I'm listening to the LiveATC.net feed of Norcal (SFO) Approach,
since the weather is 'fun' today[1], and a few of the airliners are using letters after their standard callsigns. Two I've heard are United 893 Lima and United 885 Kilo. They show up on FlightAware as UAL893L and UAL885K, and UAL893 and UAL885 also show up, but as different aircraft types and different routes. Is this United's infamous 'change of gauge' 'direct' flight trick? According to FlightAware, UAL893L is a 757 flying KJFK-KSFO and UAL893 is a 777 flying KSFO-RKSI (Seoul, Korea). Does the letter have any special meaning beyond that it appears to be another flight using the same flight number but a different aircraft? UAL885K and UAL885L both have been used according to FlightAware, in addition to UAL885. John [1] Lots of missed approaches due to windshear. Diversions due to RVR 19R OTS and crappy vis. -- John Clear - http://www.clear-prop.org/ |
On Jan 4, 3:37*pm, (John Clear) wrote:
Is this United's infamous 'change of gauge' 'direct' flight trick? According to FlightAware, UAL893L is a 757 flying KJFK-KSFO and UAL893 is a 777 flying KSFO-RKSI (Seoul, Korea). Not the old "Change of gauge direct flight trick" again. Whats that ? Does the letter have any special meaning beyond that it appears to be another flight using the same flight number but a different aircraft? Here's the story, when an airline has a through flight (Through a hub airport), and the inbound flight is running late and the outbound flight is a different AC (Or another plane and crew can be rerouted), they will send the outbound flight on time but with a different call sign. You cannot have two flights in the air at the same time with that flight number. FB |
F. Baum wrote: On Jan 4, 3:37*pm, (John Clear) wrote: Is this United's infamous 'change of gauge' 'direct' flight trick? According to FlightAware, UAL893L is a 757 flying KJFK-KSFO and UAL893 is a 777 flying KSFO-RKSI (Seoul, Korea). Not the old "Change of gauge direct flight trick" again. Whats that ? On the reservation systems, UAL893 shows as KJFK-RKSI, with a stop in KSFO. But it isn't just a stop in KSFO, it is a change of planes as well (757 - 777, probably change of terminals too). Since it has just one flight number, it will appear before connecting flights, even though it is a connecting flight. Does the letter have any special meaning beyond that it appears to be another flight using the same flight number but a different aircraft? Here's the story, when an airline has a through flight (Through a hub airport), and the inbound flight is running late and the outbound flight is a different AC (Or another plane and crew can be rerouted), they will send the outbound flight on time but with a different call sign. You cannot have two flights in the air at the same time with that flight number. So the letter is just randomly assigned then, or procedure varies by airline? Thanks, John -- John Clear - http://www.clear-prop.org/ |
On Jan 4, 5:57*pm, (John Clear) wrote:
On the reservation systems, UAL893 shows as KJFK-RKSI, with a stop in KSFO. *But it isn't just a stop in KSFO, it is a change of planes as well (757 - 777, probably change of terminals too). Since it has just one flight number, it will appear before connecting flights, even though it is a connecting flight. Sucks for the pax. That would be a hard connection to make. -Robert |
"Robert M. Gary" wrote in news:08b5e7da-e021-4ee7-ad19-
: Sucks for the pax. That would be a hard connection to make. What - you think the airlines care about the pax? |
On Jan 4, 6:57*pm, (John Clear) wrote:
Here's the story, when an airline has a through flight (Through a hub airport), and the inbound flight is running late and the outbound flight is a different AC (Or another plane and crew can be rerouted), they will send the outbound flight on time but with a different call sign. You cannot have two flights in the air at the same time with that flight number. So the letter is just randomly assigned then, or procedure varies by airline? Varies by airline. Frank |
Today at Oshkosh [11/34] - "10 T28 formation (callsign Red Star 11) in warbird show .jpg" yEnc (1/1) | Just Plane Noise | Aviation Photos | 3 | July 25th 07 09:29 PM |
Letters Asking to Buy My Glider | ContestID67 | Soaring | 20 | November 30th 06 08:19 PM |
Glider Numbers and letters | Ron Gleason | Soaring | 2 | August 1st 06 05:23 AM |
Service Bulletins, Service Letters, Service Spares Letters | O. Sami Saydjari | Owning | 5 | December 26th 03 05:36 AM |
Old Contest Letters | Mhudson126 | Soaring | 10 | December 24th 03 02:55 PM |
