Could someone fill me in on the Aerostar fuel system? The one in
question is a 602P. IIRC, Ted Smith designed it as a "Leave it alone and burn all the fuel in the airplane" type system. But wasn't there a lawsuit over one years ago? Al G |
![]() "Al G" wrote in message ... Could someone fill me in on the Aerostar fuel system? The one in question is a 602P. IIRC, Ted Smith designed it as a "Leave it alone and burn all the fuel in the airplane" type system. But wasn't there a lawsuit over one years ago? There's lawsuits over EVERYTHING in the air at one time or another. -- Matt Barrow Performance Homes, LLC. Cheyenne, WY |
On Nov 13, 4:33 pm, "Matt W. Barrow"
wrote: "Al G" wrote in message ... Could someone fill me in on the Aerostar fuel system? The one in question is a 602P. IIRC, Ted Smith designed it as a "Leave it alone and burn all the fuel in the airplane" type system. But wasn't there a lawsuit over one years ago? There's lawsuits over EVERYTHING in the air at one time or another. -- Matt Barrow Performance Homes, LLC. Cheyenne, WY I seem to remember, a looooong time ago, perhaps right after Piper resumed building Aerostars that an AD came out that required separate fuel gauges to be installed. The result was the three fuel gauges now seen at the top and center of Aerostar panels. Now . . . I could be completely wrong, and if I am, I hope someone with a lot more Aerostar knowledge will add to this thread. Take care . . . John |
![]() "John" wrote in message ... On Nov 13, 4:33 pm, "Matt W. Barrow" wrote: "Al G" wrote in message ... Could someone fill me in on the Aerostar fuel system? The one in question is a 602P. IIRC, Ted Smith designed it as a "Leave it alone and burn all the fuel in the airplane" type system. But wasn't there a lawsuit over one years ago? There's lawsuits over EVERYTHING in the air at one time or another. -- Matt Barrow Performance Homes, LLC. Cheyenne, WY I seem to remember, a looooong time ago, perhaps right after Piper resumed building Aerostars that an AD came out that required separate fuel gauges to be installed. The result was the three fuel gauges now seen at the top and center of Aerostar panels. Now . . . I could be completely wrong, and if I am, I hope someone with a lot more Aerostar knowledge will add to this thread. Take care . . . John Thanks, I was asking because a friend got killed in one Friday, from apparent fuel starvation. http://www.ntsb.gov/ntsb/brief.asp?e...13X01789&key=1 I originally thought that it would be hard to burn the thing dry on a 508nm trip. With headwinds and a short fuel load to begin with, it becomes more plausible. Al G |
On Nov 15, 1:22 pm, "Al G" wrote:
"John" wrote in message ... On Nov 13, 4:33 pm, "Matt W. Barrow" wrote: "Al G" wrote in message ... Could someone fill me in on the Aerostar fuel system? The one in question is a 602P. IIRC, Ted Smith designed it as a "Leave it alone and burn all the fuel in the airplane" type system. But wasn't there a lawsuit over one years ago? There's lawsuits over EVERYTHING in the air at one time or another. -- Matt Barrow Performance Homes, LLC. Cheyenne, WY I seem to remember, a looooong time ago, perhaps right after Piper resumed building Aerostars that an AD came out that required separate fuel gauges to be installed. The result was the three fuel gauges now seen at the top and center of Aerostar panels. Now . . . I could be completely wrong, and if I am, I hope someone with a lot more Aerostar knowledge will add to this thread. Take care . . . John Thanks, I was asking because a friend got killed in one Friday, from apparent fuel starvation. http://www.ntsb.gov/ntsb/brief.asp?e...13X01789&key=1 I originally thought that it would be hard to burn the thing dry on a 508nm trip. With headwinds and a short fuel load to begin with, it becomes more plausible. Al G- Hide quoted text - - Show quoted text - Al, For your friend's family, along with you and his or her other friends, my heartfelt condolences. Take care . . . John |
Just found this . . . see http://www.planecheck.com/aerostar.htm
"The Aerostar's fuel system has been the subject of some criticism over the years. The aircraft has three tanks - one in each wing and a central fuselage tank mounted mid-way up behind the rear cabin bulkhead. The system holds 165.5 gallons of useable fuel. The intention was to use tank vents to maintain an equal level of fuel throughout the system. As the wing tanks depleted however, fuel feed would come from the fuselage. It is important to always have fuel in the central tank and although the system is designed to accommodate this, a number of accidents have followed simultaneous engine failure caused by uneven feeding. The number of Aerostar incidents caught the attention of the FAA who issued an airworthiness directive mandating the use of a low fuel warning light for the central tank. In 1979, the FAA issued a further AD forcing owners to install a triple fuel gauge - one for each tank. The AD also called for fuel cap inspections as it was suspected that negative pressure was responsible for restricting fuel flow causing premature depletion of the fuselage tank " Take care . . . John |
Similar situation in Super Vikings... There it has a gauge for each
tank and the gauges read the tanks in use... The problem was that the unselected tanks would show some reading, not having anything to do with the actual fuel in them because the gauge was unpowered when the tank was not selected and the needles would drift wherever they would... The pilots manual was clear on this, but some folks can't be bothered to read... So, guys would look at the aux tank gauges and it says 2/3 full and they would take off... But the tanks were not near full and the reading was spurious until the gauge was powered by selecting that tank... More than one Super Vike bought the farm because some pilot didn't understand his machine... denny |
Denny wrote:
Similar situation in Super Vikings... There it has a gauge for each tank and the gauges read the tanks in use... The problem was that the unselected tanks would show some reading, not having anything to do with the actual fuel in them because the gauge was unpowered when the tank was not selected and the needles would drift wherever they would... The pilots manual was clear on this, but some folks can't be bothered to read... So, guys would look at the aux tank gauges and it says 2/3 full and they would take off... But the tanks were not near full and the reading was spurious until the gauge was powered by selecting that tank... More than one Super Vike bought the farm because some pilot didn't understand his machine... denny While I agree you should read the damn manual... How damn hard would it have been to just power the guages all the time? |
Denny wrote:
Similar situation in Super Vikings... There it has a gauge for each tank and the gauges read the tanks in use... The problem was that the unselected tanks would show some reading, not having anything to do with the actual fuel in them because the gauge was unpowered when the tank was not selected and the needles would drift wherever they would... The pilots manual was clear on this, but some folks can't be bothered to read... So, guys would look at the aux tank gauges and it says 2/3 full and they would take off... But the tanks were not near full and the reading was spurious until the gauge was powered by selecting that tank... More than one Super Vike bought the farm because some pilot didn't understand his machine... denny What ever happened to eyeballing the fuel during preflight? |
On Nov 16, 1:49 pm, Ray Andraka wrote:
Denny wrote: Similar situation in Super Vikings... There it has a gauge for each tank and the gauges read the tanks in use... The problem was that the unselected tanks would show some reading, not having anything to do with the actual fuel in them because the gauge was unpowered when the tank was not selected and the needles would drift wherever they would... The pilots manual was clear on this, but some folks can't be bothered to read... So, guys would look at the aux tank gauges and it says 2/3 full and they would take off... But the tanks were not near full and the reading was spurious until the gauge was powered by selecting that tank... More than one Super Vike bought the farm because some pilot didn't understand his machine... denny What ever happened to eyeballing the fuel during preflight?- Hide quoted text - - Show quoted text - I wonder how good of a job you can do eyeballing fuel on planes with thin tanks. I am not saying it's not worth it, but I wonder if you can discern a real difference by looking. It seems like it could be hard especially on an unlevel surface. IIRC the Aerostar POH specifically cautions against fueling on uneven surfaces. take care . . . John |
AeroStar Fuel system? | Al G[_1_] | Piloting | 0 | November 12th 07 04:53 PM |
Troubleshooting the Comanche fuel system | Thomas | Owning | 9 | March 28th 06 11:07 AM |
advanced fuel flow mesurement system using microcontroller | khanindra jyoti deka | Home Built | 4 | January 4th 05 01:18 AM |
Shadin's Fuel Flow Management System | Tom Alton | Products | 0 | September 1st 04 06:07 PM |
Pawnee fuel system leak | Rod Pool | Soaring | 0 | August 12th 04 04:29 AM |
