GNS430W software 3.0 upgrade
Old January 6th 08, 09:52 PM posted to rec.aviation.ifr
Mark Klebanoff
Default GNS430W software 3.0 upgrade
I had the upgrade installed a little while ago and it seems to have
impacted my screen. After the radio has been running a while, I
notice that when I change pages, the previous page seems to have
'burned in' to the screen for a few seconds and gradually fades away.
I also found that on startup, especially if the radio has been used
in the previous hour or so, the screen was nearly impossible to read
until I set the display settings contrast manually.
I contacted Garmin tech support and they said they'd seen something
like this with the upgrade. They had me set the contrast as "auto"
and set the contrast to a number around 095. They said it's best to
leave the contrast as auto, since apparently it needs to be constantly
tweaked as the screen heats up, but that the new software sometimes
fouls up the reference point, setting it too high.
I set the contrast to 095/auto, and now it works at startup, but I
notice that after the unit's run a while, the 'burn in" is still
there, although it fades after a few seconds. I suspect that either
the new software makes the unit run hotter, or the new software has a
problem adjusting contrast as the radio heats up. Has anyone had a
similar problem?
BTW, the radio is installed in a 1976 Cardinal RG, 14V electrical
system.
Old January 8th 08, 03:17 AM posted to rec.aviation.ifr
Sam Spade
impacted my screen.
When you say "upgrade," do you mean from a 430 to 430W?
Or, do you mean from one 430W software version to a later version?
I ask, because the conversion of a 430 to a 430W represented a major
hardware change.
Old January 8th 08, 12:05 PM posted to rec.aviation.ifr
Peter Clark
On Mon, 07 Jan 2008 19:17:52 -0800, Sam Spade
impacted my screen.
hardware change.
There's a new software version for the 430W units, came out in
December.
Old January 9th 08, 02:30 AM posted to rec.aviation.ifr
Mark Klebanoff
impacted my screen.
hardware change.
Sorry, I was unclear. I have a 430W and complied with the Garmin
service bulletin by upgrading the operating software to the 3.0
version.
Old January 9th 08, 02:50 PM posted to rec.aviation.ifr
Chuck
similar problem?
system.
And I am trying to get the upgrade and the weather here in Ohio has
delayed me. Thanks weather! The upgrade "fixes" a problem area that
I don't
use so I was fiixing something that wasn't broken. I think I will
put the upgrade on hold for a while and just listen.
Chuck
Old January 9th 08, 03:41 PM posted to rec.aviation.ifr
Mitty
On 1/9/2008 8:50 AM, Chuck wrote the following:
I don't
use so I was fixing something that wasn't broken. I think I will
Chuck
Garmin's software operation appears to be fairly undisciplined, at least from
what I see with upgrades to the CAP G1000 182s. Every new release it is a big
Easter egg hunt to find what they have changed and what they have broken. They
also change trivial cosmetic things, which is a no-no in professionally managed
mission software.
Waiting before loading "upgrades" is always wise, as is not rushing to get fixes
to problems you don't have. At my company, I always insisted that we age the
upgrades to our accounting system for at least six months, letting the "service
packs" accumulate. Which they always did.
Only after 6 months would we check the user groups and evaluate the risk and
payoff to installing the upgrade.
Old January 17th 08, 12:04 AM posted to rec.aviation.ifr
Dave Anderer
In article nze6zYQT7gHB-pn2-8eWUNLD0oD6k@localhost,
Anything more from Garmin on this? Any sense how widespread the problem
is?
I was planning to get this done soon, but...
Old January 17th 08, 10:22 AM posted to rec.aviation.ifr
Mark Klebanoff
On Thu, 17 Jan 2008 00:04:57 UTC, Dave Anderer
is?
I have not re-contacted them, but I think I can solve the problem by
continuing to adjust the contrast setting. I took it from 095 to 085.
The screen is still perfectly readable (in fact I can't see any
difference), but I think the burn in has gotten better. At least I
don't recall it being a problem the last time I flew, but I didn't
look closely.
AOPA reporting free GNSx30 WAAS software upgrade available Peter R. Instrument Flight Rules 10 December 14th 07 05:52 PM
Lightspeed: Upgrade 25XL w/Cell Adaptor or Upgrade to 30 3G Andrew Gideon Piloting 9 August 20th 04 08:36 AM
Lightspeed: Upgrade 25XL w/Cell Adaptor or Upgrade to 30 3G Andrew Gideon Products 9 August 20th 04 08:36 AM
Need software upgrade for Bendix/King KLX-100 GPSCOMM Stan Aviation Marketplace 2 August 18th 03 01:46 AM
Need software upgrade for Bendix/King KLX-100 GPSCOMM Stan General Aviation 1 August 17th 03 12:19 AM
