teaching emergency landings...How low do you go...
Old February 26th 08, 11:02 PM posted to rec.aviation.student,rec.aviation.piloting
gatt[_2_]
Default teaching emergency landings...How low do you go...
My first instructor liked to have me practice emergency landings over rural
Oregon. Although we observed basic airspace rules, we'd get down below
treetop levels, short final, maybe 100' or less before go around. Once, I
could see the startled expression on a farmer's face as he watched us. On a
couple of occasions, I thought we were actually going to land. Birds took
flight, etc. Subsequent instructors and examiners always called it "good"
well above that so we never got that low.
My question is, what would you say the lowest appropriate height AGL for
teaching student pilots about off-field emergency landings in, say, a C-152,
given the 500' rule? (We -definately- busted that in the case of the
farmer. The instructor even said so.)
-c
CP-ASEL-IA, CFI student
Old February 26th 08, 11:10 PM posted to rec.aviation.student,rec.aviation.piloting
-c
Times have changed and the ground folk are a bit more wary of
airplanes since 9/11.
N Numbers are easy to read when you can "read the farmer's
expression."
A better CFI ploy is to get acquainted with some private grass strip
owners and do some practice there. Students usually have no idea there
is an airfield "right down there."
Dan
Old February 26th 08, 11:13 PM posted to rec.aviation.student,rec.aviation.piloting
Robert M. Gary
given the 500' rule? * (We -definately- busted that in the case of the
farmer. *The instructor even said so.)
No, I would say about 5' rule. But i wouldn't do it where there were
people, structures, or vehicles in the area (cows don't count).
-robert, CFII
Old February 26th 08, 11:55 PM posted to rec.aviation.student,rec.aviation.piloting
Jim Stewart
But horses do. Expensive, high vet bills
and easily spooked.
Old February 26th 08, 11:52 PM posted to rec.aviation.student,rec.aviation.piloting
Jim Stewart
I don't know about 'appropriate', but my
instructor had no problem with '50 with
no animals or people around.
Even better is to the ground. My instructor
loved to pull the power when we were within
gliding range of an airport with no traffic.
I flew it down all the way to wheel stop
several times that way.
Old February 26th 08, 11:54 PM posted to rec.aviation.student,rec.aviation.piloting
Dudley Henriques[_2_]
-c
There are three factors common to all forced landings;
1. Control of the aircraft (Fly the airplane)
2. Picking the right spot based on aircraft position, wind, and terrain.
3. Setting up for and flying the approach (obvious)
If these three factors are accomplished, for the purposes of instruction
and training, the actual touchdown can be assumed.
I NEVER advocate using the mixture and a stopped prop in forced landing
training. The reason for this should be obvious but I always mention it
just in case someone misses the point.
Taking into consideration the effects on glide from a stopped prop as
opposed to an idling engine, it doesn't take long to realize that
setting up ANY forced landing approach whether it be with an idling
engine or with the engine completely dead, requires setting up that
approach based on THE AVAILABLE VISUAL CUES as they relate to the
position of the aircraft at all times from the intended landing site.
Based on this single fact, it should be apparent that if a pilot is
flying the airplane properly, that pilot will be making the approach
based on WHATEVER THE REAL TIME VISUAL CUES are telling him/her. This
means that prop stopped or windmilling, a properly trained pilot will be
executing a forced landing approach compensating AUTOMATICALLY to
achieve a key position based on what the visual cues are telling them.
Considering this, there should NEVER be a need to pull the mixture on a
student. Doing this can easily turn a practice session into an actual
forced landing.
I advocate using the airport for power off approaches to sharpen the
ability to properly fly the airplane based on seeking a key position on
available visual cues. Doing it this way allows the actual landing as well.
Lastly, on selecting a field; this factor can be accomplished at any
time during a dual session locally or on a cross country with the
concentration on coupling the power off approaches practiced back at the
airport with the additional factors involved; flying the airplane and
the choice of the field.
These places chosen should be researched by the instructor for
suitability before they are used for this purpose.
Dudley Henriques
Old February 27th 08, 09:52 PM posted to rec.aviation.piloting
JGalban via AviationKB.com
forced landing.
I agree about stopping the prop. I have done it before, but only to
satisfy my curiosity about performance differences between stopped and
windmilling. I did it over a deserted airport with a long runway (actually 3
long runways).
I am curious about pulling the mixture, though. The only difference
between pulling the throttle and pulling the mixture is that one cuts off air
to the engine and the other cuts off fuel. Since pulling the mixture cuts
off the fuel, it keeps the engine and plugs from loading up as much. In
practice (at least in Cherokees and 172s), I've found that the prop is not
going to stop when the mixture is pulled, unless the plane gets within a few
knots of stall speed.
I'm not a CFI, but I do practice engine out landings on a regular basis
(religiously, since my real engine out). I prefer pulling the mixture to
idle cutoff as a means of simulating the power loss, just because it keeps
the plugs cleaner. Power recovery is as simple as pushing the mixture back
in and verifying that the throttle is full forward. Is there something I'm
not thinking of?
Message posted via AviationKB.com
http://www.aviationkb.com/Uwe/Forums...ation/200802/1
Old February 27th 08, 09:57 PM posted to rec.aviation.piloting
forced landing.
long runways).
not thinking of?
Pulling to ICO is simply not necessary to teach forced landings. Doing
it is just asking for possible trouble. Bottom line is that the pros
just don't outweigh the potential cons.
It's just not a practice I have ever recommended.
DH
Dudley Henriques
Old February 27th 08, 12:02 AM posted to rec.aviation.student,rec.aviation.piloting
Euan Kilgour
-c
I am fortunate enough to fly where there are designated low flying
zones. They are only used for a maximum of two aircraft conducting
dual training. The instructor decides how low you may fly depending on
your ability and the weather conditions. The local land owners all
agreed to it and although we make every effort to avoid buzzing their
stock most of the time they (the cows that is) are so used to low
flying planes they don't even bat an eyelid at you when you fly past.
As for how low have I gone, I'd say about 4-5 feet before the
instructor told me to go around. By that time I was ready to land
alright!
Old February 27th 08, 12:18 AM posted to rec.aviation.student,rec.aviation.piloting
Dave[_1_]
Well....
On my pre- check ride for my PPL, the instructor DID clear a field
that he knew was suitable (an abandoned runway/airstrip,) and when he
saw that I had chosen the right field, he said... NOTHING!!.
.......so I landed the sucker!
He pulled the power at 1000 agl so the choices were limited....
Then he said.. "NOW we get to check your soft field takeoff
procedure..."
Dave
On Tue, 26 Feb 2008 15:02:17 -0800, "gatt"
-c
Emergency Landings Ol Shy & Bashful Piloting 7 October 15th 07 09:09 PM
Teaching the aerotow Paul Moggach Soaring 5 September 12th 05 03:31 AM
Teaching emergency procedures Ramapriya Piloting 9 January 4th 05 09:14 PM
Channel News Asia: Taiwan Jets Practise Emergency Landings on Freeway Amid Tensions with China Dionaea muscipula Military Aviation 0 July 21st 04 08:18 AM
Teaching airworthiness Roger Long Piloting 28 October 2nd 03 09:08 PM
