Air travel has come a long way since the Wright brother's first flight
in 1903. Planes are now works of technological and engineering genius, screaming across the sky at 600 miles an hour while the passengers inside enjoy in-flight movies and complimentary beverage service. However, as advanced as air travel has become, there will always be one thing that plagues some air travelers regardless of the in-flight accommodations they have. That one thing is air travel sickness. Airsickness, as it's frequently called, is a form of motion sickness travelers experience when they fly. Motion/air travel sickness is caused when your central nervous system receives conflicting messages from your eyes, inner ear, and muscles. Because of high altitudes, pressure differences, and turbulence experienced when flying, your central nervous system can receive varying messages based on how each part of your body is reacting to your surroundings and the altitude. As a result, your equilibrium can be thrown off and lead to slight nausea and dizziness, the two most common symptoms of air travel sickness. However, this imbalance doesn't always lead to airsickness. In fact, most people don't experience any sort of nausea or dizziness when they fly. But that's not to say they never will. That's why it's important to know how to avoid and deal with airsickness. How to Avoid Airsickness Although it's not always feasible to avoid airsickness completely, it is possible to lessen the likelihood of it. For starters, it's always better to travel when you're in peak health. Colds and other ailments can leave you vulnerable to slight changes in altitude and temperature, making you more susceptible to air travel sickness. Stress can also make you more vulnerable to airsickness. When you're stressed, your body is not at peak performance, and flying can take a lot out of you. So if you want to avoid the airsickness bag as best you can, try to lower your stress levels before you fly. Eating a large meal before you fly can also lead to air travel sickness. The more food you eat, the more energy it takes for your body to process it, slightly lowering your body's natural ability to adjust to higher altitudes (it's too busy digesting that triple cheeseburger you ate before takeoff). So, eat a light meal before you fly. You should definitely eat something before you fly; just make sure you eat in moderation. How to Deal with Airsickness For some people, there's no way to avoid airsickness. They're just prone to motion sickness of any kind and can't avoid the nausea and dizziness. However, that doesn't mean there's no hope for these individuals. There are a few ways to deal with airsickness if you know you're more susceptible to it. Unfortunately, once you come down with airsickness, there's no real solution to alleviating its symptoms. That's why you need to plan ahead and attack airsickness before it attacks you. Here are some simple solutions to dealing with air travel sickness: - Don't read if you are prone to airsickness. The strain on your eyes will only add to the imbalance caused by motion sickness. - If you're a frequent victim of air travel sickness, take medication. If you don't want to take medication, there are non-medicated solutions available (such as motion sickness bands). In either case, ask your local pharmacist or physician which medication/solution is best for you. - Keep yourself hydrated by drinking lots of water. Your body needs water to maintain its bodily functions. If you're dehydrated, your body won't function at peak performance. Air travel sickness is one of the few downfalls of flying. It can easily turn a simple flight into an excruciating experience. However, there are simple ways to combat airsickness before it affects you. If you're flying soon, plan ahead and heed the preceding advice on how to avoid and deal with airsickness. It could drastically improve your flying experience. http://cncarrental.cn/html/art/20061002/47973.html |
One does not often die from airsickness, but people do from deep vein
thrombosis -- those nasty clots that form in your legs, then break free. It's our practice to take a couple of baby aspirin before we take off on long flights, figuring a little anticoagulation action may make an unlikely event even less likely. As far as I know, there are not studies that directly prove this is helpful, but it makes sense to us. Like all implied suggestions on the 'net, this one is worth exactly what you paid for it. On Jan 13, 4:14*am, 88059355 wrote: Air travel has come a long way since the Wright brother's first flight in 1903. Planes are now works of technological and engineering genius, screaming across the sky at 600 miles an hour while the passengers inside enjoy in-flight movies and complimentary beverage service. However, as advanced as air travel has become, there will always be one thing that plagues some air travelers regardless of the in-flight accommodations they have. That one thing is air travel sickness. Airsickness, as it's frequently called, is a form of motion sickness travelers experience when they fly. Motion/air travel sickness is caused when your central nervous system receives conflicting messages from your eyes, inner ear, and muscles. Because of high altitudes, pressure differences, and turbulence experienced when flying, your central nervous system can receive varying messages based on how each part of your body is reacting to your surroundings and the altitude. As a result, your equilibrium can be thrown off and lead to slight nausea and dizziness, the two most common symptoms of air travel sickness. However, this imbalance doesn't always lead to airsickness. In fact, most people don't experience any sort of nausea or dizziness when they fly. But that's not to say they never will. That's why it's important to know how to avoid and deal with airsickness. How to Avoid Airsickness Although it's not always feasible to avoid airsickness completely, it is possible to lessen the likelihood of it. For starters, it's always better to travel when you're in peak health. Colds and other ailments can leave you vulnerable to slight changes in altitude and temperature, making you more susceptible to air travel sickness. Stress can also make you more vulnerable to airsickness. When you're stressed, your body is not at peak performance, and flying can take a lot out of you. So if you want to avoid the airsickness bag as best you can, try to lower your stress levels before you fly. Eating a large meal before you fly can also lead to air travel sickness. The more food you eat, the more energy it takes for your body to process it, slightly lowering your body's natural ability to adjust to higher altitudes (it's too busy digesting that triple cheeseburger you ate before takeoff). So, eat a light meal before you fly. You should definitely eat something before you fly; just make sure you eat in moderation. How to Deal with Airsickness For some people, there's no way to avoid airsickness. They're just prone to motion sickness of any kind and can't avoid the nausea and dizziness. However, that doesn't mean there's no hope for these individuals. There are a few ways to deal with airsickness if you know you're more susceptible to it. Unfortunately, once you come down with airsickness, there's no real solution to alleviating its symptoms. That's why you need to plan ahead and attack airsickness before it attacks you. Here are some simple solutions to dealing with air travel sickness: - Don't read if you are prone to airsickness. The strain on your eyes will only add to the imbalance caused by motion sickness. - If you're a frequent victim of air travel sickness, take medication. If you don't want to take medication, there are non-medicated solutions available (such as motion sickness bands). In either case, ask your local pharmacist or physician which medication/solution is best for you. - Keep yourself hydrated by drinking lots of water. Your body needs water to maintain its bodily functions. If you're dehydrated, your body won't function at peak performance. Air travel sickness is one of the few downfalls of flying. It can easily turn a simple flight into an excruciating experience. However, there are simple ways to combat airsickness before it affects you. If you're flying soon, plan ahead and heed the preceding advice on how to avoid and deal with airsickness. It could drastically improve your flying experience. http://cncarrental.cn/html/art/20061002/47973.html |
More deaths from DVT, Bertie, than from you guys flying into
mountains: we call it risk/benefit analysis in clinical trials.. I had a funny image -- Anthony, getting ready for a long simulated flight by eating a couple of placebo aspirin. I know that was really unkind, and here it is, Sunday, when we should be especially charitable. I should not have posted it until tomorrow. On Jan 13, 12:18*pm, Bertie the Bunyip wrote: Tina wrote in news:c4734f94-ac8d-4506-975b- : One does not often die from airsickness, but people do from deep vein thrombosis -- those nasty clots that form in your legs, then break free. It's our practice to take a couple of baby aspirin before we take off on long flights, figuring a little anticoagulation action may make an unlikely event even less likely. As far as I know, there are not studies that directly prove this is helpful, but it makes sense to us. Like all implied suggestions on the 'net, this one is worth exactly what you paid for it. Might make you bleed to death more quickly if you crash, too. Win-win. Bertie |
On Sun, 13 Jan 2008 10:47:22 -0800 (PST), Tina wrote:
I know that was really unkind, and here it is, Sunday, when we should be especially charitable. I should not have posted it until tomorrow. A guilty pleasure I'm sure.. :- ) -- Dallas |
See & Avoid | Ol Shy & Bashful | Piloting | 27 | August 2nd 07 01:27 PM |
See and avoid... | Ramy | Soaring | 22 | January 30th 07 09:18 PM |
Airsickness | Jim Kelly | Soaring | 25 | January 17th 05 02:52 AM |
See and Avoid applies to both IFR and VFR | Brad Z | Piloting | 14 | July 17th 04 05:48 AM |
See and avoid | Kees Mies | Piloting | 39 | March 22nd 04 08:31 PM |
