Cost of IGC approved loggers
Old February 11th 08, 10:12 AM posted to rec.aviation.soaring
Default Cost of IGC approved loggers
Are IGC approved loggers too expensive? What is there cost point
compared to a Barograph and camera setup? I.E. The cost of a Colibri
logger compared to the cost of an approved Barograph (in 2008
dollars). I don't know the cost of a barograph 20 years ago (in there
heyday) but they could not have been cheap.
Also, are clubs and individuals making loggers available to newer
pilots for badge flights as barographs were?
Just some pondering.
Bob
Old February 11th 08, 02:21 PM posted to rec.aviation.soaring
Adam
On Feb 11, 4:12*am, "
Bob
Of course they are too expensive!
Our club took up doantions and bought a EW Avionics Microrecorder.
About $800.
http://www.ewuk.co.uk/
It is very compact, portable, and very easy to use. Anyone in the club
is welcome to use it.
/Adam
Old February 11th 08, 02:43 PM posted to rec.aviation.soaring
HL Falbaum
A used, good condition Replogle Barograph can be bought for under 250 USD.
Two Cameras--200 USD.
Homemade camera mount--15 USD
Barograph paper, film and processing all cost--??10 USD per flight.
Recalibration annually 35 USD as opposed to every two years for approved
logger.
If you ask around, someone might have the barographs and cameras they will
give you--maybe---if you are lucky.
Turnpoint photography is tricky and sometimes dangerous. Shoot a bunch of
pictures and have an old-timer look at them before you count on it.
Our club has a old model Volkslogger available for use--Quirky; and a B
model EW --even quirkier (is that a word?)
Most members have not even read the manual--on the website.
Hartley Falbaum
MGSA-Georgia, USA
"Adam" wrote in message
On Feb 11, 4:12 am, "
Bob
About $800.
/Adam
Old February 11th 08, 03:29 PM posted to rec.aviation.soaring
Cats
snip
That sounds expensive for two second hand 35mm cameras with pretty
basic requirements - a tripod screw thread (for ease of mounting), and
auto wind-on. Is b&w film acceptable? If so a developing drum is
cheap again of Ebay.
However I can't think of a single reason I'd want to do it that way.
If nothing else looking at the trace from a flight recorder can be
very interesting, though I conceed that if you are not bothered about
it being valid for claiming badges, just about any Garmin GPS can be
plugged into a PDA running free software giving a cheap way of
recording flights. My club provides barographs (EW-B) for all club
single-seat gliders which does for Bronze (if not done by direct
observation) and Silver badges.
Old February 11th 08, 03:43 PM posted to rec.aviation.soaring
SoaringXCellence
On Feb 11, 7:29*am, Cats wrote:
On Feb 11, 2:43*pm, "HL Falbaum" wrote: A used, good condition Replogle Barograph can be bought for under 250 USD.
snip
auto wind-on. *Is b&w film acceptable? *If so a developing drum is
recording flights. *My club provides barographs (EW-B) for all club
The Willamette Valley Soaring Club has an older Colibri available to
any member to use. We also have a number of Palm/GPS setups in the
club that are used for "recording" flights. In several cases the Palm
units are cliped to a GPS unit that clips directly to the unit and
also provides power for the Palm. Very convenient and easy to move
between gliders.
Old February 11th 08, 03:45 PM posted to rec.aviation.soaring
SoaringXCellence
snip
any member to use. *We also have a number of Palm/GPS setups in the
club that are used for "recording" flights. *In several cases the Palm
also provides power for the Palm. *Very convenient and easy to move
between gliders.- Hide quoted text -
- Show quoted text -
By the way. Thos Palm GPS units can be put together for under $200
and you'll not only have a logger but a flight computer as well.
Old February 11th 08, 02:44 PM posted to rec.aviation.soaring
Pat Russell
A couple of points:
1. IGC really hates it when you call these things "loggers." They
prefer "Flight Recorders."
2. In a couple of weeks, they will vote on eliminating cameras and
barographs from the Sporting Code.
-Pat
Old February 13th 08, 01:12 AM posted to rec.aviation.soaring
On Feb 11, 10:03*am, Nyal Williams
Oh?
What about those contest pilots who have lost whole
days because they screwed up using a CFR?
Key here is "THEY" screwed up. It's rarely a hardware problem. With
turnpoint camera and baro attempts, the film processors can screw you
up, the OO can forget one little mark on the trace that will cost you
a badge, the canopy mark (impossible to verify until the film is
developed) might not show up, or might obscure your picture, the
clockwork mechanism of the baro itself can hang up. On top of that,
you need to calibrate the baro twice as often, and I've had a mis-
marked calibration trace cost me a badge leg too.
Old February 13th 08, 08:49 AM posted to rec.aviation.soaring
Ian
On 13 Feb, 01:12, wrote:
On Feb 11, 10:03 am, Nyal Williams
All good points - and electronics, as we all know, never go wrong. But
that aside, I simply can't see the point of banning older forms of
flight verification (I believe we're losing ground observers as
well).
One answer, of course, is for another authority besides the FAI to
issue badges.
Ian
OLC Loggers RN Soaring 8 November 17th 07 12:11 AM
A Preliminary Assessment of the Potential Cost and Cost-Effectiveness of Space-Based Weapons. Mike[_7_] Naval Aviation 0 November 2nd 07 03:18 PM
Pressure Altitude in Loggers ContestID67 Soaring 2 June 12th 07 02:41 AM
IGC loggers again tango4 Soaring 3 July 14th 04 05:50 PM
Vanity Loggers? Steve Soaring 0 October 5th 03 03:54 AM
