A Happy New Year to All! I am thinking about getting
a hydraulic disc conversion wheel/brake for my SZD-59. I have not heard anything bad about Cleveland setups, and have not anything bad the Tost equivalents either. Both setups can/have been done. Both being about the same price (read expensive), and both the same amount of work to install, naturally I want the better of the two. I hope this is not a religious war subject, I just want to hear more opinions and I know there are a few of those here... Paul Hanson "Do the usual, unusually well"--Len Niemi |
On Jan 3, 10:35*am, Paul Hanson
wrote: A Happy New Year to All! I am thinking about getting a hydraulic disc conversion wheel/brake for my SZD-59. I have not heard anything bad about Cleveland setups, and have not anything bad the Tost equivalents either. Both setups can/have been done. Both being about the same price (read expensive), and both the same amount of work to install, naturally I want the better of the two. I hope this is not a religious war subject, I just want to hear more opinions and I know there are a few of those here... Paul Hanson "Do the usual, unusually well"--Len Niemi If you want it to stop Cleveland. Al |
On Jan 3, 11:35*am, Paul Hanson
I just want to hear more opinions and I know there are a few of those here... I'd start by asking which brand current new sailplanes use. Schleicher seems to have gone with Cleveland (ASW-28). I'd also ask about price and availability of consumables. In 5 years I have never needed to do anything to the brake on my 28 but I think the Cleveland brake pads are easy to get. It would be hard to fault the 28 brake. It's powerful, progressive, does not drag, and needs no maintenance. Andy |
What Al said.
Cleveland brake is reliable, parts are readily available and braking power is unsurpassed. I believe everything AS-W since the -20B came with 500x5 Cleveland and I retrofitted one to my AS-W12 as well. |
after reading many of the responses to your message, typically never 100%
correct, what most don't realize is that most of the TOST Hydraulic brake systems are, and most of the system parts used by the glider manufacturers supplied to them by TOST are in fact......"Cleveland" Brake parts.....only with some modifications by TOST, usually to change the fluid type to(DOT 4 brake fluid rather tan Hydraulic fluid)...What TOST has done has assemble the brakes along with the brake components to make up the kit that is used on gliders. see my website page for some available kits on http://www.wingsandwheels.com/page32.htm tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Paul Hanson" wrote in message ... A Happy New Year to All! I am thinking about getting a hydraulic disc conversion wheel/brake for my SZD-59. I have not heard anything bad about Cleveland setups, and have not anything bad the Tost equivalents either. Both setups can/have been done. Both being about the same price (read expensive), and both the same amount of work to install, naturally I want the better of the two. I hope this is not a religious war subject, I just want to hear more opinions and I know there are a few of those here... Paul Hanson "Do the usual, unusually well"--Len Niemi |
For use with Mil Spec 5606 fluid (the red petroleum based fluid that is
standard for small aircraft in the US), the O-rings and seals are normally Buna-N rubber. If the Cleveland brake parts have been modified by Tost to use DOT brake fluid, they do this by changing the O-rings and seals to EPDM rubber to make them compatible with automotive DOT brake fluid. Stemme uses such modified Cleveland calipers and DOT fluid in the S10-VT. Schleicher uses unmodified Cleveland calipers and 5605 fluid in the ASH26E (and I assume all their current gliders). While automotive DOT fluids have advantages for high temperature braking applications, the fluid attacks many paints, is hygroscopic, and thus will sometimes promote corrosion in brake systems not specifically designed for it (i.e. early Cleveland calipers and pucks with bare aluminum, as opposed to anodized, will often corrode and cause fluid leakage at the seals. Some automotive restorers will line the caliper bore with brass sleeves and anodize the pucks to restore these corroded brake components. For glider and small aircraft brakes, I prefer 5605 fluid. bumper zz Minden NV Quiet Vents and MKII high tech yaw strings "Tim Mara" wrote in message ... after reading many of the responses to your message, typically never 100% correct, what most don't realize is that most of the TOST Hydraulic brake systems are, and most of the system parts used by the glider manufacturers supplied to them by TOST are in fact......"Cleveland" Brake parts.....only with some modifications by TOST, usually to change the fluid type to(DOT 4 brake fluid rather tan Hydraulic fluid)...What TOST has done has assemble the brakes along with the brake components to make up the kit that is used on gliders. see my website page for some available kits on http://www.wingsandwheels.com/page32.htm tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Paul Hanson" wrote in message ... A Happy New Year to All! I am thinking about getting a hydraulic disc conversion wheel/brake for my SZD-59. I have not heard anything bad about Cleveland setups, and have not anything bad the Tost equivalents either. Both setups can/have been done. Both being about the same price (read expensive), and both the same amount of work to install, naturally I want the better of the two. I hope this is not a religious war subject, I just want to hear more opinions and I know there are a few of those here... Paul Hanson "Do the usual, unusually well"--Len Niemi |
On Jan 3, 2:14*pm, "Tim Mara" wrote:
with some modifications by TOST, usually to change the fluid type to(DOT 4 brake fluid rather tan Hydraulic fluid)... Why did Tost find it necessary to change the fluid type and is that change approved by Cleveland? Andy |
![]() After reading Tim's post my partners and I are seriously considering installing a Tost kit on our 1979 Twin Astir (the original retractable). Has anyone out there installed one of these kits on any ship ? On a Twin Astir? Hearing about your experience both with installation and performance would be very helpful. Would you recommend having an A&E do the job, or can it be handled by enthusiastic amateurs? Thanks, Al Tim Mara wrote: after reading many of the responses to your message, typically never 100% correct, what most don't realize is that most of the TOST Hydraulic brake systems are, and most of the system parts used by the glider manufacturers supplied to them by TOST are in fact......"Cleveland" Brake parts.....only with some modifications by TOST, usually to change the fluid type to(DOT 4 brake fluid rather tan Hydraulic fluid)...What TOST has done has assemble the brakes along with the brake components to make up the kit that is used on gliders. see my website page for some available kits on http://www.wingsandwheels.com/page32.htm tim Please visit the Wings & Wheels website at www.wingsandwheels.com "Paul Hanson" wrote in message ... A Happy New Year to All! I am thinking about getting a hydraulic disc conversion wheel/brake for my SZD-59. I have not heard anything bad about Cleveland setups, and have not anything bad the Tost equivalents either. Both setups can/have been done. Both being about the same price (read expensive), and both the same amount of work to install, naturally I want the better of the two. I hope this is not a religious war subject, I just want to hear more opinions and I know there are a few of those here... Paul Hanson "Do the usual, unusually well"--Len Niemi |
relining my 5' Tost drum brake shoes with a modern
compound(eg vintage motocycle racing) worked for me (£25 and a friend sized them) Pete At 18:37 03 January 2008, Paul Hanson wrote: A Happy New Year to All! I am thinking about getting a hydraulic disc conversion wheel/brake for my SZD-59. I have not heard anything bad about Cleveland setups, and have not anything bad the Tost equivalents either. Both setups can/have been done. Both being about the same price (read expensive), and both the same amount of work to install, naturally I want the better of the two. I hope this is not a religious war subject, I just want to hear more opinions and I know there are a few of those here... Paul Hanson 'Do the usual, unusually well'--Len Niemi |
FS Tost E85 Release | scooter | Soaring | 0 | March 7th 06 02:31 AM |
FS Tost E85 Release | scooter | Soaring | 0 | November 22nd 05 01:11 AM |
Tost release on L-19? | Roy Bourgeois | Soaring | 2 | November 29th 04 10:24 PM |
Cessna 182 Tost 337? | [email protected] | Soaring | 6 | May 15th 04 03:24 PM |
Tost springs | Lord Struthers | Soaring | 1 | October 10th 03 10:49 PM |
