Nice piece on WBAL:
http://www.wbaltv.com/video/14641367/index.html Adding on sport airplane privileges is a snap for rated glider pilots. No formal FAA written or FAA checkride required. |
On Nov 19, 3:04 pm, Helen wrote:
Nice piece on WBAL: http://www.wbaltv.com/video/14641367/index.html Adding on sport airplane privileges is a snap for rated glider pilots. No formal FAA written or FAA checkride required. Yes that's a good presention. thanks for sharing it. I have not closely followed the regs for sport pilots as I already have most of the aiplane ratings I want. Can you please tell me what reg allows private rated glider pilots get a sport airplane rating without a check ride? Andy |
On Nov 20, 6:53 am, Andy wrote:
On Nov 19, 3:04 pm, Helen wrote: Andy, Helen's comments need a little clarification. With only a glider rating one would be able to fly a LSA AIRPLANE (note not aircraft) as if one had a student certificate. There would still be the need for instruction/solo and check ride. I am not sure - this comes from my expert source an instructor - if there is a written. If one has any rating in AIRPLANES then one does not need a checkride just instructor sign off to fly the ship or what ever the insurance requires. One does not need a FAA physical as long as they have a current state issued drivers license. Now here is the kicker. If you have had your FAA physical denied or revoked for any reason you can not fly LSA class but if you have let it laps without the revocation or denial and can certify lyour health ike you do for a glider then have fun. The LSA limitations are - briefly- max weight 1320 lbs, daylight only, max two passenger, max speed 120 kts., max altitude 10,000' (yes there is a LSA glider rating but the 10,000' limitation is still there.) Tom Idaho Nice piece on WBAL: http://www.wbaltv.com/video/14641367/index.html Adding on sport airplane privileges is a snap for rated glider pilots. No formal FAA written or FAA checkride required. Yes that's a good presention. thanks for sharing it. I have not closely followed the regs for sport pilots as I already have most of the aiplane ratings I want. Can you please tell me what reg allows private rated glider pilots get a sport airplane rating without a check ride? Andy |
![]() Sorry Tom, Your "expert" instructor has been wrong before. After you asked I did a bit more research and found the following on the AOPA Sport Pilot FAQ. Do I need to perform a check ride to get an additional category and/or class rating? ************************************************** ************************************************* No, a check ride is not required. Rather, you will need to follow the provisions of 14 CFR 61.321, which requires the following: Receive a logbook endorsement for meeting aeronautical knowledge and flight proficiency requirements. Complete a proficiency check from an authorized instructor other than the instructor who trained you on the aeronautical knowledge and areas of operation specified. Complete an FAA Form 8710-11, Airmen Certificate and/or Rating Application, and present it to the instructor who conducted the proficiency check. Receive a logbook endorsement from the instructor who conducted the proficiency check certifying that you are proficient in the applicable knowledge and areas of operation and that you are authorized for the additional category and class of light sport aircraft. ************************************************** ************************************************ This is also referenced in the Sport Pilot PTS. Since a Glider Pilot already qualifies for Sport Pilot Privileges, It appears to be true that you there is no written or Check ride required to be done by the FAA or a Designee. Instead you take a "proficiency check" administered by a flight instructor. Brian CFIIG/ASEL |
On Nov 20, 10:00 am, Brian wrote:
Do I need to perform a check ride to get an additional category and/or class rating? ************************************************** *************************-************************ No, a check ride is not required. Rather, you will need to follow the provisions of 14 CFR 61.321, which requires the following: The private rated glider pilot does not hold a sport pilot certificate with any category or class so there is no existing (sport pilot) rating for the airplane category to be added to. I remain unconvinced that a private rated glider pilot can add sport airplane privileges without a flight test. Anyone that thinks otherwise please provide a reference to the appropriate regulation rather than an interpretation of someone else's comment. 61.307 defines the requirement and references some exceptions to the requirements. I see nothing that allows a private rated glider pilot to be exempted. Andy |
On Nov 21, 5:59 am, Andy wrote:
61.307 defines the requirement and references some exceptions to the requirements. I see nothing that allows a private rated glider pilot to be exempted. I may have found my own answer. The sport pilot PTS provides this satement: Sport Pilot--Additional Privileges If you hold a Sport Pilot Certificate or higher and seek to operate an additional category or class of light-sport aircraft (14 CFR part 61, section 61.321), you must: 1. receive a logbook endorsement ....... 2. successfully complete a proficiency check from an authorized instructor ...... 3. complete an application for those privileges ....... 4. receive a logbook endorsement from the instructor ....... So the key piece of information may be that a private glider rating is assumed to be a higher rating than sport pilot with airplane category. Anyone done this or know someone that has? How is the certificate worded? Andy |
On Nov 20, 8:07 am, " wrote:
issued drivers license. Now here is the kicker. If you have had your FAA physical denied or revoked for any reason you can not fly LSA class but if you have let it laps without the revocation or denial and can certify lyour health ike you do for a glider then have fun. The LSA limitations are - briefly- max weight 1320 lbs, daylight only, max two passenger, max speed 120 kts., max altitude 10,000' (yes there is a LSA glider rating but the 10,000' limitation is still there.) So if you don't think you can get a medical, but have a driver's license, and feel fit to fly, and want to fly an "airplane", then the touring motorglider is still the better deal. Something like a Diamond Katana Extreme or Stemme S6 will let you fly higher, at night, and possibly faster than you could in a light sport airplane. Ain't regulations fun?! :-) |
In addition to being able to fly above 10,000 ft, motor gliders can also fly
internationally, which I believe is not currently possible with LSA aircraft. In south Florida, if you are interested in flying to the Bahamas (and possibly Cuba after Castro is gone), you are much better off with a motor glider than an LSA aircraft. One HUGE advantage of the higher maximum legal altitude, coupled with the better glide ration of a motor glider, is that you can always be within final glide of land when flying from FL to the Bahamas, whereas with an LSA aircraft, if you have an engine failure at an inopportune moment, you are going to have to ditch. Mike Schumann "5Z" wrote in message ... On Nov 20, 8:07 am, " wrote: issued drivers license. Now here is the kicker. If you have had your FAA physical denied or revoked for any reason you can not fly LSA class but if you have let it laps without the revocation or denial and can certify lyour health ike you do for a glider then have fun. The LSA limitations are - briefly- max weight 1320 lbs, daylight only, max two passenger, max speed 120 kts., max altitude 10,000' (yes there is a LSA glider rating but the 10,000' limitation is still there.) So if you don't think you can get a medical, but have a driver's license, and feel fit to fly, and want to fly an "airplane", then the touring motorglider is still the better deal. Something like a Diamond Katana Extreme or Stemme S6 will let you fly higher, at night, and possibly faster than you could in a light sport airplane. Ain't regulations fun?! :-) -- Posted via a free Usenet account from http://www.teranews.com |
Mike Schumann wrote:
In addition to being able to fly above 10,000 ft, motor gliders can also fly internationally, which I believe is not currently possible with LSA aircraft. I believe that it's the license and not the aircraft. The Sport Pilot license is not recognized internationally and will likely be unusable outside the U.S. Similarly, we have a club member who has the Dutch equivalent of a recreational pilot license. The FAA would not recognize that either and the member would up getting a U.S. private Pilot license. As for the 10,000 ft thing - that's because Sport Pilots are not tested for high altitude operations. I have a page on my club web site (and so excuse the local references, please) that may be of interest - http://home.comcast.net/~verhulst/GB...sportpilot.htm Tony |
Adding a Partner | Jon Kraus | Owning | 6 | September 25th 06 09:59 PM |
Question about adding a second electric AI | M | Owning | 10 | January 4th 05 07:29 PM |
Adding a glideslope to a KX-155 | Brinks | Owning | 2 | October 27th 04 05:18 PM |
Adding new Aircraft to FS2004--why can't I do it? | Twilson | Simulators | 2 | February 19th 04 11:03 PM |
Adding a second CDI/GS | MP | Owning | 4 | December 27th 03 02:10 AM |
