Finish sanding slurry solution
Old January 13th 08, 05:40 PM posted to rec.aviation.soaring
Gregg Leslie
Default Finish sanding slurry solution
Hi Folks,
Anyone use a colored slurry solution when you are wet
sanding to finish? I see on the Polish refinish site
they use some kind of blue solution that drys. Any
idea what it is composed of?
GL
Old January 13th 08, 07:41 PM posted to rec.aviation.soaring
Udo
Gregg
Buy a can of lacquer paint, any dark colour will do.
Hold the can about 2 feet above the surface and spray horizontally
and produce a speckled surface. used a cloth wetted with thinner
and wipe, bingo you will have a nice coloured surface.
http://www.wingdolly.reach.net/image2.html
Udo
On Jan 13, 12:40*pm, Gregg Leslie
Hi Folks,
GL
Old January 13th 08, 09:15 PM posted to rec.aviation.soaring
Peter Thomas
pretty much everybody uses these in some for or other
when profiling gelcoat
red/black/blue 1 pack paint, put some in a jar, dilute
with acetone (gives very quick drying), you will have
to experement with dilution, too thin, you cant see
it, too thick and it will clog the finer grits . wipe
on with rag, we call it scumble locally, sand until
it disapears (but do not sand untill every single dot
disappears otherwise you may sand through.
for each grade of abrasive you use reapply(shows up
the scratches from the last cut)
for small areas you can use a soft graphite pencil
if you have to apply more gelcoat or fill pinholes,
wipe of residual paint with acetone first otherwise
it will be trapped under the gel
in any case wipe down with acetone before polishing
Pete
At 17:42 13 January 2008, Gregg Leslie wrote:
Hi Folks,
GL
Old January 14th 08, 02:04 AM posted to rec.aviation.soaring
Brian Bange
Go to the local auto paint store and buy a 3M product
called Dry Guide Coat. It is much, much easier than
making some concoction that needs to be sprayed or
smeared on. It has a foam applicator pad and as the
name implies, it goes on dry. It holds up to water,
yet comes right off with a swipe of sand paper. Really
good stuff, designed for this exact application. I've
tried the other methods, and found this to be far superior.
Brian Bange
Pete
Hi Folks,
GL
Old January 15th 08, 04:11 AM posted to rec.aviation.soaring
On Jan 13, 10:40 am, Gregg Leslie
Hi Folks,
GL
Take a look at the jimphoenix website.
Great finish / refinish info.
He uses blue ink and water to dye the gelcoat he
http://www.jimphoenix.com/jimphoenix...ubNimbus1.html
RJL
Mini Nimbus FK
Old January 15th 08, 06:42 AM posted to rec.aviation.soaring
Craig[_2_]
Hi Folks,
GL
He uses blue ink and water to dye the gelcoat hehttp://www.jimphoenix.com/jimphoenix...us1/subNimbus1...
RJL
Mini Nimbus FK
Udo's on the right track, but you don't even need to spend the time to
smear it around with a thinner soaked rag. A $3.00 can of semi-flat
black Krylon works great. Just mist it on to speckle the surface and
wait a few minutes for it to dry and away you go. Simple and fast.
Craig
Sanding Glider Wing [email protected] Soaring 1 February 11th 07 01:37 PM
Sanding or Waxing - PIK 20 Question culverflyer Soaring 22 September 22nd 05 09:01 PM
Advice on sanding fibreglass [email protected] Home Built 12 April 28th 05 10:39 PM
Sanding composites [email protected] Home Built 12 January 31st 05 06:47 AM
Fear of Sanding Stuart Grant Soaring 7 January 17th 05 05:28 PM
