SB-912-056: MANDATORY REPLACEMENT OF ROTAX PROPELLER GEARBOX, ENGINES TYPE 912/914
Old February 4th 08, 05:08 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.homebuilt
Larry Dighera
Default SB-912-056: MANDATORY REPLACEMENT OF ROTAX PROPELLER GEARBOX, ENGINES TYPE 912/914
Below are excerpts from these mandatory Rotax 912/914 service
bulletins:
http://www.rotax-owner.com/SI_TB_Inf...SB-912-056.pdf
TYPE 912/914
Compliance
- during the next maintenance event
- at the latest April 30th 2008.
Reason
Due to a slightly increased amount of irregularity in the form of
material inclusions some isolated problems were detected on the
gearbox and/or the gear set in the field.
Such material inclusions in the area of the tooth base can lead to a
tooth break under severe operating conditions.
Normally broken metal fragments are dropping to the lower portion of
the gearbox and are retained captive by the magnetic plug, but in
individual cases they may get squeezed by rotating gear sets further
damaging the gearbox housing.
Propeller gearboxes affected
- propeller gearboxes with a serial number listed below:
03.0310 / 03.0311 / 03.0313 / 03.0316 / 03.0408 / 03.0418 / 03.0433 /
03.0436 to 03.0452 / 03.0493 to 03.0562 / 03.0595 to 03.0679 / 03.0699
to 03.0778 / 03.0802 to 03.0814 / 03.0816 to 03.0856 / 03.0867 to
03.0876 / 03.0898 to 03.0985 / 03.1011 to 03.1048 / 03.1062 to 03.1124
/ 03.1128 to 03.1138 / 03.1140 / 03.1169 to 03.1174 / 03.1179 to
03.1247 / 03.1249 / 03.1251 / 03.1286 to 03.1294 / 03.1296 to 03.1308
/ 03.2063 to 03.2078 / 03.2080 / 03.2082 / 03.2084 to 03.2091 /
03.2106 / 03.2107 / 03.2118 to 03.2136 / 03.2152 to 03.2182 / 03.2197
to 03.2257 / 03.2259 to 03.2285 / 03.2348 to 03.2397 / 03.2399 to
03.2402 / 03.2404 / 03.2405 / 03.2407 / 03.2409 to 03.2418 / 03.2421 /
03.2423 / 03.2425 / 03.2426 / 03.2430 / 03.2431 / 03.2433 / 03.2435 /
03.2437 / 03.2438 / 03.2440 / 03.2476 to 03.2483 / 03.2485 / 03.2487 /
03.2490 / 03.2491 / 03.2493 / 03.2495 to 03.2498 / 03.2500 to 03.2517
/ 03.2519 to 03.2611 / 03.2628 to 03.2729 / 03.2735 to 03.2737 /
03.2759 to 03.2826 / 03.2832 to 03.3007 / 03.3046 / 03.3055 to 03.3127
/ 03.3129 / 03.3132 to 03.3149 / 03.3187 to 03.3337 / 03.3339 to
03.3362 / 03.3364 / 03.3366 to 03.3378 / 03.3443 to 03.3506 / 03.3508
to 03.3510
Instructions
3.1.1) Remove of the propeller gearbox
1. Lock the crankshaft
2. Remove the propeller gearbox. Perform relevant work depending on
gearbox type in accordance with
the current Maintenance Manual. The propeller gearbox needs to be sent
to a ROTAX® Authorized
Distributor for repair.
3. Install the new propeller gearbox.
4. Restore aircraft to original operating configuration.
5. Connect negative terminal of aircraft battery.
6. Conduct test run including ignition check and leakage test.
CAUTION: After the exchange of the propeller gearbox it is necessary
to check the oil filter in accordance with the latest relevant
Maintenance Manual (Line Maintenance, chapter 12-00-00).
Additional mandatory 912/914 service bulletins:
http://www.rotax-owner.com/SI_TB_Inf...-912-056UL.pdf
Old February 4th 08, 05:36 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.homebuilt
Bertie the Bunyip[_25_]
Larry Dighera wrote in
bulletins:
Good lord. Your life must be as gray as Eeyore's ass.
Bertie
Old February 4th 08, 09:47 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.homebuilt
Peter Dohm
"Bertie the Bunyip" wrote in message
bulletins:
Bertie
I'm not so sure he has a life. Sort of like he who shall not be named.
Peter
Old February 4th 08, 10:55 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.homebuilt
Peter Clark
On Mon, 4 Feb 2008 16:47:29 -0500, "Peter Dohm"
bulletins:
Bertie
Oh no, is Voldemort online now?
Old February 4th 08, 10:58 PM posted to rec.aviation.piloting,rec.aviation.owning,rec.aviation.homebuilt
"Peter Dohm" wrote in news:NJLpj.66137$Mu4.14547
@bignews7.bellsouth.net:
bulletins:
Bertie
So many to choose form these days.
Bertie
SB-912-056: MANDATORY REPLACEMENT OF ROTAX PROPELLER GEARBOX, ENGINES TYPE 912/914 Larry Dighera Piloting 6 February 4th 08 11:01 PM
Rotax 532 Type A Reduction Drive Question [email protected] Rotorcraft 0 April 28th 06 03:06 AM
Rotax (C) gearbox for sale , Brand new GASSITT Aviation Marketplace 0 March 4th 04 03:13 PM
New product: reduction gearbox for Subaru and Suzuki engines Mr.Twistair Home Built 2 January 25th 04 10:02 PM
New product: reduction gearbox for Subaru and Suzuki engines Mr.Twistair Aviation Marketplace 3 January 25th 04 10:02 PM
