earliest turbine powered helicopter?
Old January 2nd 04, 05:28 AM
Charles Gray
Default earliest turbine powered helicopter?
When was the earliest turbine powered helicopter? I khnow that the
turbine is far more effective than an IC engine.
Also, what was the delay? Was it just a matter of nobody really got
around to it, or were there power/reliability issues with the
turbines?
Old January 2nd 04, 12:47 PM
The Enlightenment
"Charles Gray" wrote in message
got
turbines?
I know that Dr Franz Anselem set his personal goal as the development
of a gas turbine engine for helicopters for which he saw that their
protperties would be hugely advantageous. I think this would be the
first such engine. The result was the T53 from Avco Lycoming. It
was used on the UH1 Iroquoise, Mohawk, XV-15 as well as the (scaled
up) T55 used on the Chinook and I believe as the core of the BAe 146s
regional jet liner when it was given a geared fan.
Anselem also headed development of the AGT 1500 for the M1 Abrams
tank.
Anselem is probably most famouns for his turbojet the Junkers Jumo 004
which he developed for the Messerscmitt Me 262 while working at
Junkers.
The T53 was a pretty engine.
This is what the Soviets list as advantages of Gas turbines for tanks.
The T-80U's gas-turbine power plant has a number of advantages over a
diesel engine as it provides for:
- higher maneuverability and tactical mobility; higher medium and
maximum traveling speeds provided by the highest (among
domestically-produced engines) specific power of 26.9 hp/t (19.8
kW/t);
- high combat readiness in low ambient temperature conditions owing to
rapid engine starting;
- higher mobile fire effectiveness owing to lower vibration level at
gunner's and commander's stations, smoother curvilinear motion owing
to a wider choice of speed gears (from zero to the highest gear) and
optimal motion conditions at an engaged gear;
- lower (by a factor of eight) heat transfer to engine oil and absence
of a water cooling system, which significantly reduces the area of
weakened zones on the cover of engine/transmission compartment;
- reduced power consumption by the cooling system (by 50 percent);
- reduced labor intensity of maintenance services (by 50 percent); no
seasonal maintenance is required;
- reduced engine (monoblock) replacement time (by a factor of five or
six);
- reduced number types of fuels, oils and lubricants (by a factor of
three for round-the-year operation);
- ability to climb ice-covered upgrade slopes and move across terrain
where soils feature low load-carrying capacity. This has been achieved
owing to the smooth application of torque and use of the
gas-turbine-to-turbo-compressor gas coupling;
- easy tank steering owing to the specific engine features and
trouble-free engine operation under heavy loads;
- less crew fatigue owing to the low vibration and noise levels and
smoother torque application;
- reduction of such signatures as thermal emission; smoke, engine
noise, etc.;
- use of a less complex remote control system.
Old January 2nd 04, 04:13 PM
robert arndt
Charles Gray wrote in message . ..
turbines?
Kaman K-225:
http://www.nasm.si.edu/research/aero...kamen_k225.htm
Rob
Old January 2nd 04, 04:16 PM
robert arndt
turbines?
Kamen K-225 color jpg in museum:
http://www.neam.org/images/k225_lg.jpg
Rob
Old January 2nd 04, 11:35 PM
QDurham
Then ther's always the Hiller ram-jet powered copter. I understand its noise
broke windows far and wide. Also was quite a spectacle when operated at night
-- particularly on startup.
Quent
Old January 2nd 04, 04:31 PM
Ariennya Romani
turbines?
Although Italy was working on one, the French Ariel III was first
http://www.awgnet.com/shownews/01hai1/intell04.htm
Ariennya Romani
Old January 2nd 04, 04:52 PM
John Hairell
turbines?
The initial concepts of turbine-powered helicopters were for the
engines (basically compressors) to feed a fuel/air mix to the rotor
blade tips. i.e. ramjets. Part of this research was done in WWII
Austria by Friedrich von Doblhoff, who went on to McDonnell post-war.
Late in the war several test articles were designed, built, and
somewhat "flown", normally to immediate destruction.
The concept survived into the '50s, when the French SNCASO Ariel III
test aircraft first flew on April 18th, 1951. The last Ariel used a
Turbomeca Artouste I turbine engine. The Djinn model (first flight
January 2nd, 1953) was partially derived from the Ariels and was
produced into the '60s. It used a Palouste gas generator to send gas
to the blade tips.
All of the tip-driven helicopters had a common problem - they were
very noisy and used huge quantities of fuel. Compressed air and fuel
fed to the blade tips proved to be a technological dead end and the
industry eventually went to the turbine driving the rotor blades via
shafts/belts and transmissions. The manufacture of small but powerful
turbine engines light enough to be used in helicopters all but killed
the ramjet idea.
In December 1951 a Boeing 502 turbine engine powered a Kaman K-225.
On July 24th, 1953 Sikorsky flew the turbine-powered S-52 using a
Turbomeca Artouste I. On March 12th, 1955 the Sud-Est SE 3130
Alouette II became the first turbine-powered helicopter to go into
series production.
John Hairell )
Dennis Fetters Mini 500 EmailMe Home Built 70 June 21st 04 09:36 PM
Musings of a Commercial Helicopter Pilot Badwater Bill Home Built 6 February 27th 04 09:11 AM
Water Cooled Jet Engines: a possibillity then and now? The Enlightenment Military Aviation 3 December 18th 03 09:41 AM
After 23 years, Marines get last Super Stallion CH-53E helicopter Otis Willie Military Aviation 0 November 25th 03 10:04 PM
