On a fighter equipped with machine guns and 20mm cannon, how common was it to fire BOTH weapons at the same time? Thanks in advance for your response. |
Kurt Jeffery wrote:
On a fighter equipped with machine guns and 20mm cannon, how common was it to fire BOTH weapons at the same time? Thanks in advance for your response. Presumably it was fairly common, at least if the two had similar ballistics. I seem to recall that there was a quote in Ethell's book on the P-38 Lightning about squadrons rewiring their aircraft so that both MGs and cannon would fire with one switch. Mike |
In Soviet Red Army, P-39 Aircobras had four 12.7mm and one 37mm gun. The
Soviet ace, Pokryshkin, noticed that pilots are coming home with full 37mm magazines. He disovered it was because of the unsuitable location of 37 mm gun trigger. Then he ordered that all armament is coupled on one trigger. Once it proved sucessful, he ordered same modification to entire squadron and wrote to HQ about this problem, so most Soviet Aircobras were firing 12.7 & 37mm guns by pressing one trigger instead of two. -- Nele NULLA ROSA SINE SPINA Kurt Jeffery wrote in message ... On a fighter equipped with machine guns and 20mm cannon, how common was it to fire BOTH weapons at the same time? Thanks in advance for your response. |
hen he ordered that all armament is coupled on one trigger. That's a whole different concept than the early Japanese Zero pilots, who supposedly used their 7.7 mm guns essentially as targeting devices for the 20 mm. all the best -- Dan Ford email: see the Warbird's Forum at www.warbirdforum.com and the Piper Cub Forum at www.pipercubforum.com |
Cub Driver wrote in message . ..
hen he ordered that all armament is coupled on one trigger. That's a whole different concept than the early Japanese Zero pilots, who supposedly used their 7.7 mm guns essentially as targeting devices for the 20 mm. It's worth noting that some mixed installations had very different loadouts. The Bf 109E carried about seven seconds' worth of ammo for the 20mm, but a whole minute's worth for the 7.92mm. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
In article Z_NAb.19515$d35.8687@edtnps84, Kurt Jeffery
writes On a fighter equipped with machine guns and 20mm cannon, how common was it to fire BOTH weapons at the same time? Thanks in advance for your response. Depends first of all if your gun controls allowed it. I think that most RAF fighters with mixed armament did, the early Beaufighter being a notable exception: On early single-engined RAF fighter aircraft during the war the gun firing control was located on the spade grip and was a single button with a rotating safety ring surrounding it. This dated from the eight gun period. When the Spitfire acquired cannon, the control column had a triple push switch fitted for selective firing of; cannon, MGs, and both together. I do not know what this switch looked like. The Mosquito FB6 had a gun master switch on the instrument panel and on the control column there was a forefinger operated trigger for the 20mm cannon, and a thumb-operated trigger for the machine guns. The early Beaufighters had a single button for all guns (20mm and .303), and the later ones had a forefinger trigger for the cannon and a thumb button for the MGs, similar to the Mosquito. (Anyone know about the options for the Lockheed Lightning's mixed armament?) Later on, a new type of gun firing control came into use in the RAF which had an exposed camera button next to a hinged safety cover over a triple pressure gun button for selective fire. But I don't know precisely when this refinement came in. It was present in the Hornet, the Sea Fury, the Meteor Mk III, the Vampire etc. (all cannon-only fighters). A push on any part of the 'wobble button' fired all four cannon. I am sure that being able to fire just a pair of cannon selectively might have been useful at times, but I have not come across an RAF gun control that allowed this. I guess that by firing all together you would maintain a better chance of hitting a target, so when would selective fire be useful? MGs only against soft targets (strafing troops?) and cannon for hard skinned (vehicles and aircraft?). I have not come across any doctrine on this. Perhaps Tony and Emmanuel might be able to comment further? Cheers, Dave -- Dave Eadsforth |
Dave Eadsforth wrote in message ...
I am sure that being able to fire just a pair of cannon selectively might have been useful at times, but I have not come across an RAF gun control that allowed this. I guess that by firing all together you would maintain a better chance of hitting a target, so when would selective fire be useful? MGs only against soft targets (strafing troops?) and cannon for hard skinned (vehicles and aircraft?). I have not come across any doctrine on this. Perhaps Tony and Emmanuel might be able to comment further? It's not a subject that I've really looked at, but I have a vague recollection that Hunters could fire two Adens at a time, which was usual in ground attack to conserve ammo - they used all four in aerial combat. Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ |
In article , Tony
Williams writes Dave Eadsforth wrote in message news:RvdnW4AriF1$Ew8+ ... I am sure that being able to fire just a pair of cannon selectively might have been useful at times, but I have not come across an RAF gun control that allowed this. I guess that by firing all together you would maintain a better chance of hitting a target, so when would selective fire be useful? MGs only against soft targets (strafing troops?) and cannon for hard skinned (vehicles and aircraft?). I have not come across any doctrine on this. Perhaps Tony and Emmanuel might be able to comment further? It's not a subject that I've really looked at, but I have a vague recollection that Hunters could fire two Adens at a time, which was usual in ground attack to conserve ammo sensible option... - they used all four in aerial combat. sensible default! Tony Williams Military gun and ammunition website: http://www.quarry.nildram.co.uk Discussion forum at: http://forums.delphiforums.com/autogun/messages/ Cheers, Dave -- Dave Eadsforth |
On a fighter equipped with machine guns and 20mm cannon, how common was it to fire BOTH weapons at the same time? It would depend on the weapons themselves and what was preferred, either by squadron or by the pilot. High velocity machine guns combined to low velocity cannons, like in early Zeros or 109 E-models, weren't too suited to firing together unless in close range. Later 109 models or Focke Wulfs were equipped with machine guns and cannons that had fairly equal bullet trajectory and the weapons were set up such as the bullets from the various weapons flew approximately (or exactly) with same trajectory. Also, the weapons in Me 109 and I suspect as well as in FW 190s were electrically triggered. The 109 stick had a small "electrical board" which made it possible to change / connect any of the four buttons on the stick to whatever combination was needed. Some Finnish pilots preferred to wire all guns into the trigger, others kept the standard configuration (machine guns on trigger, cannons on top button). With cannonboot Messerschmitts nose cannon and machine guns were fired with trigger, wing cannons with top button. jok |
why fire a cannon at a figther ,you needed power to kill a big bomber..a .50mm
would shredd a zero so why would a P-38 jockey waste 20mm on one |
| Veteran fighter pilots try to help close training gap | Otis Willie | Military Aviation | 0 | December 2nd 03 11:09 PM |
| Kadena honors legendary WWII fighter ace | Otis Willie | Military Aviation | 0 | November 23rd 03 03:58 AM |
| A-4 / A-7 Question | Tank Fixer | Military Aviation | 135 | October 25th 03 04:59 AM |
| "Target for Today" & "Thunderbolt" WWII Double Feature at Zeno'sDrive-In | Zeno | Aerobatics | 0 | August 2nd 03 08:31 PM |
| Joint Russian-French 5th generation fighter? | lihakirves | Military Aviation | 1 | July 5th 03 02:36 AM |
