Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
Helicopter trailer
Old November 25th 07, 01:12 AM posted to rec.aviation.rotorcraft
Stuart & Kathryn Fields
Default Helicopter trailer
Is there anyone out there? I have been dissatisfied with my trailer that
I'm using to haul my 1,000 # helicopter around. It is basically a car
hauler that I've stripped the springs down to 1 1/2 leaves and put soft car
tires on it to make the ride a bit softer. Even with the reduced springs, a
4,000 # car didn't bottom out the springs. I also want to be able to fly on
and off the trailer. In the desert this is a big dirt avoider. With the
reduced springs I have had 4 spring failures to date and because it is
always the trailing spring, it has just been a nuisance and hasn't caused
any damage. I've been thinking about designing my own trailer using torsion
bars that is designed just for the helicopter and not a general case utility
trailer.
I had a chance encounter with the president of Kendon Industries. This
company makes ATV and Motorcycle trailers. They are interested in possibly
pursuing a design for a trailer that could be used to haul the helicopters
and provide a soft ride. I'm attaching some of the points to consider in
hopes that someone out there might read this and have some good ideas.
1. Function - land on or load the helicopter in some alternate way? (I'm
biased toward flying on and off with a winch backup)
2. Length - overhang or no overhang? (I want enough overhang for a blade
support structure. I tow with blades installed)
3. Weight capacity - 2,000 lbs? 3,000 lbs? More? (2,000 # limit would
suit me)
4. Accessories - boxes, winches, built in tie down straps and in what
locations, security system, etc? (I can handle this on my own)
5. Purpose - is this best to be a "helicopter-only" trailer, or should it be
appropriate for alternate uses? (I want a trailer designed specifically for
the helicopter)
6. Optimal price?(Less than $4k?)
7. Deck height limitations or preferences? (Accomodate at least a 14" tire)
8. If we could accomplish most of the desired preferences, how likely would
you be to purchase such a trailer? (I want one and will design and build my
own if I can't find an acceptable one)
Other ideas???
Old December 2nd 07, 09:59 PM posted to rec.aviation.rotorcraft
D Peter Maus
trailer.
suit me)
the helicopter)
Other ideas???
Call Ken at Sun Aero Helicopters in Lansing, Illinois. He had one
built for the 206L to haul it to Nascar events. It's fit to the bird,
with supports for the MR blades to prevent flapping in transport, tie
downs, proper suspension, and lift to permit backing up the truck for
hitching.
Ken can fill you in on the structural parameters, and operational
considerations.
My thoughts would be not to do this too cheaply. You've got a
sizeable investment in your aircraft. Cheaping out on the transport
could be your most expensive mistake.
Old December 3rd 07, 04:27 PM posted to rec.aviation.rotorcraft
Peter: Thanks for the contact. I am sure not going to cheap out on the
trailer. I've got way too much time and money invested in the helicopter
and for sure don't want it wrecked due to a pitiful trailer.
Thanks again for the contact.
"D Peter Maus" wrote in message
car tires on it to make the ride a bit softer. Even with the reduced
springs, a 4,000 # car didn't bottom out the springs. I also want to be
able to fly on and off the trailer. In the desert this is a big dirt
avoider. With the reduced springs I have had 4 spring failures to date
and because it is always the trailing spring, it has just been a nuisance
and hasn't caused any damage. I've been thinking about designing my own
trailer using torsion bars that is designed just for the helicopter and
not a general case utility trailer.
possibly pursuing a design for a trailer that could be used to haul the
helicopters and provide a soft ride. I'm attaching some of the points to
consider in hopes that someone out there might read this and have some
good ideas.
suit me)
be appropriate for alternate uses? (I want a trailer designed
specifically for the helicopter)
tire)
would you be to purchase such a trailer? (I want one and will design and
build my own if I can't find an acceptable one)
Other ideas???
Call Ken at Sun Aero Helicopters in Lansing, Illinois. He had one built
for the 206L to haul it to Nascar events. It's fit to the bird, with
supports for the MR blades to prevent flapping in transport, tie downs,
proper suspension, and lift to permit backing up the truck for hitching.
considerations.
My thoughts would be not to do this too cheaply. You've got a sizeable
investment in your aircraft. Cheaping out on the transport could be your
Old November 26th 07, 08:35 PM posted to rec.aviation.rotorcraft
Maxwell
"The OTHER Kevin in San Diego" skiddz "AT" adelphia "DOT" net wrote in
message news
On Sat, 24 Nov 2007 17:12:11 -0800, "Stuart & Kathryn Fields"
Perhaps something akin to how off road cars/trucks are built, i.e. low
spring rates, high rates of damping.
I'm envisioning something using coil overs, but those tend to be
pretty long so the trailer might sit higher than you'd like.
Maybe use torsion bars instead of traditional springs? I know a lot
of race car trailers use this setup - as do we with our sims in a
trailer - with good result.
Perhaps the folks at Carson Trailer (They're in L.A.) can help with
some basics for a "roll your own" rig...
Maybe heavy trailer frame and light springs. Perhaps springs designed for
less weight, like a boat trailer. I have seen former boat trailers used to
haul ultralights with good results.
I always thought a boat trailer with a telescoping tongue might be good for
a rotor craft. Chock the wheels, pull a pin, and pull forward. You could
park your RV almost a full trailer length away, and never disconnect the
trailer.
Old November 26th 07, 11:02 PM posted to rec.aviation.rotorcraft
Maxwell that is the first time I've heard that idea and it is sure going
into my stew pot. With the trailer length that I'm thinking about being as
long as the helicopter from tailboom to blade tip, it would have room for a
very long telescoping tongue.
Thanks...Stu
"Maxwell" wrote in message
message news
for a rotor craft. Chock the wheels, pull a pin, and pull forward. You
could park your RV almost a full trailer length away, and never disconnect
the trailer.
Old November 26th 07, 11:41 PM posted to rec.aviation.rotorcraft
Maxwell
"Stuart & Kathryn Fields" wrote in message
as long as the helicopter from tailboom to blade tip, it would have room
for a very long telescoping tongue.
Thanks...Stu
Glad to help. I hope to employ the feature myself someday.
MINI 500, Rinke, Turbine, Helicopter for sale, Helicopter, Revolution, Turbine Power TurbineMini Richard Rotorcraft 2 January 28th 09 07:50 PM
aero-domains for helicopter pilots and helicopter companies secura Rotorcraft 0 June 26th 04 07:33 AM
Helicopter Trailer John P. Kelly Rotorcraft 2 April 3rd 04 04:14 AM
JAG Helicopter Video, Rinke Aerospace, Spy Photos, JAG Helicopter, Helicopter, Black Ops Dennis Chitwood Rotorcraft 4 January 10th 04 05:34 PM
