PC power using aircraft ground
Old February 5th 08, 02:03 AM posted to rec.aviation.owning, rec.aviation.homebuilt
Default PC power using aircraft ground
I run a Motion LS800 for my EFB. I use a DC 12V to 19V power
converter to power my LS800 since I have a 12V aircraft system.
To minimize the number of wires, can I use a single wire to run +19V
from the power converter to LS800 and connect the ground from power
converter to LS800 thru the airfram ground?
Thanks in advance,
Robin Hou
Old February 5th 08, 02:26 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Bill Daniels
" wrote in message
Thanks in advance,
Robin Hou
No answer on the ground wire but how do you like the LS800? Do you have the
"View Anywhere" screen and/or the SSD drive?
Bill D
Old February 5th 08, 03:26 AM posted to rec.aviation.owning, rec.aviation.homebuilt
rmhou at yahoo.com
On Feb 4, 6:26*pm, "Bill Daniels" bildan@comcast-dot-net wrote:
No answer on the ground wire but how do you like the LS800? *Do you have the
Bill D
I have been using Jeppview FliteDeck for 3 years now on an old laptop
with a cheap touch screen car monitor. Just got the Motion 2 months
ago. The LS800 w/ View Anywhere screen is more readable with a lot
less wires running thru my aircraft. Overall it is a plus compare
with my last setup. But the requirement of a stylist as the pointing
device is a drag. If I have to do it over, I will go with a
transreflective car monitor w/ touch screen like this:
http://store.mp3car.com/category_s/82.htm
I don't have the SSD drive. I have been to 11,500 for more than 2
hours without problem. I will switch to a SSD drvie on the first sign
of HD problem, or when I turbo normalize my airplane after I win the
lotto ;-)
Old February 5th 08, 03:56 AM posted to rec.aviation.owning,rec.aviation.homebuilt
Bill Daniels
"rmhou at yahoo.com" wrote in message
Bill D
lotto ;-)
I'd been looking at the LS800 for use in my glider. The touch screen is not
ideal but it can be made to work. I've also thought about building my own
system. I have the software I want and the Via Pico ITX computer runs it
fine with little battery drain. The problem is a high visibility, low power
monitor. I haven't found one I like yet.
Bill D
Old February 6th 08, 02:43 AM posted to rec.aviation.owning,rec.aviation.homebuilt
clare at snyder.on.ca
On Mon, 4 Feb 2008 19:26:44 -0700, "Bill Daniels"
" wrote in message
Thanks in advance,
Robin Hou
Bill D
The short answer to the ground question is "yes"
Posted via a free Usenet account from http://www.teranews.com
FS: 60' Aircraft ground power cable, 6-conductor, copper - $480 [email protected] Aviation Marketplace 0 May 16th 06 01:55 AM
Permit to use aircraft radio frequencies on ground C. J. Clegg General Aviation 23 January 20th 05 07:23 PM
Permit to use aircraft radio frequencies on ground C. J. Clegg Restoration 1 January 1st 05 10:08 PM
Predicting ground effects on induced power Marc Shorten Soaring 0 October 28th 03 11:18 AM
NEEDED: Aircraft Ground Handling Information Jarry Clausing Products 0 August 9th 03 03:24 PM
