Belly Landing
Old November 25th 03, 03:09 PM
Emilio
Default Belly Landing
Take a look at this 737 belly landing video clips.
http://radioscanning.wox.org/Scanner...o/737gear.mpeg
On a first sequence it appears the pilot is trying to get the gear unjammed
by bouncing the aircraft on the good landing gear. The second sequence
shows the actual landing. But I am little puzzled by the fact that when he
touches down the aircraft attitude is quite flat like in the normal
touchdown. Isn't it better to touch down at minimum flying speed with nose
up and about to stall?
Emilio.
Old November 25th 03, 03:38 PM
Tex Houston
"Emilio" wrote in message
unjammed
he
nose
Emilio.
Having only dialup I did not look at the clip but was it a military 737?
Old November 25th 03, 04:56 PM
I don't think so Tex, bit hard to tell but looks commercial to
me.
-Gord.
Old November 25th 03, 04:44 PM
Rick
It is always better to fly the aircraft under full control at the speed
determined by load and conditions. Trying to fly at stickshaker speed in
order to reduce damage to the aircraft is far more dangerous.
Rick
Old November 25th 03, 06:24 PM
Rick
ArtKramr wrote:
Or to look at it from another point of view, when in doubt get out.
Not an option on a 737 until it is stopped.
Rick
Old November 25th 03, 05:51 PM
Darrell
I wouldn't think it would be a good idea to slow to minimum landing speed.
The tail would drag first and slam-flop the airplane onto the runway and
might break it in half. Although a flat touchdown would require a higher
landing speed it would probably produce less overall damage as long as that
extra speed didn't cause it to leave the runway surface.
B-58 Hustler History: http://members.cox.net/dschmidt1/
unjammed
he
nose
Emilio.
Dudley Henriques
unjammed
he
nose
Emilio.
No, especially in large aircraft like this one. It's far better to lay it
down with positive control at some median airspeed that produces this
control than trying to slow it down to an absolute minimum airspeed. The key
phrase in emergency landings is "positive control". In almost every case,
this area of positive control will occur at an airspeed that is producing an
angle of attack less than that encountered with the touchdown attitude
you're describing.
Each type of aircraft has a recommended procedure covering this situation.
Some are different than others, but the actual flight parameters are spelled
out for the type involved in either the POH, the dash 1, or the Natops, as
the situation dictates.
Dudley Henriques
International Fighter Pilots Fellowship
Commercial Pilot/ CFI Retired
For personal email, please replace
the z's with e's.
dhenriquesATzarthlinkDOTnzt
Old November 25th 03, 10:22 PM
Jim Baker
unjammed
he
nose
Emilio.
In these situations Emilio, you always want to fly the aircraft nose down to
the ground. Never want it to drop because even a two or three foot drop
will most likely severely damage the aircraft. B-1B landed at Edwards in
the late 80's with the nose gear up and, with no practice for this manuever,
the pilot let it fall about two feet onto the nose. Lots of damage. He had
the idea to fly it down, but without any reference picture or practice, it
fell the last two feet.
"bush flying" in the suburbs? [email protected] Home Built 85 December 28th 04 11:04 PM
Diamond DA-40 with G-1000 pirep C J Campbell Instrument Flight Rules 117 July 22nd 04 05:40 PM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Home Built 0 February 19th 04 06:51 PM
Cessna Steel Landing Gears, J-3 Seat Sling For Auction Bill Berle Aviation Marketplace 0 February 19th 04 06:51 PM
Off topic - Landing of a B-17 Ghost Home Built 2 October 28th 03 04:35 PM
