Hello,
What are peoples opinions regarding towing a Russia AC4C with an aluminum skinned trailer with a VW diesel beetle? The diesel engine has plenty of torque. I have have towed my boat which is 1200 lbs with the trailer and I have not had any problems. I would be towing quite far on the highways. Thanks |
On Dec 1, 5:33 pm, wrote:
Hello, What are peoples opinions regarding towing a Russia AC4C with an aluminum skinned trailer with a VW diesel beetle? The diesel engine has plenty of torque. I have have towed my boat which is 1200 lbs with the trailer and I have not had any problems. I would be towing quite far on the highways. Thanks - I towed an ASW19 with Seat Toledo 1.9TDi - same engine, heavier car; with speeds up to 140KMH/85 MPH with absolutely no problems. Fuel consumption goes up significantly, that's all. Cheers GK N19JE |
"GK" wrote
What are peoples opinions regarding towing a Russia AC4C with an aluminum skinned trailer with a VW diesel beetle? I know of someone who tows a LAK-12 with a 80's vintage diesel Rabbit (Golf). Bill -- Posted via NewsDemon.com - Premium Uncensored Newsgroup Service -------http://www.NewsDemon.com------ Unlimited Access, Anonymous Accounts, Uncensored Broadband Access |
On Dec 1, 6:33 pm, wrote:
Hello, What are peoples opinions regarding towing a Russia AC4C with an aluminum skinned trailer with a VW diesel beetle? The diesel engine has plenty of torque. I have have towed my boat which is 1200 lbs with the trailer and I have not had any problems. I would be towing quite far on the highways. Thanks Hello gn, I don't know about the New Beetle (my first car was a 1963 Beetle), but I'll let you know an opinion. I've found out the expensive way that no matter if the car has ample towing power, it doesn't help if there's not enough steel in the rear to attach the hitch to. What is the Beetle rated to tow? You say you've towed your 1,200 lb boat/trailer. Do you know how much your Russia and trailer weighs? I know how much my trailer/glider combo weighs because I took it to a truck scale and weighed it. That service cost only US $8.00. Turned out to be A LOT heavier than I anticipated. How about 2,040 lbs? I was first guessing 1,200 lbs. Then, maybe 1,700 lbs. But the scales showed 2,040 lbs! Holy Beer Belly! So, my suggestion: 1. Weigh your rig 2. Consult your car's info on towing capacity 3. Look at the hitch and how it attaches to the car. Does it attach to some "substantial" steel? (That's hard to come by on some cars these days...) 4. If it is automatic transmission, consider installing a transmission oil cooler. If VW doesn't offer one, try going to a local transmission shop and see if they can find something that will work. 5. If the Beetle doesn't look like it's gonna work, then you might have to do as I just did a couple of weeks ago: Buy a replacement vehicle. I just got a Subaru Forester to replace the Honda Accord. It's only a four cylinder of 165 h.p. vs. the 200 h.p. in the V6 Accord. But Subaru rates it to tow 2,400 lbs while the Honda is rated to tow only 1,000 lbs. And there's really not a good way to attach a hitch on the Accord to handle the 180 lbs of tongue weight and 2,040 lbs of trailer. The Honda is for sale... |
On Dec 1, 8:04 pm, rlovinggood wrote:
On Dec 1, 6:33 pm, wrote: Hello, What are peoples opinions regarding towing a Russia AC4C with an aluminum skinned trailer with a VW diesel beetle? The diesel engine has plenty of torque. I have have towed my boat which is 1200 lbs with the trailer and I have not had any problems. I would be towing quite far on the highways. Thanks Hello gn, I don't know about the New Beetle (my first car was a 1963 Beetle), but I'll let you know an opinion. I've found out the expensive way that no matter if the car has ample towing power, it doesn't help if there's not enough steel in the rear to attach the hitch to. What is the Beetle rated to tow? You say you've towed your 1,200 lb boat/trailer. Do you know how much your Russia and trailer weighs? I know how much my trailer/glider combo weighs because I took it to a truck scale and weighed it. That service cost only US $8.00. Turned out to be A LOT heavier than I anticipated. How about 2,040 lbs? I was first guessing 1,200 lbs. Then, maybe 1,700 lbs. But the scales showed 2,040 lbs! Holy Beer Belly! So, my suggestion: 1. Weigh your rig 2. Consult your car's info on towing capacity 3. Look at the hitch and how it attaches to the car. Does it attach to some "substantial" steel? (That's hard to come by on some cars these days...) 4. If it is automatic transmission, consider installing a transmission oil cooler. If VW doesn't offer one, try going to a local transmission shop and see if they can find something that will work. 5. If the Beetle doesn't look like it's gonna work, then you might have to do as I just did a couple of weeks ago: Buy a replacement vehicle. I just got a Subaru Forester to replace the Honda Accord. It's only a four cylinder of 165 h.p. vs. the 200 h.p. in the V6 Accord. But Subaru rates it to tow 2,400 lbs while the Honda is rated to tow only 1,000 lbs. And there's really not a good way to attach a hitch on the Accord to handle the 180 lbs of tongue weight and 2,040 lbs of trailer. The Honda is for sale... Well, I know that the trailer built by the guy in Montana had No problems from there to Calif with a 40 mph crosswind in Nevada and an Explorer. The original trailer was very well balenced and towed very well. Stable and no problem in crosswinds at all. VW might be case of tail wagging dog though. YMMV larry |
Try a search. There's been a few hundred posts on this issue this
year, with some good info contained within. Dan |
I tow a 1,300 lb (590 lbs Austria, 610 lbs tube) trailer with a 2006
Jetta TDI. Due to the chord of the wing - 48" - the trailer has a 53"diameter, so a lot of frontal load. Tow capacity is 2,000 lbs, they recommend trailer brakes for over 1,000 lbs (my trailer has hydraulic surge brakes). I have no problems towing or stopping (braking is as important as the torque for getting going. I have a 5 speed manual transmission; I've read on the TDI club (http:// www.tdiclub.com/) that the automatic transmission might be a problem, for the Jetta anyway. There is a TDI Beetle forum on the site previously mentioned, where I'm betting there is a lot of info on hitches, towing generally... there sure was for the Jetta TDI on there. I bought a hitch and electrics for towing based on the recommendations there. Dan |
On Dec 2, 12:11 pm, Dan wrote:
I tow a 1,300 lb (590 lbs Austria, 610 lbs tube) trailer with a 2006 Jetta TDI. Due to the chord of the wing - 48" - the trailer has a 53"diameter, so a lot of frontal load. Tow capacity is 2,000 lbs, they recommend trailer brakes for over 1,000 lbs (my trailer has hydraulic surge brakes). I have no problems towing or stopping (braking is as important as the torque for getting going. I have a 5 speed manual transmission; I've read on the TDI club (http://www.tdiclub.com/) that the automatic transmission might be a problem, for the Jetta anyway. There is a TDI Beetle forum on the site previously mentioned, where I'm betting there is a lot of info on hitches, towing generally... there sure was for the Jetta TDI on there. I bought a hitch and electrics for towing based on the recommendations there. Dan And the other 100 lbs is wing stands, cleaning stuff, etc... |
On Dec 2, 12:12 pm, Dan wrote:
On Dec 2, 12:11 pm, Dan wrote: I tow a 1,300 lb (590 lbs Austria, 610 lbs tube) trailer with a 2006 Jetta TDI. Due to the chord of the wing - 48" - the trailer has a 53"diameter, so a lot of frontal load. Tow capacity is 2,000 lbs, they recommend trailer brakes for over 1,000 lbs (my trailer has hydraulic surge brakes). I have no problems towing or stopping (braking is as important as the torque for getting going. I have a 5 speed manual transmission; I've read on the TDI club (http://www.tdiclub.com/) that the automatic transmission might be a problem, for the Jetta anyway. There is a TDI Beetle forum on the site previously mentioned, where I'm betting there is a lot of info on hitches, towing generally... there sure was for the Jetta TDI on there. I bought a hitch and electrics for towing based on the recommendations there. Dan And the other 100 lbs is wing stands, cleaning stuff, etc... Hmmm a thread about the optimal tow vehicle and only 8 replies over a few days? this should be up to at least 50 or 100 by now |
... ... Hmmm a thread about the optimal tow vehicle and only 8 replies over a few days? this should be up to at least 50 or 100 by now Would it help if I claim that you need one of these to tow with? http://69.20.127.42/StaticFiles/internationalTrucks/Documents/Truck%20Detail/INT_103_RXT_SellSheet_Back_v5.pdf It does have a diesel like the OP wanted... :-) Just kidding. Really. -- Geoff The Sea Hawk at Wow Way d0t Com remove spaces and make the obvious substitutions to reply by mail When immigration is outlawed, only outlaws will immigrate. |
| Towing to the airport | [email protected] | Home Built | 32 | September 3rd 06 04:47 AM |
| banner towing | Emily | Piloting | 9 | July 8th 06 03:42 AM |
| Towing | Roger Fowler | Soaring | 6 | August 11th 05 05:25 AM |
| FAA says towing ULV's is OK? | ken ward | Soaring | 4 | September 30th 04 04:12 AM |
| Towing with a Segway | Liam Finley | Soaring | 3 | February 23rd 04 07:32 PM |
