Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Rotorcraft
and a new pilot/engineer is born.
Old January 15th 08, 04:33 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.rotorcraft
Charles Vincent
Default and a new pilot/engineer is born.
Ricky wrote:
On Jan 14, 7:19 pm, William Hung wrote:
http://gizmodo.com/gadgets/homemade-...-man-builds-wo...
Way to go Muhammed!
Wil
I remain extremely skeptical that the thing flys until I see a picture
or video of it in the air.
I mean, 133 hp?? With heavy Toyota car seats (4 of them)? Don't the
smallest helios have over 200 hp?
Ricky
Other articles on the helicopter have reported its maximum altitude as
seven feet. He is hoping to build one that will achieve fifteen feet.
Still an achievement, as that is untethered.
Charles
Old January 15th 08, 05:22 AM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.rotorcraft
cavelamb himself[_4_]
An accomplishment? Or an accident looking for a crash site?
The 12-meter-long aircraft, which has never flown above a height of
seven feet, is powered by a secondhand 133 horsepower engine from a
Honda Civic. In the basic cockpit there are two Toyota car seats, with a
couple more in the cabin behind. Controls are simple, with an ignition
button, an accelerator lever to control vertical thrust and a joystick
that provides balance and bearing. A camera beneath the chopper
connected to a small screen on the dash gives the pilot ground vision,
and he communicates via a small transmitter.
Mubarak says he learned the basics of helicopter flying through the
internet after he decided it would be easier to build a chopper than a
car. Flying his creation is easy, he claims. "You start it, allow it to
run for a minute or two and you then shift the accelerator forward and
the propeller on top begins to spin," he explains. "The further you
shift the accelerator the faster it goes and once you reach 300 rpm you
press the joystick and it takes off."
Undeterred that his home-made transporter, which lives in a hangar on
campus, lacks the gear to measure atmospheric pressure, altitude and
humidity, Mubarak is working on a new machine which "will be a radical
improvement on the first one in terms of sophistication and aesthetics."
A two-seater with the ability to fly at 15 feet for three hours at a
time, Mubarak's new creation will be powered by a brand-new motor
straight from Taiwan, normally found in motorbikes.
Old January 15th 08, 06:30 PM posted to rec.aviation.piloting,rec.aviation.homebuilt,rec.aviation.rotorcraft
Dudley Henriques[_2_]
I make it an accomplishment, AND probably also an accident waiting to
happen;hopefully not.
Just figuring out the hard numbers and applying them to available parts
and achieving untethered flight for even a few feet, considering
everything involved in doing that, marks this fellow as someone with
unusual talent.
Fron the looks of that thing however, I sincerely hope some legitimate
helo company offers this guy a steady job before his talent ends up
being wasted by his experimenting any deeper into the highly complicated
world of helo flying.
After accomplishing what he has done already, I'd not like to see him
injured or killed for lack of suitable employment.
Dudley Henriques
and a new pilot/engineer is born. William Hung[_2_] Piloting 41 January 16th 08 03:34 AM
and a new pilot/engineer is born. William Hung[_2_] Home Built 26 January 16th 08 03:34 AM
Retired military pilot was born to fly Otis Willie Military Aviation 2 July 18th 04 09:35 PM
