I threw out the Wiki on Dudley Henriques to MX on r.a.s. and then read this:
"During the early sixties, flying a Mustang, he patented a three point reverse roll to knife-edge tactical pitch-out approach that became a trademark manoeuvre." http://en.wikipedia.org/wiki/Dudley_Henriques Well, that flew right over -my- head! There doesn't seem to be video or some other internet source demonstrating this that I can find. (but boy is it fun looking!) Can I ask what a "reverse roll" is? (or a "tactical pitch-out approach") Thanks! -Chris Gattman Portland |
"gatt" wrote in message ... I threw out the Wiki on Dudley Henriques to MX on r.a.s. and then read this: "During the early sixties, flying a Mustang, he patented a three point reverse roll to knife-edge tactical pitch-out approach that became a trademark manoeuvre." http://en.wikipedia.org/wiki/Dudley_Henriques Well, that flew right over -my- head! There doesn't seem to be video or some other internet source demonstrating this that I can find. (but boy is it fun looking!) Can I ask what a "reverse roll" is? (or a "tactical pitch-out approach") Thanks! -Chris Gattman Portland In a tactical pitch out is that the airplane is flying an upwind leg, which is parallel to the active runway. Then, to enter a left traffic pattern, the airplane rolls into a left hand 180 degree turn, placing it on the downwind leg. This is the pitch out. It serves the purpose of bleeding airspeed and can be used to extend spacing between a formation of aircraft. The way you describe it, instead of rolling 90 degrees left into a bank, the airplane rolls 270 degrees the opposite way (right), which puts the airplane in the exact same orientation as if the airplane made a 90 degree left bank. Then the airplane does the same 180 degree turn (pitch out) into the downwind leg. The maneuver sounds like a nice bit of flair to use in finishing off a solo airshow routine. KB |
"Kyle Boatright" wrote in message ... The way you describe it, instead of rolling 90 degrees left into a bank, the airplane rolls 270 degrees the opposite way (right), which puts the airplane in the exact same orientation as if the airplane made a 90 degree left bank. Then the airplane does the same 180 degree turn (pitch out) into the downwind leg. The maneuver sounds like a nice bit of flair to use in finishing off a solo airshow routine. Thanks. The next time I'm flying a P-51, I'm gonna try that. *looks around* -c |
reverse roll to knife-edge tactical pitch-out approach that became a trademark manoeuvre." http://en.wikipedia.org/wiki/Dudley_Henriques Maneuvers are patentable??? I would think that's going a little too far. Jose -- You can choose whom to befriend, but you cannot choose whom to love. for Email, make the obvious change in the address. |
Jose schrieb:
Maneuvers are patentable??? You can license the take off roll from me, if you wish. |
Jose wrote:
"During the early sixties, flying a Mustang, he patented a three point reverse roll to knife-edge tactical pitch-out approach that became a trademark manoeuvre." http://en.wikipedia.org/wiki/Dudley_Henriques Maneuvers are patentable??? I would think that's going a little too far. Jose I believe the term was simply meant to imply that at the time, no one else apparently was doing a flash pitchout in quite the same manner. No big deal at all. -- Dudley Henriques |
gatt wrote:
I threw out the Wiki on Dudley Henriques to MX on r.a.s. and then read this: "During the early sixties, flying a Mustang, he patented a three point reverse roll to knife-edge tactical pitch-out approach that became a trademark manoeuvre." http://en.wikipedia.org/wiki/Dudley_Henriques Well, that flew right over -my- head! There doesn't seem to be video or some other internet source demonstrating this that I can find. (but boy is it fun looking!) Can I ask what a "reverse roll" is? (or a "tactical pitch-out approach") Thanks! -Chris Gattman Portland Kyle has it exactly right. Reverse roll simply meant the pitch out was away from the intended downwind low off the initial; a 270 degree point 3 roll stopping the third point with hard top rudder and a transition to back pressure onto the downwind. A "tactical pitch out" as opposed to a normal pitch out off the initial puts the airplane coming in low off the deck at a much higher airspeed at the pitch point than the normal pitch out, which is performed near pattern speed at the downwind altitude. The tactical pitch out is a fan break off the deck pulling up and into the downwind. Both approaches use the break and pull into drag rise to slow the aircraft to dirty configuration airspeed. -- Dudley Henriques |
"Dudley Henriques" wrote in message ... Kyle has it exactly right. Reverse roll simply meant the pitch out was away from the intended downwind low off the initial; a 270 degree point 3 roll stopping the third point with hard top rudder and a transition to back pressure onto the downwind. A "tactical pitch out" as opposed to a normal pitch out off the initial puts the airplane coming in low off the deck at a much higher airspeed at the pitch point than the normal pitch out, which is performed near pattern speed at the downwind altitude. The tactical pitch out is a fan break off the deck pulling up and into the downwind. Both approaches use the break and pull into drag rise to slow the aircraft to dirty configuration airspeed. Okay. Well, I'd be lying if I said I could -fully- visualize it just yet, and my wife is going to want to know why I'm playing with a toy plane all of a sudden (a Revell Spitfire MkIX will have to substitute for a Mustang) when I have more time to try to figure it out tonight, but I think I get the idea. Thanks to both of you for replying. -Chris |
"Dudley Henriques" wrote in message ... gatt wrote: I threw out the Wiki on Dudley Henriques to MX on r.a.s. and then read this: "During the early sixties, flying a Mustang, he patented a three point reverse roll to knife-edge tactical pitch-out approach that became a trademark manoeuvre." http://en.wikipedia.org/wiki/Dudley_Henriques Well, that flew right over -my- head! There doesn't seem to be video or some other internet source demonstrating this that I can find. (but boy is it fun looking!) Can I ask what a "reverse roll" is? (or a "tactical pitch-out approach") Thanks! -Chris Gattman Portland Kyle has it exactly right. Reverse roll simply meant the pitch out was away from the intended downwind low off the initial; a 270 degree point 3 roll stopping the third point with hard top rudder and a transition to back pressure onto the downwind. A "tactical pitch out" as opposed to a normal pitch out off the initial puts the airplane coming in low off the deck at a much higher airspeed at the pitch point than the normal pitch out, which is performed near pattern speed at the downwind altitude. The tactical pitch out is a fan break off the deck pulling up and into the downwind. Both approaches use the break and pull into drag rise to slow the aircraft to dirty configuration airspeed. -- Dudley Henriques I seem to remember the Blue Angels solos doing a similar maneuver at the finish of each of their passes. For example, a solo pass from right to left would finish with a 270 roll to the right and then a pitch to the left (maybe with a slight hesitation at the knife edge position) to exit the "arena" to set up for the next pass. Only difference would be that the 270 was in one motion rather than hesitating at each 90 degree point (if that's what you mean by "3-point" roll.) tp |
muff528 wrote:
"Dudley Henriques" wrote in message ... gatt wrote: I threw out the Wiki on Dudley Henriques to MX on r.a.s. and then read this: "During the early sixties, flying a Mustang, he patented a three point reverse roll to knife-edge tactical pitch-out approach that became a trademark manoeuvre." http://en.wikipedia.org/wiki/Dudley_Henriques Well, that flew right over -my- head! There doesn't seem to be video or some other internet source demonstrating this that I can find. (but boy is it fun looking!) Can I ask what a "reverse roll" is? (or a "tactical pitch-out approach") Thanks! -Chris Gattman Portland Kyle has it exactly right. Reverse roll simply meant the pitch out was away from the intended downwind low off the initial; a 270 degree point 3 roll stopping the third point with hard top rudder and a transition to back pressure onto the downwind. A "tactical pitch out" as opposed to a normal pitch out off the initial puts the airplane coming in low off the deck at a much higher airspeed at the pitch point than the normal pitch out, which is performed near pattern speed at the downwind altitude. The tactical pitch out is a fan break off the deck pulling up and into the downwind. Both approaches use the break and pull into drag rise to slow the aircraft to dirty configuration airspeed. -- Dudley Henriques I seem to remember the Blue Angels solos doing a similar maneuver at the finish of each of their passes. For example, a solo pass from right to left would finish with a 270 roll to the right and then a pitch to the left (maybe with a slight hesitation at the knife edge position) to exit the "arena" to set up for the next pass. Only difference would be that the 270 was in one motion rather than hesitating at each 90 degree point (if that's what you mean by "3-point" roll.) tp That's right. The Blues two solos called it the Mirror Break if I remember right. Really looked sharp in the A4F's. The only difference was that they did it from level flight rather than as a fan break. -- Dudley Henriques |
| Thread Tools | |
| Display Modes | |
| Friday 072707 in Oshkosh Pt 1 - the Raptor [01/30] - "F22 lifting off 18 after very short takeoff roll.jpg" yEnc (0/1) | Just Plane Noise[_2_] | Aviation Photos | 129 | August 17th 07 06:52 AM |
| Friday 072707 in Oshkosh Pt 1 - the Raptor [01/30] - "F22 lifting off 18 after very short takeoff roll.jpg" yEnc (1/1) | Just Plane Noise[_2_] | Aviation Photos | 2 | July 29th 07 06:07 PM |
| FAA "Diversity" a.k.a. Reverse Racism | BiffClinton | Instrument Flight Rules | 3 | June 6th 07 05:36 PM |
| FAA "Diversity" a.k.a. White Male Reverse Racism | BiffClinton | Aviation Marketplace | 0 | June 3rd 07 09:02 PM |
| Hersh: Our Military Is "Getting To The Edge" With Bush... | dontcowerfromthetruth | Naval Aviation | 0 | April 10th 06 02:40 AM |
