PA-28 Glareshield Replacement
Old January 9th 08, 06:29 PM posted to rec.aviation.owning
Marco Leon[_4_]
Default PA-28 Glareshield Replacement
What are the options out there for replacing the glareshield fabric on Piper
Cherokees? Specifically, I have a 1978 Warrior that has some badly-faded
fabric though the tears seem to be minimal. I know I'll need to have the A&P
remove the windshield but the weatherproofing seems to be coming out of the
edges so I may need it out regardless.
Is there an STC for some new material? It seems a thin carpet-like material
would look nice but I'm not sure of the fire-resistancy and compliance.
Marco
Old January 9th 08, 07:29 PM posted to rec.aviation.owning
JGalban via AviationKB.com
Not sure what your budget is, but Dick Russ at Aircraft Door Seals sells a
full replacement glareshield that includes the eyebrow. I've seen it
installed on a couple of PA28s and it looks great. You can see it at :
http://www.aircraftdoorseals.com/pro...roducts_id=123
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200801/1
Old January 9th 08, 10:06 PM posted to rec.aviation.owning
Marco Leon[_4_]
"JGalban via AviationKB.com" u32749@uwe wrote in message
news:7df702d65f666@uwe...
a
Oooh, that's purty! $250 is actually not that bad considering it's going
into an aircraft.
Thanks John, haven't seen that yet!
Marco
Old January 11th 08, 02:18 PM posted to rec.aviation.owning
texas slacker
On Jan 9, 4:06 pm, "Marco Leon" wrote:
"JGalban via AviationKB.com" u32749@uwe wrote in messagenews:7df702d65f666@uwe... Not sure what your budget is, but Dick Russ at Aircraft Door Seals sells
a
http://www.aircraftdoorseals.com/pro...=21_24&product...
into an aircraft.
Marco
I just had my 76 warrior glareshield re-covered for $100 at an
upholstry shop. I also have a glareshield loose cover that eleminates
the reflection, like those available for a car. I don't remember
where I got it but they are out there. I don't think you have to
remove the windshield to remove the glare shield. I think you can
pull the plastic cover from the panel and the support bracket arms
unscrew from the metal panel and the whole eyebrow comes out Don't
slit your wrists, this is not that big a deal. Leo
Old January 11th 08, 03:17 PM posted to rec.aviation.owning
Marco Leon[_4_]
"texas slacker" wrote in message
Leo, how did you get it to follow the bumps on the glareshield? In my
airplane, I have a little rectangular "island" under the center post that's
raised a half-inch. My eyebrow is fine and still looks new so I'm really
just looking for to recover the area from the brow to the windshield base.
Thanks,
Marco
Old January 11th 08, 08:15 PM posted to rec.aviation.owning
texas slacker
Thanks,
Marco
Marco: I don't know, mine does not have that bump. A good upholstry
shop is going to know a lot more than I do. Leo
Old January 9th 08, 08:13 PM posted to rec.aviation.owning
John Kunkel
"Marco Leon" wrote in message
Piper Cherokees? Specifically, I have a 1978 Warrior that has some
badly-faded fabric though the tears seem to be minimal. I know I'll need
to have the A&P remove the windshield but the weatherproofing seems to be
coming out of the edges so I may need it out regardless.
material would look nice but I'm not sure of the fire-resistancy and
compliance.
Make a thin cardboard pattern of the glareshield cover and take it to one of
those places that make dashboard covers for cars, be sure to make the
cutouts for the windscreen defrost vents and the compass if applicable.
There are spray-on fabric fire retardants available.
If legality becomes an issue at annual time simply remove the cover.
Also, the existing fabric color can be rejuvenated with liquid shoe polish.
Old January 9th 08, 08:24 PM posted to rec.aviation.owning
Paul kgyy
Dennis Ashby makes a good solid fiberglass glareshield. It has enough
of an eyebrow to grab when adjusting the seat, and you can mount panel
lights underneath as well.
Dick Russ' (aircraftdoorseals) looks a lot more classy, though.
Glareshield Overhaul? Mike Spera Owning 7 March 23rd 07 11:34 PM
F-15J Replacement Prowlus Military Aviation 8 April 28th 04 02:16 PM
ASW20A Glareshield needed Tim Mara Soaring 0 April 19th 04 04:17 AM
Glareshield renewal and TSA Roger Long Owning 9 February 27th 04 12:39 PM
EP-3 replacement? user Naval Aviation 23 December 6th 03 09:46 PM
