Inside the Air Force
STOVL-, CV-variants less expensive than CTOL DAVIS: BIGGEST JOINT STRIKE FIGHTER PROBLEM IS PRODUCTION COSTS Date: February 22, 2008 In the wake of the third propulsion malfunction in six months, the head of the Joint Strike Fighter program office says testing difficulties are not his biggest worry in the military's largest procurement investment to date. Instead, Maj. Gen. Charles Davis mainly concerns himself with keeping production line costs down. On Feb. 4, the engine that was to go onto the first Marine F-35B -- the short takeoff, vertical landing variant (STOVL) -- failed when a third- stage blade of the turbine came off. This event was similar to an incident in August 2007, where an engine designed for the Air Force's conventional takeoff and landing-variant test jet failed, Davis said during a Feb. 13 speech at an industry conference in Washington. In December 2007, program officials also discovered a manufacturing defect in the lift fan rotor -- which assists the jet in vertical landings -- of the STOVL test aircraft that required the installation of new components. However, the two-star, who has worked on and headed several jet aircraft test programs in his nearly 30 years of service, has said there has not been a single program in which he has been involved where the developers have not had some issue in the middle of flight tests with the platform's engine. Davis remains confident that the program has discovered and will fix the "root causes" that led to the "high-cycle fatigue" the engine encountered, and he is focused on making sure the first aircraft on the next-generation fighter's production line is built "exactly the same way" as the last. "That is the challenge we are working through right now in the F-35" program office, the general said. "I don't worry about capabilities; I'm not really worried about liability and logistics right now. I'm worried about getting our manufacturing line standing down the learning curves." Due to the number of aircraft variants, the program has cost more and has used more titanium than originally planned, Davis said. To stem the excess titanium used, officials are looking at how they can streamline the production process. "We're scrapping probably 90 percent of the titanium it takes to build these airplanes because of the way the machines cut and drill and shape parts, and we've got to figure out what to do with that," the two-star said. "We've got to reduce the cost of what it takes to build these airplanes." The JSF program is learning lessons with each phase of the process, and incorporating this new knowledge to the next phases will cut down the cost of the STOVL and carrier-variant versions than originally planned, Davis said. "My biggest risk has been just getting through the planned assembly path of the airplane while I get the supplier base up and running," he said, noting that the "planned learning curve" of the jet is in the area of 5 to 8 percent less efficient at this point than expected. "As we build each section, [we ask ourselves,] 'Have we learned something from the previous section? What do we need to do better on the next section?'" |
F-35 Joint Strike Fighter | No Name | Aviation Photos | 44 | January 14th 07 10:47 PM |
F-35 Joint Strike Fighter | No Name | Aviation Photos | 0 | January 9th 07 11:11 PM |
CRS VIEWS THE JOINT STRIKE FIGHTER | Mike | Naval Aviation | 13 | June 10th 06 12:37 AM |
Joint Strike Fighter under attack on Capitol Hill | Henry J Cobb | Military Aviation | 2 | March 27th 04 08:07 PM |
Joint Strike Fighter focus sparks concern | Otis Willie | Military Aviation | 0 | March 19th 04 09:19 PM |
