Maintenance
Old November 27th 07, 12:02 AM posted to rec.aviation.soaring
Steve Freeman
Default Maintenance
I am new to glider ownership an am about to disassemble the interior
to get to all the cables etc. for inspection and lubrication. Any
advice on what is the best lubricant to use for cables etc.?
Old November 27th 07, 09:25 AM posted to rec.aviation.soaring
Bert Willing[_2_]
Default Maintenance
Yes. You don't lubricate cables in the first place.
Bert
"Steve Freeman" wrote in message
Old November 27th 07, 01:39 PM posted to rec.aviation.soaring
Andy[_1_]
Default Maintenance
On Nov 27, 1:25 am, "Bert Willing" bw_no_spam_ple...@tango-
Interesting!. Why not? I use LPS2 to lubricate the rudder cable runs
on my ASW-28 and did the same on my ASW-19b.
Andy
Old November 27th 07, 02:19 PM posted to rec.aviation.soaring
Bert Willing[_2_]
Default Maintenance
Why would you do that ?
In places where the cable runs along a pulley, there is no friction.
In places where the cable runs in teflon hoses, lubrication will attract
dust, and make the cable more abrasive.
Same goes with the roller guides of control tubes. If you lubricate them,
they'll attract dust and you will end up with intends in the tube.
"Andy" wrote in message
Andy
Old November 27th 07, 10:34 PM posted to rec.aviation.soaring
Eric Greenwell
Default Maintenance
I never lubricated the rudder cables on my ASW 20 (I flew it for 11
years), and I've never lubricated the cables on my ASH 26 E (13 years so
far). The maintenance manuals on these gliders did not call for
lubrication of the cables, nor did the friction increase while I owned
the gliders, and there was never any corrosion. So, without a problem to
cure, I never tried to fix one.
Did you have a problem that required a cure?
* "Transponders in Sailplanes" http://tinyurl.com/y739x4
Old November 27th 07, 06:21 PM posted to rec.aviation.soaring
bumper
Default Maintenance
Bert,
I beg to disagree. When wire rope or cables flex over a pulley or sheave,
the strands rub against one another. Some larger cables are lubricated as
part of the manufacturing process. I think the smaller aircraft cable we're
talking about is not.
Lubricating the cables, where they flex or rub, will greatly enhance their
service life. A good penetrating lubricant, one with a carrier that
evaporates, is best (Tri-Flow or Super Lube spray come to mind).
bumper
zz
Minden
"Bert Willing" wrote in message
Bert
Old November 28th 07, 12:17 AM posted to rec.aviation.soaring
Bob Kuykendall
Default Maintenance
On Nov 27, 12:25 am, "Bert Willing" bw_no_spam_ple...@tango-
If you're like me, you remember reading that advice in an old copy of
AC43.13, complete with references to long-obsolete lubricants like
"Par-L-Ketone." From memory, 43.13 said to not oil cables because
lubricants thin enough to get to the cable core will just displace the
factory lubricant and make them more, not less, susceptible to
internal friction and internal corrosion.
However, in the 1998 edition of AC43.13, Chapter 7 seems to have been
revamped, and makes several reasonable recommendations about
inspecting and lubing cables and what to lube them with (MIL-C-16173,
grade 4, or MIL-C-11796, Class I, if you can find them). It also
describes nylon-jacketed cables, which I believe is a newish
development.
My own recommendation would be to avoid thinned oils like tri-flow for
unsheathed cables. As much as I like Tri-Flow as a general lubricant,
it tends to leave a sticky surface, and its solvents might tend to
wash away more of the internal lubricant than it applies. Those waxy
dry lubricants now available for bicycles might be a good bet, since
they tend to leave a dry, tack-free surface that does not attract
abrasive particles. I use that stuff on the cables and pivots of my
climbing gear, and it seems to work a treat.
Thanks, Bob K.
Old November 29th 07, 08:41 PM posted to rec.aviation.soaring
Doug Hoffman
Default Maintenance
The following relates the actual experience an HP-14 owner had
with lubricants and dirt. Source is Wayne Paul's HP web site. It
supports Bob Kuykendall's assertion that careful selection of
lubricant is important, if one chooses to lubricate at all.
"I have had to replace all of the cables, the previous owner had
greased them at the fairleads, and they picked up dirt and got
badly worn very fast. I also replaced the aileron pushrods, as
they also had been greased at the guides, and ended up with wear
marks. "
Regards,
Doug
Posted via a free Usenet account from http://www.teranews.com
Old November 29th 07, 04:08 PM posted to rec.aviation.soaring
Default Maintenance
"Doug Hoffman" wrote in message
marks. "
At the time of cable/push-rod replacement, the HP-14 was 27 years old;
however, only had 167 hours of flight time. I thought I had purchased an
inexpensive sailplane, but in fact I had purchased a cheap sailplane.
(http://www.soaridaho.com/Schreder/HP-14/N990/N990.html)
HP-14 "6F"
SZD55 Maintenance icsonka Soaring 6 October 13th 06 06:13 AM
Maintenance and Insurance AceHyflyer Owning 12 July 27th 06 06:01 AM
What do you do about maintenance? Andrew Gideon Owning 5 July 2nd 06 05:00 PM
Maintenance Personel Charles Talleyrand Naval Aviation 6 August 6th 03 12:35 AM
B-25 Maintenance Randy Military Aviation 1 July 11th 03 04:37 AM
