SHOULD YOU OPEN FIRE?
Easy question right? Are you sure? Let's take a case in point. You are sitting in the top turret of a bomber. You spot a formation of fighters coming toward you. They are clearly the P-51 fighter escort you have been waiting for. "About time they showed up", you are thinking. They are getting closer pointing straight at you. Why aren't they fanning out and forming into a top cover position? They are still coming. Now they are getting near that critical 1,000 yard mark. At 600 yards they will be within their firing range. SHOOT NOW DAMMIT SHOOT! Shoot at what you identified to be your own P-51's? Damn right, And shoot to kill. And if you shot down every one of them, no jury would ever convict you. You were obeying a first rule that all gunners are taught early on. It goes like this. Any fighter that points its guns at you is to be considered hostile and be fired upon. On the other hand every fighter pilot is warned that hanging around a bomber formation can be a dangerous business,. He must be careful how he moves and where he moves to. For example; If a fighter is flying parallel to a bomber formation and wants to get closer, he might turn toward the formation dropping his inside wing and swinging his nose toward the bombers. This is a classic fighter approach so highly favored by the Luftwaffe and the USAAC and RAF as well. To approach a bomber in this manner can prove fatal since gunners are trained to recognize that as a fighter approach and assume he is under attack.. He will then assume that he misidentified the attacker as friendly when the every moves proves he is hostile. Should you open fire? Damn right you should. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
Uhhh....I think "drop the inside wing and swing the nose" is the normal way
to turn an airplane. Maybe I don't understand your point. "ArtKramr" wrote in message ... SHOULD YOU OPEN FIRE? Easy question right? Are you sure? Let's take a case in point. You are sitting in the top turret of a bomber. You spot a formation of fighters coming toward you. They are clearly the P-51 fighter escort you have been waiting for. "About time they showed up", you are thinking. They are getting closer pointing straight at you. Why aren't they fanning out and forming into a top cover position? They are still coming. Now they are getting near that critical 1,000 yard mark. At 600 yards they will be within their firing range. SHOOT NOW DAMMIT SHOOT! Shoot at what you identified to be your own P-51's? Damn right, And shoot to kill. And if you shot down every one of them, no jury would ever convict you. You were obeying a first rule that all gunners are taught early on. It goes like this. Any fighter that points its guns at you is to be considered hostile and be fired upon. On the other hand every fighter pilot is warned that hanging around a bomber formation can be a dangerous business,. He must be careful how he moves and where he moves to. For example; If a fighter is flying parallel to a bomber formation and wants to get closer, he might turn toward the formation dropping his inside wing and swinging his nose toward the bombers. This is a classic fighter approach so highly favored by the Luftwaffe and the USAAC and RAF as well. To approach a bomber in this manner can prove fatal since gunners are trained to recognize that as a fighter approach and assume he is under attack.. He will then assume that he misidentified the attacker as friendly when the every moves proves he is hostile. Should you open fire? Damn right you should. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
![]() "Olen Goodwin" wrote in message ... Uhhh....I think "drop the inside wing and swing the nose" is the normal way to turn an airplane. Maybe I don't understand your point. "ArtKramr" wrote in message I'll naturally leave the final comments on this to those who have actually seen them applied in combat , but these are my thoughts on this issue. It's a ROE issue, a choice issue.....not aerodynamics. It has to do with which direction the guns are pointed as that relates to the interface between the present rules of engagement understood by both the bomber and fighter crews , and what that all boils down to when you have one man in a fighter doing something with his airplane that presents a choice to a gunner in another airplane; and all this done under the pressure and strain of combat where people are firing at you. It's about firing at the enemy being bad enough on your brain's reaction time without factoring in choices to make it harder!!!! It's a point well made by Art, and deserves more than a cursory glance by those interested in the real psychology of war. The point here is that some ROE are fine when you view them in the operations room, but while engaged, it's a whole different ball game for those whose lives are on the line!! ROE for gunners present a nice fat and pat set of "rules" that everybody is supposed to follow .But ROE in actual combat are just that.....rules! I believe that ROE fall into several categories actually; those that can be considered before the fact....like not bombing a specific area (these are the easy rules).....and those like Art is describing, where there's a "rule" in play that everybody is supposed to understand and abide by while under combat conditions. At first glance, the two "rules" appear alike, but if you look closely, the first rule can be planned ahead of time. The second is applied in real time in an ongoing combat environment. This inserts a viable additional factor into the ROE equation, and that factor is individual choice. The time line for reaction is virtually zero, and this brings up an aspect of the ROE question that in every instance should be addressed by those who come after the fact and seek to judge those directly involved. In this case the ROE dictated that guns pointed at a bomber by ANYONE friendly or otherwise were to be considered hostile and return fire was a possibility. Both the bomber crews and the fighter pilots were no doubt briefed in the form of a "warning". This is all well and good in the operations room, but once in actual combat, there is little time for "rules", especially for a turret gunner who has mere seconds to save both his life and the lives of everyone in his crew. Although there's a guideline in place, there are real time choices involved with this kind of a ROE that might very well go beyond the ability of anyone to be reasonably able to comply in every instance. Viewed in the scenario of actual combat in real time "Should you open fire" is a valid question before and after the event. During the event, it could very well involve a judgment call requiring a thought process/reaction that is unavailable to the human mind under the pressure/strain factors involved. At best, this kind of ROE should be considered exactly for what it is in reality; to the fighter pilot, simply a warning you keep in the back of your mind and try to avoid. For the gunner it's worse. He has the rule, the act the pilot has committed, the recognition factor, and the reaction time to consider. After he's done all this......he has a CHOICE to make. Or, he can forget all this, and simply fire at anything pointing their guns at his airplane. In vierwing the roles of both the fighter pilot and the gunner as each interacts with a ROE like this one, the bottom line should be that it's out there in both camps as a general warning, but if that "warning" fails to prevent a friendly fire incident, no action should be forthcoming after the fact by those who instigated these "rules" Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
Subject: SHOULD YOU OPEN FIRE?
From: "Dudley Henriques" Date: 12/13/03 8:23 AM Pacific Standard Time Message-id: "Olen Goodwin" wrote in message ... Uhhh....I think "drop the inside wing and swing the nose" is the normal way to turn an airplane. Maybe I don't understand your point. "ArtKramr" wrote in message I'll naturally leave the final comments on this to those who have actually seen them applied in combat , but these are my thoughts on this issue. It's a ROE issue, a choice issue.....not aerodynamics. It has to do with which direction the guns are pointed as that relates to the interface between the present rules of engagement understood by both the bomber and fighter crews , and what that all boils down to when you have one man in a fighter doing something with his airplane that presents a choice to a gunner in another airplane; and all this done under the pressure and strain of combat where people are firing at you. It's about firing at the enemy being bad enough on your brain's reaction time without factoring in choices to make it harder!!!! It's a point well made by Art, and deserves more than a cursory glance by those interested in the real psychology of war. The point here is that some ROE are fine when you view them in the operations room, but while engaged, it's a whole different ball game for those whose lives are on the line!! ROE for gunners present a nice fat and pat set of "rules" that everybody is supposed to follow .But ROE in actual combat are just that.....rules! I believe that ROE fall into several categories actually; those that can be considered before the fact....like not bombing a specific area (these are the easy rules).....and those like Art is describing, where there's a "rule" in play that everybody is supposed to understand and abide by while under combat conditions. At first glance, the two "rules" appear alike, but if you look closely, the first rule can be planned ahead of time. The second is applied in real time in an ongoing combat environment. This inserts a viable additional factor into the ROE equation, and that factor is individual choice. The time line for reaction is virtually zero, and this brings up an aspect of the ROE question that in every instance should be addressed by those who come after the fact and seek to judge those directly involved. In this case the ROE dictated that guns pointed at a bomber by ANYONE friendly or otherwise were to be considered hostile and return fire was a possibility. Both the bomber crews and the fighter pilots were no doubt briefed in the form of a "warning". This is all well and good in the operations room, but once in actual combat, there is little time for "rules", especially for a turret gunner who has mere seconds to save both his life and the lives of everyone in his crew. Although there's a guideline in place, there are real time choices involved with this kind of a ROE that might very well go beyond the ability of anyone to be reasonably able to comply in every instance. Viewed in the scenario of actual combat in real time "Should you open fire" is a valid question before and after the event. During the event, it could very well involve a judgment call requiring a thought process/reaction that is unavailable to the human mind under the pressure/strain factors involved. At best, this kind of ROE should be considered exactly for what it is in reality; to the fighter pilot, simply a warning you keep in the back of your mind and try to avoid. For the gunner it's worse. He has the rule, the act the pilot has committed, the recognition factor, and the reaction time to consider. After he's done all this......he has a CHOICE to make. Or, he can forget all this, and simply fire at anything pointing their guns at his airplane. In vierwing the roles of both the fighter pilot and the gunner as each interacts with a ROE like this one, the bottom line should be that it's out there in both camps as a general warning, but if that "warning" fails to prevent a friendly fire incident, no action should be forthcoming after the fact by those who instigated these "rules" Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt All this is originally derived from basic infantry training. We were taught in basic training that you are never to point a gun at a man unless you mean to kill him And if a man points a gun at you, assume he means to kill you. These rules were simply transferred intact to air-to-air gunnery. And a good thing too. Griego never should have allowed that "P-51 flashing his wing lights" get so close in the 6 O'clock position. He should have opened fire long before that. He made two errors. He misidentified the EA and he allowed it to get within that critical 600 yard range where it could do damage. We had a range of about 1.000 yards. The AE had a 600 yard range. So there was a 400 yard zone where we could hit the AE but the Ae couldn't hit us. Greigo should have started firing in that 400 yard zone. But it was our first mission and we were young and very inexperienced. I guess that is why they stuck us back in the tail-end-Charlie slot until we were dry behind the ears..But we moved up quickly with experience and ended up flying deputy lead before the war ended. Regards, Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
![]() "ArtKramr" wrote in message ... Subject: SHOULD YOU OPEN FIRE? I guess that is why they stuck us back in the tail-end-Charlie slot until we were dry behind the ears..But we moved up quickly with experience and ended up flying deputy lead before the war ended. One thing's for certain. Nobody learns about aerial gunnery faster than the guy flying that TEC position!! In the fighter groups, early in the war, before viable and realistic tactical formations became the rule of the day , that position was tantamount to a death sentence for many. Dudley Henriques International Fighter Pilots Fellowship Commercial Pilot/ CFI Retired For personal email, please replace the z's with e's. dhenriquesATzarthlinkDOTnzt |
From: "Dudley Henriques" Date: 12/13/03 10:02 AM Pacific Standard Time Message-id: t "ArtKramr" wrote in message ... Subject: SHOULD YOU OPEN FIRE? I guess that is why they stuck us back in the tail-end-Charlie slot until we were dry behind the ears..But we moved up quickly with experience and ended up flying deputy lead before the war ended. One thing's for certain. Nobody learns about aerial gunnery faster than the guy flying that TEC position!! In the fighter groups, early in the war, before viable and realistic tactical formations became the rule of the day , that position was tantamount to a death sentence for many. Dudley Henriques International Fighter Pilots Fellowship Well for us Flak was more of a dangere than fighters. And in most cases where flak strikes is more of a statistical happenstance than the slot you were in. But you are right, TEC wasn't my favorite slot and we were glad to move up and out of it.. Regards, Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
to turn an airplane. Maybe I don't understand your point. The point is, you don't want to look like an attacker. Anyway, you don't need to point your nose at a bomber, or other aircraft, to get close to it. It isn't even the "right" way to do it." You do a formation join-up. If the bomber is flying, say, due north, and is on your left side, you fly a heading of around 300 - 320. You keep adjusting your heading so that the bomber's position remains constant relative to your own. I.e., it appears to stay at the same place on your canopy. You will soon be on the bomber's wing, but will not get shot at because you have never pointed your guns toward it. You appear to be flying "almost parallel," which, in fact, you are. And you give the bomber's crew a good look at your side profile, which they are most likely to recognize as a friendly. vince norris "ArtKramr" wrote in message ... SHOULD YOU OPEN FIRE? Easy question right? Are you sure? Let's take a case in point. You are sitting in the top turret of a bomber. You spot a formation of fighters coming toward you. They are clearly the P-51 fighter escort you have been waiting for. "About time they showed up", you are thinking. They are getting closer pointing straight at you. Why aren't they fanning out and forming into a top cover position? They are still coming. Now they are getting near that critical 1,000 yard mark. At 600 yards they will be within their firing range. SHOOT NOW DAMMIT SHOOT! Shoot at what you identified to be your own P-51's? Damn right, And shoot to kill. And if you shot down every one of them, no jury would ever convict you. You were obeying a first rule that all gunners are taught early on. It goes like this. Any fighter that points its guns at you is to be considered hostile and be fired upon. On the other hand every fighter pilot is warned that hanging around a bomber formation can be a dangerous business,. He must be careful how he moves and where he moves to. For example; If a fighter is flying parallel to a bomber formation and wants to get closer, he might turn toward the formation dropping his inside wing and swinging his nose toward the bombers. This is a classic fighter approach so highly favored by the Luftwaffe and the USAAC and RAF as well. To approach a bomber in this manner can prove fatal since gunners are trained to recognize that as a fighter approach and assume he is under attack.. He will then assume that he misidentified the attacker as friendly when the every moves proves he is hostile. Should you open fire? Damn right you should. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
Couldn't he fire a short warning burst sufficiently off target at 900
yards, in essence telling any fighter to back off or else? That should scare off a friendly, still preserve some range advantage, and it might also disrupt an enemy's gun run. If the guy was friendly and kept flying into that, well, the gunner would be doing a Jack Kavorkian (sp?) on the fighter pilot. Tony "ArtKramr" wrote in message ... SHOULD YOU OPEN FIRE? Easy question right? Are you sure? Let's take a case in point. You are sitting in the top turret of a bomber. You spot a formation of fighters coming toward you. They are clearly the P-51 fighter escort you have been waiting for. "About time they showed up", you are thinking. They are getting closer pointing straight at you. Why aren't they fanning out and forming into a top cover position? They are still coming. Now they are getting near that critical 1,000 yard mark. At 600 yards they will be within their firing range. SHOOT NOW DAMMIT SHOOT! Shoot at what you identified to be your own P-51's? Damn right, And shoot to kill. And if you shot down every one of them, no jury would ever convict you. You were obeying a first rule that all gunners are taught early on. It goes like this. Any fighter that points its guns at you is to be considered hostile and be fired upon. On the other hand every fighter pilot is warned that hanging around a bomber formation can be a dangerous business,. He must be careful how he moves and where he moves to. For example; If a fighter is flying parallel to a bomber formation and wants to get closer, he might turn toward the formation dropping his inside wing and swinging his nose toward the bombers. This is a classic fighter approach so highly favored by the Luftwaffe and the USAAC and RAF as well. To approach a bomber in this manner can prove fatal since gunners are trained to recognize that as a fighter approach and assume he is under attack.. He will then assume that he misidentified the attacker as friendly when the every moves proves he is hostile. Should you open fire? Damn right you should. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
From: "Tony Volk" Date: 12/13/03 12:32 PM Pacific Standard Time Message-id: Couldn't he fire a short warning burst sufficiently off target at 900 yards, in essence telling any fighter to back off or else? That should scare off a friendly, still preserve some range advantage, and it might also disrupt an enemy's gun run. If the guy was friendly and kept flying into that, well, the gunner would be doing a Jack Kavorkian (sp?) on the fighter pilot. Tony "ArtKramr" wrote in message ... SHOULD YOU OPEN FIRE? Easy question right? Are you sure? Let's take a case in point. You are sitting in the top turret of a bomber. You spot a formation of fighters coming toward you. They are clearly the P-51 fighter escort you have been waiting for. "About time they showed up", you are thinking. They are getting closer pointing straight at you. Why aren't they fanning out and forming into a top cover position? They are still coming. Now they are getting near that critical 1,000 yard mark. At 600 yards they will be within their firing range. SHOOT NOW DAMMIT SHOOT! Shoot at what you identified to be your own P-51's? Damn right, And shoot to kill. And if you shot down every one of them, no jury would ever convict you. You were obeying a first rule that all gunners are taught early on. It goes like this. Any fighter that points its guns at you is to be considered hostile and be fired upon. On the other hand every fighter pilot is warned that hanging around a bomber formation can be a dangerous business,. He must be careful how he moves and where he moves to. For example; If a fighter is flying parallel to a bomber formation and wants to get closer, he might turn toward the formation dropping his inside wing and swinging his nose toward the bombers. This is a classic fighter approach so highly favored by the Luftwaffe and the USAAC and RAF as well. To approach a bomber in this manner can prove fatal since gunners are trained to recognize that as a fighter approach and assume he is under attack.. He will then assume that he misidentified the attacker as friendly when the every moves proves he is hostile. Should you open fire? Damn right you should. Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer Yes, that was often the case. Warning rounds were both common and usually quite effective. I should have mentioned that. Thanks. Regards, Arthur Kramer 344th BG 494th BS England, France, Belgium, Holland, Germany Visit my WW II B-26 website at: http://www.coastcomp.com/artkramer |
Inside the Cowling Fire / Heat Detector? | George Sconyers | Aviation Marketplace | 4 | May 31st 04 01:40 AM |
FS DeHavilland Open Cockpit Chipmunk | [email protected] | Aviation Marketplace | 0 | October 14th 03 11:10 AM |
Fire officer tops in field — again | Otis Willie | Military Aviation | 0 | October 13th 03 08:37 PM |
Friendly fire pilot may testify against wingman | Otis Willie | Military Aviation | 0 | October 11th 03 09:32 PM |
Woman's sentence suspended in attempt to set captain on fire | Otis Willie | Military Aviation | 0 | August 16th 03 08:44 PM |
