Hi-performance endorsment with a experimental engine
Old September 8th 03, 01:25 AM
Paul Lee
Default Hi-performance endorsment with a experimental engine
FAA requires hi-performance endorsment for 200+ engines.
Is that requirement only for certified planes?
One CFI indicated that it is not required for experimentals.
Old September 8th 03, 02:02 AM
Ed Wischmeyer
Depends on the operating limitations of the aircraft in question. There
is an FAR somewhere that says, in effect, you don't need the appropriate
ratings to be legal -- legal that is, not safe. However, frequently the
operating limitations for that individual aircraft state differently.
Ed Wischmeyer
Old September 8th 03, 05:00 PM
x
The hi-performance endorsement is for the pilot, not the aircraft.
Experimental/non-experimental is not a factor.
Also it is for greater than 200 hp, so a 200 hp does not require it.
"Paul Lee" wrote in message
om...
Old September 8th 03, 05:21 PM
Ron Natalie
"x" wrote in message news:RI17b.395481$uu5.73501@sccrnsc04...
61.31 which talks about requirements for category, class, and type ratings as
well as the tailwheel, high performance, complex, and high altitude training
requirements, has a clause that exempts experimentals from the "ratings
limitations."
High performance homebuilt in the UK NigelPocock Home Built 0 August 18th 03 08:35 PM
