the EFC time to pass before using it. Secondly, while being radar-vectored I have never had to wait for ten minutes: three-four minutes maximum, which makes me think that staying low for that long may not in fact be desirable. In particular, staying at 2000 feet while maneuvering in southerly direction for too long can put me in close proximity to TEB ILS rw 6 approach path. I should mention that I am in Canada and the IFR regs are more or less the same, but in the Canadian AIM there is an explicit statement in reference to altitude in a comm failure situation: "the altitude or FL that ATC has advised may be expected in a further clearance (the pilot shall commence climb to this altitude/FL at the time/point specified by ATC to expect further clearance/altitude change)." The way you quoted the FAR above it certainly implies that you should start climbing right away. This is a significant difference in the lost comm procedures between Can/US. John |
On 12 Nov 2007 04:10:11 GMT, Andrey Serbinenko
wrote: Now, during climb-out via heading 210 we lose communication. It is IMC. Standard question: what altitudes and routing you'd fly? The aircraft we're flying is /U, so we can't navigate direct BIGGY. I'd probably decline the clearance or ask for vectors SBJ instead since I can't do the direct part, but if forced to attempt this I'd likely fly last given heading until getting onto an intercept for SBJ R-237 or R067, then turn towards BIGGY. |
"Peter Clark" wrote in message ... I'd probably decline the clearance or ask for vectors SBJ instead since I can't do the direct part, but if forced to attempt this I'd likely fly last given heading until getting onto an intercept for SBJ R-237 or R067, then turn towards BIGGY. What's the direct part? |
On Tue, 13 Nov 2007 17:04:39 -0600, "Steven P. McNicoll"
wrote: "Peter Clark" wrote in message .. . I'd probably decline the clearance or ask for vectors SBJ instead since I can't do the direct part, but if forced to attempt this I'd likely fly last given heading until getting onto an intercept for SBJ R-237 or R067, then turn towards BIGGY. What's the direct part? "Expect radar vectors BIGGY" then losing comms while on a vector? |
"Peter Clark" wrote in message ... "Expect radar vectors BIGGY" then losing comms while on a vector? What's the direct part? |
In this day and age, anyone who flies IFR in IMC withut a GPS handheld, which would enable you to fly direct BIGGY, is just plain foolish... On 12 Nov 2007 04:10:11 GMT, Andrey Serbinenko wrote: A question to IR pilots. Suppose we have the following situation: a flight departing from MMU rw 23, cleared as follows: "Morristown 5 dep, vectors to BIGGY, then V3, MAZIE, etc... 2000 feet, expect 4000 10 minutes after departure, dep freq, squawk etc..." Now, during climb-out via heading 210 we lose communication. It is IMC. Standard question: what altitudes and routing you'd fly? The aircraft we're flying is /U, so we can't navigate direct BIGGY. First question: would you keep flying the DP, i.e. left turn 160? If so, for how long would you fly heading 160 after you turn? Lost comm instructions in the DP do not apply to us since we're southbound. In order to get onto V3 you'd probably need to fly direct SBJ, and proceed from there, but SBJ is not part of your clearance? Second question -- the altitude: OROCA in the quadrant is 2900. MSA provided by Jepp for CAT is 2000 in this sector. Would you climb to 4000 right away, or you'd wait for 10 mins? MEAs of the airways in that vicinity are 2300 and 3000 feet. Andrey |
| Lost Comm route? | [email protected] | Instrument Flight Rules | 8 | June 22nd 07 03:28 PM |
| Lost comm in Mexico | Michael | Piloting | 3 | January 27th 06 01:17 AM |
| Lost comm -- what would you do? | Roy Smith | Instrument Flight Rules | 19 | December 1st 05 04:57 PM |
| Lost comm procedures | Ron Garret | Instrument Flight Rules | 12 | March 8th 05 10:42 AM |
| Lost comm altitude? | Roy Smith | Instrument Flight Rules | 12 | January 11th 04 01:29 AM |
