Electric airplane - recharged
Old December 21st 07, 03:50 PM posted to rec.aviation.homebuilt
Bill Daniels
Default Electric airplane - recharged
Take a look at this:
http://www.electronista.com/articles...owire.battery/
OK, it's just a laboratory development and needs to work it's way through
all the R&D to become an actual product. But, an order of magnetude
improvement? WOW!
Of course, as many 'negative experts' will point out, if this thing shorts
out, your airplane goes supernova.
However, if this thing works out, a 10 hour, 1000NM range electric airplane
is actually possible.
Bill Daniels
Old December 21st 07, 05:20 PM posted to rec.aviation.homebuilt
Gig601XLBuilder
improvement? WOW!
Bill Daniels
This won't work in small aircraft but Toshiba has a new gadget that
should work for the big boys.
http://www.nextenergynews.com/news1/...ar-12.17b.html
Old December 23rd 07, 02:19 PM posted to rec.aviation.homebuilt
David Bridgham
Gig601XLBuilder writes:
It is 6'x20' and produces only 200kW or 268hp. That's a lot when
powering a building but not so much for a large aircraft.
-Dave
Old December 23rd 07, 07:31 PM posted to rec.aviation.homebuilt
Morgans[_2_]
And I'll bet that it was designed and built with lightness as the foremost
consideration.
April fools! g
Jim in NC
Old December 21st 07, 10:51 PM posted to rec.aviation.homebuilt
Vaughn Simon
"Bill Daniels" bildan@comcast-dot-net wrote in message
OK, it's just a laboratory development and needs to work it's way through all
the R&D to become an actual product. But, an order of magnetude improvement?
WOW!
Also, Exxon (yep, the gasoline folks) is actually bringing new lithium
battery technology to market. They are aimed at the EV/ hybrid vehicle market.
http://www.ecogeek.org/content/view/1180/
Vaughn
Old December 21st 07, 11:52 PM posted to rec.aviation.homebuilt
Bill Daniels
"Vaughn Simon" wrote in message
news
improvement? WOW!
market.
Vaughn
Here's an interview with Dr. Yi Cui the Stanford researcher who made the
breakthrough. Yi seems to be saying that his work is complementary to the
Lithium Iron (LiFeP04) batteries from companies like A123 Systems. If true,
and I very much hope it is, we will get 10 hour duration electric airplanes
that recharge in minutes and electric cars with 1000 mile range. Long life,
safety, high capacity, fast charge (10 min) high current delivery, what's
not to like.
This could be, finally, the death nell for the internal combustion engine.
http://www.gm-volt.com/2007/12/21/gm...-breakthrough/
Old December 22nd 07, 01:13 AM posted to rec.aviation.homebuilt
Vaughn Simon
we will get 10 hour duration electric airplanes that recharge in minutes and
That sounds incredibly optimistic, and far from necessary. I would be happy
to pay a lot less for a three hour airplane and/or a car with climate control
that will carry 4 folks an honest 100 miles or so.
Vaughn
Old December 26th 07, 01:29 AM posted to rec.aviation.homebuilt
Roger (K8RI)
On Fri, 21 Dec 2007 16:52:46 -0700, "Bill Daniels"
news
improvement? WOW!
market.
Vaughn
Ahhh... you might get the capacity and duration, but stop and think
what you'd need for a charging capacity. First, I'd figure at least
180HP at 748 per HP that 8640 watts per hour X 10 or 86,400.
Neglecting losses in the motor power conversion as well as the charge
and discharge
If running 220 volts you could charge in 10 hours @ 30 amps, one hour
at 300 amps (that's a lot of amps) or the "10 minutes or less" = 1800
amps or more at the electrical mains. There are some practical
considerations here beyond the battery that at best would give a
charge time of several hours. Now given (again not considering
losses) 86 KWH at 10C per KWH = $8.60 Which sounds great. Even at the
Republik of kalafornia's 38 cents per KWH peak time it's only $32.68
which still sounds good compared to the 8 GPH of a 180 HP Engine for
10 hours = 80 gallons at $5.00 per gallon or $400
DC motors are running in the 94 to 96% range which is really good, but
I don't know about the battery charge and discharge efficiency.
Think of just 10 planes stopping in for a charge on a cross country.
With the minimum charge of 1 hour that would require 3,000 amps from
the 220 mains or 1500 from a 3 phase 440 system. That is one
industrial grade, have your own substation hook up. Even with trainers
we need 3 hours duration, but they could be on the order of 100 to 120
HP and those could meet the short charge times and require batters
about 15 to 20% the size above. Now used in the sport plane size
category they could make for some inexpensive flying. To be
competitive they still need a minimum of 500 mile range, but 500 miles
on half the HP means only a quarter of the energy is required. That
could make a fleet of trainers and flight training quote economical.
not to like.
Probably not right away, or more likely it'd take at least two or
three decades under the best of conditions if the technology is
available soon.
If batteries get this good where is the electricity going to come
from? We have no where near the grid capacity to power more than a
small fraction of the cars on the road. Solar is great, but not at
this scale at least from home even if you do live in the sunny SW.
To charge in 10 hours would take a pretty big and expensive array
however every little bit helps. On average the best you can hope for
is 12 hours of sunlight and less than 10 of strong sunlight. Up here,
this time of year it's only about 8 to 8.5 hours from dawn to dusk.
Most of that is from a shallow angle and it's cloudy most of the
time. Just to do my small house with a combination of active and
passive the quote came out to about $50,000 up here and there are no
subsidies available. When you consider the *current* low cost of
electricity and natural gas this is nowhere near being economically
feasible.
Our electric alone is running 6 to 7 KWh per hour for a small home and
we already use the energy efficient lights in almost every fixture.
This doesn't count the natural gas.
What this works out to is even with these high efficiency batteries
the power used would well exceed the use of the average size home IF
you could continue to get it. OTOH this does have lots of
possibilities, but I think we are going to be stuck at the hybrid
level for at least a couple of decades. Even with high capacity
batteries with high efficiency charge and discharge cycles Hybrids
with the ability to charge when parked would give the best we could
hope for.
There are even more efficient means of storage, but you're going to
have to get that room temperature super conductor perfected. However
with large capacity batteries that have *zero* internal resistance I
doubt the government would permit them. Remember, dynamite contains
far less energy than gas, it's the rate of release that does the
damage. Now take the equivalent of a 100 or so gallons of gas and
release that in a few milliseconds.
With the Lithium batteries you might get a big, hot, toxic fire, but
with the superconduting battery, it go "boom".
Roger (K8RI)
Old December 26th 07, 02:00 AM posted to rec.aviation.homebuilt
Bill Daniels
"Roger (K8RI)" wrote in message
news
through
improvement? WOW!
market.
Vaughn
true,
airplanes
life,
and discharge
not to like.
available soon.
feasible.
hope for.
Roger (K8RI)
Dispite what the electric companies say, charging big battery powered
vehicles will indeed stress the power grid - even if charging is done at
night. The generation and distribution grid will have to be improved - but
that will probably be neccessary anyway for electric cars. Airplanes are
way down the list but it could happen. It's pretty hard not to get excited
about a 10x battery improvement.
(Wasn't there a thread about personal nuclear power?
http://www.news.com/8301-10784_3-9837400-7.html )
Bill Daniels
Old December 26th 07, 03:51 PM posted to rec.aviation.homebuilt
Darrel Toepfer
Do like the propane tanks and exchange them out for a small fee...
This takes into consideration that they bring down the cost of making
the batteries to begin with. The "local battery exchange" can then
recharge the batteries using longer charge times, which would of course
extend their life...
Electric maned airplane Flyingmonk Piloting 26 July 20th 06 05:43 AM
Electric maned airplane Flyingmonk Home Built 26 July 20th 06 05:43 AM
Electric maned airplane Morgans Home Built 4 July 19th 06 02:28 AM
Electric RC Helicopter for $83 NYPT Man Home Built 0 October 24th 05 06:47 PM
Electric DG Robbie S. Owning 0 March 19th 05 03:20 AM
