"Ron Benell" wrote in message
m... I have wood building experience with a Super Emeraude some years ago and I'm looking for a project that will take quite a few years to complete. I just like the building process... Ron......... May I ask which Emeraude you worked on? Rich S. |
"Rich S." wrote in message ...
"Ron Benell" wrote in message m... I have wood building experience with a Super Emeraude some years ago and I'm looking for a project that will take quite a few years to complete. I just like the building process... Ron......... May I ask which Emeraude you worked on? Rich S. Rich I worked on The CP328 Super Emeraude for a few years and at that time just didn't have time to finish it. Since then I've retired and have lots of time. Ron |
(Ron Benell) wrote:
Good morning all I've just finished building a Hatz Classic biplane which I displayted at Oshkosh this year and now need to start another project. I've always had a eye for the GP4 and wonder if there is anyone out there that has any experience with the airplane. Any structural failures, resale values, etc etc. I have wood building experience with a Super Emeraude some years ago and I'm looking for a project that will take quite a few years to complete. I just like the building process... Any comments will be appreciated. Thanks Ron Ron, As a follow-up to my previous post, a search of the NTSB accident database reveals that there have been three fatal GP-4 accidents resulting in 5 fatalities. As there have only been a dozen or so GP-4 completions to date, this seems an unusually high percentage. Of course, the accident reports themselves will tell a more complete story. I'll let you draw your own conclusions. Here are the links to the accident reports. Be sure to read the full narratives. http://www.ntsb.gov/NTSB/brief.asp?e...11X12599&key=1 http://www.ntsb.gov/NTSB/brief.asp?e...12X18712&key=1 http://www.ntsb.gov/NTSB/brief.asp?e...06X00626&key=1 David O -- http://www.AirplaneZone.com |
On Tue, 02 Sep 2003 15:35:50 -0400, David O
wrote: (Ron Benell) wrote: Good morning all I've just finished building a Hatz Classic biplane which I displayted at Oshkosh this year and now need to start another project. I've always had a eye for the GP4 and wonder if there is anyone out there that has any experience with the airplane. Any structural failures, resale values, etc etc. I have wood building experience with a Super Emeraude some years ago and I'm looking for a project that will take quite a few years to complete. I just like the building process... Any comments will be appreciated. Thanks Ron Ron, As a follow-up to my previous post, a search of the NTSB accident database reveals that there have been three fatal GP-4 accidents resulting in 5 fatalities. As there have only been a dozen or so GP-4 completions to date, this seems an unusually high percentage. Of course, the accident reports themselves will tell a more complete story. I'll let you draw your own conclusions. Here are the links to the accident reports. Be sure to read the full narratives. http://www.ntsb.gov/NTSB/brief.asp?e...11X12599&key=1 http://www.ntsb.gov/NTSB/brief.asp?e...12X18712&key=1 http://www.ntsb.gov/NTSB/brief.asp?e...06X00626&key=1 I have flown this one and can give a bit more background and detail. As to the crash itself the ground had lots of fuel on it but that evaporates quickly. Hence the blighted vegetation. As the report noted, there were no baffles in the tanks. Although the report stated ground scarring was limited to underneath the plane form...The leading edge of the right wind left an imprint *forward of the wing* that started at the root and extended forward about 8 inches to a foot at the tip. This is consistent with the empennage being "bent" to the left as seen from the rear looking forward. As to the thumb pressure compression it's amazing as the cylinders and a couple of accessories were the only things intact Even the crank case was broken. "The general consensus locally" is the plane was in a flat spin. This caused the tanks to unport and the engine to sputter and quit. How he got into the flat spin is even more conjecture. Again, knowing the plane and pilot the best guess is something broke and he lost it trying to put the gear down. As to the plane itself.. "It's my understanding" that the wing had been changed in cord as well as position to get the CG *within* a useable range. Roll forces were normal. Pitch forces were nonexistent. No breakout force and no gradient. It felt like a game joystick with no springs. It took _very_little stick movement fore and aft for substantial pitch changes. You *positioned* the stick fore and aft for pitch changes. I would put my hand on my knee and roll using my leg. Pitch was a tiny movement between thumb and forefinger. Pitch *appeared* to be neutral. Neither divergent or convergent. You put the nose in a position and it stayed there. It was still *relatively* easy to fly. When I flew it, the plane responded well. Yet there is that tiny tail. As far as I know, and I'm almost certain, the pilot had no aerobatic training, nor had I ever heard of him taking spin training. I sneezed and it took two miles to stop the PIO. That was as much due to my unfamiliarity with the plane as with the ultra sensitive pitch control. I just opened my thumb and forefinger and the PIO stopped. The Gs were moving my leg just enough to cause the stick to move a tiny bit. His aversion to aerobatics came from a botched attempt to do a loop in the Barracuda many years ago when he was a relatively low time pilot. This was also back in the days before a high performance/complex/retract checkout was required.. The result scared him so bad he wanted nothing to do with aerobatics even riding with an experienced pilot after that. Although... the air show pilot surprised him with a roll in the Barracuda when he wasn't expecting it. They described it as IFR *in* the cockpit. (I'm sure that requires no explanation for most) I do know he DID NOT like anything much other than the normal flight regime. I started out with some dutch rolls, but didn't even make it to 60 degrees when he said "that's enough". For all it's lack of control harmony it had very little adverse yawh and as well as it behaved I'd guess it would have easily gone to 90 degrees with a hesitation. (He didn't even want to go back and get chutes to give it a check out) The plane had been test flown by at least one well know aerobatic pilot from the air show circuit. However it was not a full checkout and this particular aircraft had never been spun. I'm not so sure it had ever been stalled with the exception of the aerobatic pilot and I'm not positive he stalled it. To complicate matters the gear down speed was relatively low...about 120 MPH as I recall, but I may be off on that number. However it was slow for a plane that fast and slippery. One note: On a trip to Sun 'n Fun one year, the elevator trim tab broke which resulted in an immediate pitch up to 6Gs even with a very rapid correction from the pilot...who was not the owner. That caused the pilot to decide he really didn't want to keep flying it. I'd not call this particular plane representative of the model, but then again I'd not throw it out either. I'd like to fly a stock model through the whole flight envelope, but definitely while wearing a chute. It was fun to fly, but certainly not for a low time pilot or even one a bit rusty. jack was a great guy who liked to experiment. Some of his experiments worked great and some didn't. How much they may have contributed to the end result is still open to debate. Roger Halstead (K8RI EN73 & ARRL Life Member) www.rogerhalstead.com N833R World's oldest Debonair? (S# CD-2) David O -- http://www.AirplaneZone.com |
