See You How To?
Old November 26th 07, 02:19 PM posted to rec.aviation.soaring
Roy Bourgeois
Default See You How To?
In See You - how does one capture a page (for example a task/map) so =
that it can be copied and emailed or linked to for someone without See =
You? Or - how to make a See You page a PDF or a jpeg file for the same =
purpose?
Roy
Old November 26th 07, 02:37 PM posted to rec.aviation.soaring
Ann O'Rack[_2_]
Use ALt-print. I.e. hold down the alt key whilst pressing
the Print key. This will copy the active window to
the clipboard. Open up a receiving application e.g.
Paint, Word, new (rich text or HTML) email in Outlook
etc. and press ctrl-V (hold control while pressing
v) to paste output.
a task/map) so =
file for the same =
purpose?
Roy
Old November 26th 07, 04:20 PM posted to rec.aviation.soaring
2cernauta2
v) to paste output.
Or, if your keyboard doesn't have the Print key, use a simple "Screen
Capture" program like for example Bilderman
http://www.burrrn.net/?page_id=39
It will save a jpg file to a directory of your choice, anytime you
press Ctrl+F11
Aldo Cernezzi
Old November 26th 07, 02:49 PM posted to rec.aviation.soaring
"Roy Bourgeois" wrote in message
purpose?
Roy
If I understand the question correctly then the solution is:
Click on file; click on "save as"; name the file; change the format from IGC
to JPG (or whatever); select the desired directory; and, finally click on
"Save."
HP-14 "6F"
http://www.soaridaho.com/
Old November 26th 07, 04:18 PM posted to rec.aviation.soaring
Andrej Kolar
There is several ways:
1.
that it can be copied and emailed or linked to for someone without See You?
This is one way to capture a picture of your flight. There are a few
limitations. It will always save the Route view of the whole flight.
It will be saved as a JPG file on your disk (you get to choose the
location and size of the image). You can't save 3D, graphs or
statistics through this feature.
2.
purpose?
Saving to PDF is not a SeeYou native feature for a good reason. There
are several free and very capable software which can do the PDF output
for you. I personally use www.cutePDF.com. It installes as a printer.
To use it in SeeYou you go to File Print (or File Page setup or
File Print Preview if you wish to make modifications). When you wish
to print, select "CutePDF Writer" as your printer. The output will go
to a PDF file on your disk rather than paper.
Direct link:
http://www.cutepdf.com/Products/CutePDF/writer.asp
3.
"Save."
This is the third option. It's got nothing to do with SeeYou - it's a
built in Windows featu
1. Press PrtScr key on the keyboard (seemingly nothing had happened)
2. Open Word or a any graphics software
3. Select Edit-Paste (you should now see the screenshot you took in
#1)
4. Save what you have just done
5. Send this file by email
Regards,
Andrej Kolar
glider pilots use
http://www.SeeYou.si/
Old November 27th 07, 11:46 AM posted to rec.aviation.soaring
MaD
On 26 Nov., 15:19, Roy Bourgeois
purpose?
Roy
Hi
Roughly related subject:
Has anyone tried any of these he
http://all-streaming-media.com/recor...e-software.htm
to make a movie from SeeYou? For expl. to be run within a Power-Point
presentation?
Regards
Marcel
Old November 27th 07, 12:33 PM posted to rec.aviation.soaring
Scott[_1_]
Scrren shot capture on a PC (no idea on Mac) is ctrl-print scrn. Hold
both keys down at same time. Print Scrn is usually at top of keyboard
to the right of all the function keys. It works for static screen
display...not sure it will capture a video frame or whatever. Once you
do this, just use paste on a Word document (or probably any other
program that has a paste function. No guarantee, but give this a try...
Scott
purpose?
Roy
Hi
presentation?
Regards
Marcel
Scott
http://corbenflyer.tripod.com/
Gotta Fly or Gonna Die
Building RV-4 (Super Slow Build Version)
