Osprey tested in air, at sea, but not in vortex ring state.
Old December 9th 03, 02:32 AM
Henry J. Cobb
Default Osprey tested in air, at sea, but not in vortex ring state.
http://www.signonsandiego.com/news/m...cnsosprey.html
"They decided not to finish a second phase of vortex ring state testing."
-HJC
Old December 9th 03, 02:50 AM
Kevin Brooks
That (your subject line claim) is not what it says. You are mistaking the
questionable claim from a former OT&E guru as meaning that the aircraft was
not tested in vortex ring state conditions, which just ain't the case.
"...has proven its ability to function safely in potentially deadly rapid
descent conditions, the government's top test pilot said...Gross said they
have completed the tests necessary to document the tilt-rotor's response to
the dangerous vortex ring state condition that rotary wing aircraft
encounter when descending too quickly at low airspeed...Gross and other
members of the Osprey test team have said the tilt-rotor encounters vortex
ring state at much higher rates of descent than helicopters and recovers
better because it can move the rotors forward to quickly gain airspeed..."We
believe we have explored this enough," Gross said.
If you are going to try to summarize the gist of the article in your header,
at least get it right.
Brooks
"Henry J. Cobb" wrote in message
om...
-HJC
Old December 9th 03, 06:52 AM
Henry J. Cobb
"Kevin Brooks" wrote in message t...
I don't see any mention that they ever actually went into full vortex
ring state.
What they need to do is send an unmanned Osprey up to say 10k feet,
put it into VRS and have it automatically recover until the software
is solid.
Then you don't have to worry about the pilot reacting in time, the
aircraft will rotate the engines forward and scoot out of trouble on
it's own.
-HJC
Old December 9th 03, 01:33 PM
Kevin Brooks
om...
t...
was
ring state.
You should reread your article, then.
is solid.
it's own.
Why? Other (conventional) rotary aircraft currently within operating
inventopries are susceptable to VRS and manage to handle it by knowing the
limits--why do you think the V-22 should somehow be different? Illogical.
Brooks
-HJC
Old December 11th 03, 01:29 AM
Henry J. Cobb
"Kevin Brooks" wrote in message et...
http://198.65.138.161/military/syste...t/v-22-vrs.htm
"This asymmetrical VRS phenomenon, which is unique to side-by-side
rotor configurations, will have the initial resultant effect of
inducing a large rolling moment in the yaw direction."
That's what's different about it.
-HJC
Old December 11th 03, 02:28 AM
Chad Irby
et...
You missed a quote:
"Vortex Ring State can occur in all rotary-wing aircraft under similar
conditions of low airspeed and high sink rate."
The article also doesn't mention that front/back twin-rotor copters can
have similar issues (one in, one out of VRS).
Then there's this:
"When flown in compliance with NATOPS WARNING limits and with adequate
training, susceptibility to VRS is nil."
In other words, don't drop faster than 800 feet per minute at speeds
less than 40 knots and this won't happen to you.
cirby at cfl.rr.com
Remember: Objects in rearview mirror may be hallucinations.
Slam on brakes accordingly.
Old December 11th 03, 04:07 AM
Kevin Brooks
om...
et...
Illogical.
So what? The chief test pilot said that after the latest flight tests they
feel comfortable with thier procedures to handle it--that carries a heck of
a lot more water than what either you or that "former" OT&E guy have to say
about the matter.
Brooks
-HJC
Old December 11th 03, 07:21 PM
Alan Minyard
-HJC
A "rolling moment in the yaw direction"????? Is it just me, or does that
make no sense at all??
Al Minyard
Osprey 2 modifications Terry Mortimore Home Built 5 October 23rd 04 11:46 PM
Amphib: Coot vs Osprey II Greg Milligan Home Built 9 December 29th 03 01:48 AM
Will the V-22 Osprey be a harder RPG target? Henry J. Cobb Military Aviation 17 November 25th 03 05:15 PM
Squadron formed to test Osprey for combat readiness Otis Willie Military Aviation 0 August 30th 03 07:33 PM
Osprey vs. Harrier Stephen D. Poe Military Aviation 58 August 18th 03 03:17 PM
