From Europe:
________________________________________________ "On Sun, November 25, 2007 9:31 am, peternarinx wrote: Yesterday, on the airfield of Weelde ( EBWE) in Belgium, Peter Mink reached 1718m AGL with an ASK21 and a Mel winch." "The length of the runway is 3100m including the grass at both ends and the winch is on the ground. You can see the airfield on google earth 51 23 48 N , 04 37 77 E. They said that the conditions were not optimal yesterday......." _________________________________________________ 1718 meters is 5,636 feet AGL. The runway length is 3100 meters or 10,170 feet. With the new light weight UHMWPE winch rope and a modern high performance winch, great heights can be achieved. Bill Daniels |
A typical winch launch yeilds about 1/3 of the runway/field available, this is a fantastic result, Bill!
Perhaps we should be measuring the launch as a percentage of field length, then there would actually be a record available for everyone to shoot for, regardless of locality. So... With a runway of 3100m and a launch of 1718, the current known record is 55.42% Get out there and break it!! bagger |
George Moore of Spokane, WA has developed some very convincing math that
says 50% of the initial rope length should be possible as release height under no wind conditions. As you go to longer ropes, the percentage used for ground roll and rotation into the climb becomes less and as you get higher, you may encounter higher headwinds which also adds to release height. I would expect higher percentages simply due to longer ropes. All this depends on several things. Using Spectra or Dyneema rope which is 10 - 12% the weight of steel cable for a given strength, using adequate power to maintain a rope tension of 1 to 1.5 x glider weight and managing that tension precisely with a computer. In this case, they used an ASK-21 which specifies a black 2200 pounds-force weak link. This allows a lot of power to be transfered to the glider. Apparently it was flown solo which means a tension factor of ~1.5 x weight was possible. All very technical, of course. Where it's a game changer is training, particularly glider aerobatic training. An aero tow to 1700 meters is way over 100 Euro. The winch launch was probably less than 10 Euro. I like to think of quietly lobbing an instructor with a pre-solo student up over a vertical mile at 6AM for 40 minutes of instruction in glassy smooth air. Bill Daniels "bagmaker" wrote in message ... A typical winch launch yeilds about 1/3 of the runway/field available, this is a fantastic result, Bill! Perhaps we should be measuring the launch as a percentage of field length, then there would actually be a record available for everyone to shoot for, regardless of locality. So... With a runway of 3100m and a launch of 1718, the current known record is 55.42% Get out there and break it!! bagger -- bagmaker |
over a vertical mile at 6AM for 40 minutes of instruction in glassy smooth air. This is slightly OT, but... is there an optimal launch height at each stage of training? For example, a few really high launches at the very beginning (so that the student has time to practice things like speed control and turns), and then a lot of standard (~1500ft) launches (circuit planning and landing)? Bartek |
![]() "brtlmj" wrote in message ... I like to think of quietly lobbing an instructor with a pre-solo student up over a vertical mile at 6AM for 40 minutes of instruction in glassy smooth air. This is slightly OT, but... is there an optimal launch height at each stage of training? For example, a few really high launches at the very beginning (so that the student has time to practice things like speed control and turns), and then a lot of standard (~1500ft) launches (circuit planning and landing)? Bartek Of course. Early trainees gets high launches until they can fly the glider reasonably well and then a lot of low launches for landings and launch failure training. For low launches, 1500 feet or less, a retrieve winch can be used to get the rope back for another launch achiving a launch every 2 minutes or so. It would be great to have both capabilities. Bill D |
On Nov 26, 10:37 am, "Bill Daniels" bildan@comcast-dot-net wrote:
It would be great to have both capabilities. ....and that would probably require two winches. Even though one could release at 1500ft when being launched by a 4000ft-capable winch, it would probably be pointless. But then, would it be possible to operate two winches safely? Bartek |
On Sun, 25 Nov 2007 21:27:23 +0000, bagmaker
wrote: With a runway of 3100m and a launch of 1718, the current known record is 55.42% I can offer 63.8% (Ka-8b, 670 m height on a 1050 m standard steel cable). Bye Andreas |
You would also need to make an adjustment for headwinds to make it really
fair. Mike Schumann "bagmaker" wrote in message ... A typical winch launch yeilds about 1/3 of the runway/field available, this is a fantastic result, Bill! Perhaps we should be measuring the launch as a percentage of field length, then there would actually be a record available for everyone to shoot for, regardless of locality. So... With a runway of 3100m and a launch of 1718, the current known record is 55.42% Get out there and break it!! bagger -- bagmaker -- Posted via a free Usenet account from http://www.teranews.com |
![]() "bagmaker" schrieb im Newsbeitrag ... A typical winch launch yeilds about 1/3 of the runway/field available, this is a fantastic result, Bill! Perhaps we should be measuring the launch as a percentage of field length, then there would actually be a record available for everyone to shoot for, regardless of locality. So... With a runway of 3100m and a launch of 1718, the current known record is 55.42% Get out there and break it!! 950m steel cable + 350hp winch + 20km/h wind + ASK21 = 750m or 78%. More high was possible, but airspace class C begins at 750m above our airfield so I had to release the cable. I think the ASK21 gets the best high on winchlaunch. Our DG1000 always gets 25% less high. Greetings, Sönke |
On Nov 28, 6:22 pm, "Sönke Gutzlaff" wrote:
950m steel cable + 350hp winch + 20km/h wind + ASK21 = 750m or 78%. More high was possible, but airspace class C begins at 750m above our airfield so I had to release the cable. I think the ASK21 gets the best high on winchlaunch. Our DG1000 always gets 25% less high. Greetings, Sönke Sönke, what speed do you fly at on the winch, and how much back pressure do you apply to the stick? Dan |
How to get maximum height on a winch launch? | Dan G | Soaring | 38 | December 22nd 16 12:29 AM |
Winch launch speed versus height gain | Neil | Soaring | 20 | November 9th 07 12:57 AM |
Record Highs/Record Lows | Jay Honeck | Piloting | 12 | October 12th 06 01:27 AM |
Perlan height record in Argentina | Charles Yeates | Soaring | 3 | September 1st 06 12:59 PM |
LIppmann reports a 950 meter winch launch with their Dynatec winch line - anything higher? | Bill Daniels | Soaring | 20 | December 27th 04 12:33 AM |
