The subject of checklist use has come up in another thread and I thought it
deserved its own. I was recently told that the compulsory use of written checklists originated with the introduction of the B17 which was experiencing a high degree of incidents caused by procedural deviations. It was felt that the complexity of the aircraft required the adoption of formalized written procedures best accomplished by the use of written checklists. My flight training emphasized correct checklist usage and their proper use in a team environment is a big part of proper CRM. IHBT the fastest way to fail a flight test is failure to properly utilize checklists and I have heard of examiners failing an applicant (before taking the runway) as a result of failure to use proper written checklists for startup and preflight. I have recently read of the adoption of written checklists in medical treatment which has significantly reduced medical mistakes and malpractice. I am currently engaged in a project involving the introduction and implementation of written checklists in heavy industrial construction and maintenance and would appreciate comments and particularly links to articles regarding checklist usage and implementation. TIA |
On Feb 5, 11:36*am, "Private" wrote:
The subject of checklist use has come up in another thread and I thought it deserved its own. I was recently told that the compulsory use of written checklists originated with the introduction of the B17 which was experiencing a high degree of incidents caused by procedural deviations. *It was felt that the complexity of the aircraft required the adoption of formalized written procedures best accomplished by the use of written checklists. My flight training emphasized correct checklist usage and their proper use in a team environment is a big part of proper CRM. *IHBT the fastest way to fail a flight test is failure to properly utilize checklists and I have heard of examiners failing an applicant (before taking the runway) as a result of failure to use proper written checklists for startup and preflight. I have recently read of the adoption of written checklists in medical treatment which has significantly reduced medical mistakes and malpractice.. I am currently engaged in a project involving the introduction and implementation of written checklists in heavy industrial construction and maintenance and would appreciate comments and particularly links to articles regarding checklist usage and implementation. TIA Just as an aside note. Most pilots use "do lists" although some use "check lists". A true checklist is only referenced after you believe you have already completed all the tasks. Its just a "check". A "do list" is a list of instructions to do and is what most pilots do. -Robert |
Private wrote:
The subject of checklist use has come up in another thread and I thought it deserved its own. I was recently told that the compulsory use of written checklists originated with the introduction of the B17 which was experiencing a high degree of incidents caused by procedural deviations. It was felt that the complexity of the aircraft required the adoption of formalized written procedures best accomplished by the use of written checklists. My flight training emphasized correct checklist usage and their proper use in a team environment is a big part of proper CRM. IHBT the fastest way to fail a flight test is failure to properly utilize checklists and I have heard of examiners failing an applicant (before taking the runway) as a result of failure to use proper written checklists for startup and preflight. I have recently read of the adoption of written checklists in medical treatment which has significantly reduced medical mistakes and malpractice. I am currently engaged in a project involving the introduction and implementation of written checklists in heavy industrial construction and maintenance and would appreciate comments and particularly links to articles regarding checklist usage and implementation. TIA There are several prime factors involved with the use of checklists. The possibility of omission is obvious of course, but right along with this factor and directly related and equally important is the sequential factor. This aspect of the checklist equation takes into account that a downstream item requiring an action depends on the upstream item being preformed first. In the aircraft application, both of these factors are of prime importance. I would imagine other checklist scenarios will be the same. Of course there are the psychological factors as well. These include distraction and over tasking; both of which are critical to proper CRM and SA. The bottom line on checklists is that they are necessary in the complicated scenarios where they are used. Peripheral to the checklist itself is the issue of flow pattern, where the properly written checklist follows a set pattern of flow whenever and where ever possible. This flow is an added aid that allows the following of the checklist to an optimized standard in minimum time. -- Dudley Henriques |
On Tue, 05 Feb 2008 15:02:33 -0500, Dudley Henriques
wrote in : The possibility of omission is obvious of course, but right along with this factor and directly related and equally important is the sequential factor. This aspect of the checklist equation takes into account that a downstream item requiring an action depends on the upstream item being preformed first. Right. For example, before engine start I switch to the least full tank, start the engine, then switch to the fullest tank later. That way I have verified that fuel can be drawn from both tanks. It's difficult to do that sort of thing with an unwritten 'flow' type (non)checklist. |
Larry Dighera wrote:
It's difficult to do that sort of thing with an unwritten 'flow' type (non)checklist. No, it's really not. My engine start procedure has me select the least full tank before start. The runup procedure has me switch to the other (fullest) tank. |
the properly written checklist follows a set pattern of flow whenever and where ever possible. This flow is an added aid that allows the following of the checklist to an optimized standard in minimum time. -- Dudley Henriques- In a way it's not really peripheral, rather integral. Older checklists, from say a 1975 150 are flow-wise pretty disorganized compared to even 5 years later, 1980. Didn't the FAA get involved with the flow of checklists in that time frame? Anyway I definitely see a huge improvement in those 5 years from a flow perspective. I even write my own checklists that I use to make sure I test all the scenarios that need to work in software I write BEFORE even sending it to the QA department. Checklists for complex industrial construction? I'd have hoped that would have been in use for years! ![]() |
Pre-Lunch checklists | 01-- Zero One | Soaring | 9 | January 28th 06 10:38 PM |
Pre-launch checklists | John Brenann | Soaring | 2 | January 27th 06 04:27 PM |
Pre-launch Checklists. | keithw | Soaring | 0 | January 26th 06 02:54 AM |
maintenance checklists | tony roberts | Owning | 2 | January 25th 05 10:59 PM |
Where to buy MU-2 Checklists and books? | Rob C. | Owning | 3 | March 15th 04 01:08 AM |
