Aviation maths for Pro !!
Old February 12th 08, 07:23 PM posted to rec.aviation.piloting
Paul[_1_]
Default Aviation maths for Pro !!
I'm trying to find out a formulae regarding the gap between Takeoff
Distances by POH and real-life measures. I did the maths for wind,
temperature, pressure altitude, runway slope, weight, etc. It's quite
detailled and effective...
But...
The only calculation I don't know how to "translate" is the difference, in
feet, between the POH speed and the speed I did during the test.
For example: If my airplane took off at 1050 feet on the initial roll, at 62
knots, how many feet will I need if left the runway at 56 kts ? POH states
it requires only 699 feet at 56kts for the same factors (temp, press, etc)!
Thank you
Paul
Old February 12th 08, 08:46 PM posted to rec.aviation.piloting
WingFlaps
But...
I think most of the POH takeoff figures are not theoretical
calculations but the results of actual tests. As such they are
affected by factors outside aerodynamics -runway surface roughness,
tyre performance and pilot skill being factors in rolling distance. In
other words I don't think a simple equation will give you the "right"
answer. For a first order approximation consider kinetic energy build
up.
Cheers
Old February 13th 08, 01:00 PM posted to rec.aviation.piloting
terry
But...
I think you will struggle to find a simple calculation ( or a
difficult one for that matter) . why dont you just try testing your
takeoff distance at the same speed as the POH reccomends? May I ask
what aircraft you are flying? and what did you find with your
mathematical studies, and did you read my earlier thread on
"Confusion with Cessna take off distance " where I found that after
converting pressure ht and temperature to density altitude that there
was still a temperature effect on the take off distance required. I
would be interested to know if you saw something similar wtih your
data?.
Terry
PPL Downunder
Old February 13th 08, 05:37 PM posted to rec.aviation.piloting
Bertie the Bunyip
But...
I've got a couple at home and I'll check for you when I get there, but
like I told you before, it all depends on the approach the engineer
takes and you're not going to get any real precision out of them
FA: 3 Advanced AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Derek Aviation Marketplace 0 September 3rd 07 03:17 AM
FA: 1-Day-Left: 3 AVIATION Books: Aviation Electronics, Air Transportation, Aircraft Control and Simulation Jeff[_5_] Aviation Marketplace 0 September 1st 07 01:45 PM
ENHANCED AVIATION SECURITY PACKAGE ANNOUNCED (All "General Aviation Pilots" to Pay $200.00 every two years!) www.agacf.org Piloting 4 December 21st 03 10:08 PM
where's the THRILL is flying, rec.aviation.balloon,   rec.aviation.hang-gliding, rec.aviation.powerchutes, rec.aviation.soaring BW Rotorcraft 0 October 15th 03 12:42 PM
