ILS 16R at KRNO
Old December 13th 07, 04:34 PM posted to rec.aviation.ifr
nick name
Default ILS 16R at KRNO
The ILS 16R (http://tinyurl.com/353gd5) at Reno (KRNO) has the
notation:
"8500 to GS intercept 181 (2) and LOC (8.8)"
I don't understand this. It appears this means that GS intercept will
occur in 2 miles on a 181 heading and that LOC intercept will occur in
8.8 miles. Neither appears to be true from the plan view. In fact, it
looks more like LOC intercept will occur in 2 miles and GS intercept
in 8.8 (at 8500 feet).
Any insights?
Old December 13th 07, 05:44 PM posted to rec.aviation.ifr
Kobra
Any insights?
No idea, but I would like to know how on an ILS approach without GPS one
would identify PYRAM.
Kobra
Old December 13th 07, 06:05 PM posted to rec.aviation.ifr
Dave Butler
Any insights?
If airnav.com is to be believed, it's at the intersection of the 286
radial from HZN, and the 332 radial from FMG, at 22.19 DME, and is
charted on enroute-high and enroute-low as well as the IAP.
Dave
Old December 13th 07, 10:41 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Dave Butler" wrote in message
radial from HZN, and the 332 radial from FMG, at 22.19 DME, and is charted
The low altitude enroute chart shows the intersection of the HZN 286R and
FMG 332R to be LIBGE, three miles north of PYRAM.
Old December 14th 07, 03:23 PM posted to rec.aviation.ifr
gwengler
On Dec 13, 5:41 pm, "Steven P. McNicoll"
Isn't that interesting. Both on the Jepp approach plate as well as on
the Jepp low enrout chart PYRAM shows as FMZ 332R and HZN 286R. LIBGE
is FMZ 332R and on the INRO 164 LOC. By measuring the radial from HZN
to PYRAM, I get 303 deg T from FliteStar which is actually 286 deg M
(HZN Station Declination: 17.0 deg E), so that seems to be correct.
Gerd
Old December 19th 07, 12:40 PM posted to rec.aviation.ifr
Ron Natalie
Dave
It's even on the SECTIONAL.
Old December 13th 07, 10:38 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Kobra" wrote in message
PYRAM is a DME fix on V165.
Three miles north of PYRAM there's another fix, LIBGE, which can be
determined by DME, or a radial intersection from Hazen VOR, or the
intersection with the Reno RWY 16R LOC.
If you were inbound to Reno from the north on V165 you could your determine
your position at LIBGE as you flew through the localizer, continue for
another three miles on V165 and determine your position at the IAF PYRAM by
use of DME or GPS, at which point you'd turn to a heading of 181 to
intercept the localizer.
Old December 14th 07, 01:24 PM posted to rec.aviation.ifr
Ron Rosenfeld
You use your low altitude chart.
PYRAM is defined by the 286.0° radial from HZN (Hazen VOR) at 41.7 NM. It
is on V165 a few miles south of LIBGE
Old December 14th 07, 02:11 PM posted to rec.aviation.ifr
Steven P. McNicoll[_2_]
Are you looking at a Jeppesen chart?
NACO low altitude enroute chart L-9 shows LIBGE to be where the HZN
286R crosses V165. NACO high altitude enroute chart H-3 shows PYRAM
to be where the HZN 286R crosses J5. V165 and J5 are defined by the
FMG 332R.
Old December 14th 07, 03:38 PM posted to rec.aviation.ifr
gwengler
On Dec 14, 9:11 am, "Steven P. McNicoll"
FMG 332R.
Isn't that interesting. On both Jepp approach plate and low enrout
chart, PYRAM is identified as HZN 286R and FMG 332R. I measured it
with FliteStar and it's indeed 303T from HZN, which is correct
(Station Declination: 17.0°E). LIGBE is defined as by the IRNO /
RW16R Localizer at KRNO at 27.4 NM by Jeppesen, but it's also FMG
332R.
Gerd
