Dart Powered Mustang and Piper Enforcer
Old January 17th 08, 12:27 PM posted to alt.binaries.pictures.aviation
TacAN
Default Dart Powered Mustang and Piper Enforcer
I had been reading through a back issue of Australian Aviation Magazine -
September/October 1987.
And came across an article about the development of the Mustang.
The picture of the Dart powered Mustang had this caption....
Quote
Well known to Canberra residents for many years this Dart powered Mustang
never got airborne under its turboprop power and is now being rebuilt to
standard D specs.
Un-quote
(Just for the record Canberra Australia is located in our state of New South
Wales and bears the international code YSCB)
The Dart engine looks like it was lifted straight out of a Vickers Viscount
or similar.
The caption for the Piper Enforcer reads....
Quote
The final version of the long lived Mustang was the Piper Enforcer. This
Counter Insurgency aircraft was powered by a 2445shp Lycoming turboprop and
was optimised to deliver up to 5600 Lb of underwing stores while operating
out of remote and semi prepared strips.
For a variety of political and and technical reasons the aircraft never got
past initial developmental funding and the two Enforcer prototypes presently
remain in storage.
Un-quote
Does anyone have any further information on these two interesting types.
With apologies to the folk on dialup - I couldn't get the images much
smaller.
Graham
Click image for larger version
ID:	21582  Click image for larger version
Name:	Dart Powered Mustang.jpg
Old January 17th 08, 10:33 PM posted to alt.binaries.pictures.aviation
Martin Helms
"TacAN" schrieb im Newsbeitrag
Quote
standard D specs.
Un-quote
South
Viscount
or similar.
Personally, I think the "Dart" is a giveaway to the Dornier Do 335 "Pfeil"
(meaning arrow or dart in English):
http://en.wikipedia.org/wiki/Dornier_Do_335
(all pics from the article included in the post)
The "long nose" engine part certainly does look somewhat similar (to me at
least).
Just wondering why the went with a four-blade propeller instead of the
second aft-mounted three-blade one (ok, obviously saves one engine )...
ID:	21584  Click image for larger version
ID:	21585  Click image for larger version
Old January 19th 08, 12:44 AM posted to alt.binaries.pictures.aviation
Bob Walter
Re the Enforcer, I dug out our copy of Piper Aircraft by Roger W.
Peperell, published by www.airbritain.com . Roger is the official Piper
historian and has complete access to all company records.
Anyway, Roger says there were four Enforcers in two distinct programs.
The first two airframes were purchased from Cavalier Aircraft Corp in
1970 as incomplete turbo-prop conversions. The conversions were
completed at Vero Beach, powered by Lycoming's 2445 SHP T55-L-9 engine.
These airplanes had a 10,500 lb gross weight and were capable of 397 kts
with a 2550 ft-min rate of climb. Service ceiling was 42,000 ft.
The first aircraft was a two-seat dual control version designated PE2
which first flew April 28, 1971. PE2 was lost July 12, 1971 when the
tail separated from the airplane due to flutter. The test pilot safely
ejected and was rescued by a surfer just off the beach.
The second aircraft was a single-seat version designated PE1 which
first flew later in July 1971. These airplanes were equipped with six
..50-caliber machine guns and up to 10 bombs under the wings. They had
extended fuel capacity in wing tip tanks and more than twice the armor
carried by the original Mustang.
This design was submitted by Piper as the "Enforcer" in response to
the Air Force's A-X requirement, but Piper was unsuccessful and Northrup
and Fairchild were awarded contracts to produce prototypes for a fly-off
which evently yielded the A-10.
The second program was the PA-48 Enforcer. Two airplanes were built at
Piper's Lakeland facility using the PE1 as a pattern aircraft. Major
design changes included: lengthening the aft fuselage 19-inches,
stregthening the wing to support a 14,000 lb. gross weight, new
ailerons, raising the canopy and seat 1.5 inches to improve over the
nose visibility, a new rudder, tail-plane and tail cone. These
airplanes were also powered by Lycoming's 2445 SHP T55-L-9 engine and
used a cut-down A-1E Skyraider four-bladed propeller. They were capable
of 350 kts with a 4790 ft-min rate of climb. Service ceiling was 37,600
ft.
The first airplane, EN-1, first flew April 9, 1983 and was used to
test performance, stability and control systems.
The second airplane, EN-2, first flew July 8, 1983 and was to be the
weapons testbed. It was equipped with six under-wing pylons and was to
carry the G.E. Gepod 30mm 4-barrel rotary cannon.
These airplanes were delivered to the Air Force in late 1984 for
trials. There is no evidence the trials were ever conducted. Both
airplanes were in U.S.A.F. museums in the 1990's: one at Dayton and the
other at Edwards.
Enjoy, Bob
"TacAN" wrote in message
Quote
standard D specs.
Un-quote
South Wales and bears the international code YSCB)
Viscount or similar.
Quote
and was optimised to deliver up to 5600 Lb of underwing stores while
operating out of remote and semi prepared strips.
got past initial developmental funding and the two Enforcer prototypes
presently remain in storage.
Un-quote
smaller.
Graham
Old January 19th 08, 04:52 AM posted to alt.binaries.pictures.aviation
Glenn[_2_]
at one point one was in Canberra in Australia.
I missed it :-( And at that time, I even lived at the airport.
http://www.warbirdz.net/phpBB2/showt...ighlight=turbo
"Bob Walter" wrote in message
ft.
other at Edwards.
Enjoy, Bob
Quote
standard D specs.
Un-quote
Quote
Un-quote
smaller.
Graham
Old January 20th 08, 12:17 AM posted to alt.binaries.pictures.aviation
TacAN
The one pictured apparently is the same one that was based at Canberra.
Certainly pre-1987 - if someone could "date" the "xxxxxx Aviation Terminal"
in the background, it might give a better idea when this picture was taken.
Unfortunately the article in the October 1987 Australian Aviation magazine
mentioned no time frame for the Dart powered Mustang.
Cheers
Graham
"Glenn" wrote in message
Old January 23rd 08, 03:00 PM posted to alt.binaries.pictures.aviation
Russell
For a few years it was near the south fence at Canberra with a tarp covering
it. I remember seeing it from the road.
ft.
other at Edwards.
Enjoy, Bob
Quote
Mustang never got airborne under its turboprop power and is now being
rebuilt to standard D specs.
Un-quote
Quote
Un-quote
smaller.
Graham
Old January 20th 08, 12:09 AM posted to alt.binaries.pictures.aviation
TacAN
Hi Bob
Thanks so much for all the additional.
Cheers
Graham
Old January 25th 08, 11:35 AM posted to alt.binaries.pictures.aviation
Dave Kearton
Magazine - September/October 1987.
smaller.
Graham
Hey cool, I found my picture. I took this on holiday in '78 in
Canberra.
Cheers
Dave Kearton
Name:	Dart powered Mustang, Canberra Airport , January '78.jpg
Old January 28th 08, 01:15 AM posted to alt.binaries.pictures.aviation
TacAN
"Dave Kearton" wrote in message
smaller.
Graham
Canberra.
Cheers
Dave Kearton
Good one, Dave. :-))
Thanks
Graham
Old January 28th 08, 07:39 AM posted to alt.binaries.pictures.aviation
Dave Kearton
| smaller.
| Graham
| Canberra.
| Cheers
| Dave Kearton
| Thanks
| Graham
Well, cover me with honey and throw me to the lesbians .....
Here's the second photo I took that day, found by the wife, under an
ancient pile of books in the 'spare' room.
Cheers
Dave Kearton
Name:	Dart powered Mustang, Canberra Airport , January '78      2.jpg
Mustangs Of Old - North American P-51D Mustang Rare Korean Mustang - 07.jpg (1/1) Mitchell Holman Aviation Photos 0 December 29th 06 05:34 AM
Mustangs Of Old - North American P-51D Mustang Rare Korean Mustang - 05.jpg (1/1) Mitchell Holman Aviation Photos 0 December 29th 06 05:34 AM
Mustangs Of Old - North American P-51D Mustang Rare Korean Mustang - 04.jpg (1/1) Mitchell Holman Aviation Photos 0 December 29th 06 05:34 AM
Mustangs Of Old - North American P-51D Mustang Rare Korean Mustang - 03.jpg (1/1) Mitchell Holman Aviation Photos 0 December 29th 06 05:34 AM
Mustangs Of Old - North American P-51D Mustang Rare Korean Mustang - 02.jpg (1/1) Mitchell Holman Aviation Photos 0 December 29th 06 05:34 AM
