What glue to use for replacing cockpit interior fabric
Old February 6th 08, 12:38 PM posted to rec.aviation.soaring
Gary Emerson
Default What glue to use for replacing cockpit interior fabric
Greetings,
I've got a SH glider. Have ordered new cockpit interior fabric, and am
ready to glue them in. Old fabric is removed, but there is some
residual glue on the cockpit sides that is pretty well stuck that I'd
prefer not to have to remove.
Asked SH, but got no reply.
One pilot suggested Pliobond, but it has a stronger odor that lingers
after it dries that I'm really not very excited about.
Has anyone used the Weldwood contact cement successfully or is there
another lower odor cement/glue that is recommended???
Many thanks in advance!
Gary
Old February 6th 08, 01:42 PM posted to rec.aviation.soaring
JJ Sinclair
On Feb 6, 4:38*am, Gary Emerson wrote:
Greetings,
I've got a SH glider. *Have ordered new cockpit interior fabric, and am
ready to glue them in. *Old fabric is removed, but there is some
Gary
Contact cement's the way to go. Stir well, apply to both surfaces, let
it dry for 15 minutes, put in place (be careful to get it started in
the exact right place), hammer it down everywhere with a rubber
mallet.
JJ
Old February 6th 08, 02:23 PM posted to rec.aviation.soaring
Gary Emerson
JJ,
Which glue have you used? Weldwood? Pilobond?? other?
Thanks,
Gary
JJ Sinclair wrote:
On Feb 6, 4:38 am, Gary Emerson wrote:
Greetings,
Gary
mallet.
JJ
Old February 6th 08, 10:54 PM posted to rec.aviation.soaring
JJ Sinclair
Weldwood works for me. I have found that "tapping" the two pieces
together with a rubber mallet will insure good gontact between both
surfaces. Don't "Hammer" so hard as to crack the gel-coat. Contact
cemented velcro doesn't hold in the heat, even if you "hammer" it
down.
:) JJ
Old February 6th 08, 02:59 PM posted to rec.aviation.soaring
I'm not sure I would want to "hammer" against my cockpit structure
with a rubber mallet or anything else. Can you say cracking gelcoat?
If it was my glider, I would carefully fit the fabric and apply
contact cement to Velcro strips around the edges. More strips on the
cockpit surface and the fabric can be removed for cleaning.
MSM
mallet.
JJ- Hide quoted text -
- Show quoted text -
Old February 6th 08, 07:13 PM posted to rec.aviation.soaring
Decent idea. But in the heat, the velcro bond is stronger than the
contact cement and you'll just end up pulling all the velcro up. Use
plumbers goop.
Old February 7th 08, 12:28 AM posted to rec.aviation.soaring
Todd
I am not sure I would beat the k... out of my glider. They make a
tool called a J-Roller for this purpose. Not real expensive, and
might be hanging right next to the contact cement at your local home
center. Or find a friend who likes to make cabinets (Formica type
stuff) and borrow his. Then roll the k... out of everything.
I agree, wait till a warm day. If it is too cold, especially for the
non-solvent contact cements, they take forever to dry to the tacky
state.
And don't forget, once the 2 pieces touch each other, they are not
going anyplace. Given all the weird shapes you will be working with,
I would figure out the final assembly BEFORE any cement is applied.
Wax paper, parchment paper between the glider and carpet might work
well to permit you to reposition before you slowly pull the paper out.
Old February 7th 08, 03:03 AM posted to rec.aviation.soaring
Gary Emerson
state.
Fortunately, I have a J roller from putting down the Formica on my
workbench. The wax paper is a great idea.
Thanks!
Old February 6th 08, 03:51 PM posted to rec.aviation.soaring
Greetings,
Gary
To get the best bond of the new fabric, regardles of what glue you
use, you will need to remove the old residue first. Time, scotchbrite
pads, and 3M General Adhesive Cleaner http://www.3mestore.com/62478765092.html
Old February 7th 08, 03:19 AM posted to rec.aviation.soaring
Peter[_4_]
I found the old fashioned "DAP" contact cement working the best. I am sure
others are fine as well. The ones to stay away from are the "green",
environmentally friendly labeled adhesives. They don't work worth a crap!
PeterK
Greetings,
Gary
Replacing Cockpit placards toad Soaring 9 March 28th 06 03:04 PM
Pirep on replacing interior plastic parts [email protected] Owning 1 April 12th 05 05:06 AM
Cobra Interior Carpet Glue Brian Iten Soaring 7 August 24th 04 05:35 AM
Looking for pics of SU-24 Fencer cockpit interior Boomer Naval Aviation 0 March 6th 04 12:43 AM
Looking for pics of SU-24 Fencer cockpit interior Boomer Military Aviation 0 March 6th 04 12:42 AM
