Folks:
I am in the process of sealing up a plenum project. So far all has gone well using regular baffle seal and silicone P strip. However there are several places of extremely irregular shape that I cannot seal with the baffle seal or P strip. Some of the guys around my field have advised that the tricks of the trade are to stuff the tough spots with either dry fiberglass cloth or steel wool. I am not thrilled with either trick, although I concede that they would work. The dry glass cloth is going to be difficult to secure in place and frankly would look like a bunch of rags stuffed into the crevices of an otherwise nice installation. The steel wool is, well, steel wool. In no time it is going to be corroded and nasty and it is obviously a bit on the abrasive side. And I don't think it would seal very well, to boot. So I'm looking for suggestions of something I can stuff into an oddly shaped hole in contact with the cooling fins on an engine. I like the idea of silicone foam as it will take the heat and it's very conformable, but before I spend the big bucks I thought I would cast a wider net to see if there is a simple trick that I have not thought of. Thanks in advance and take care-- Steve. |
Steve S. wrote:
Folks: I am in the process of sealing up a plenum project. So far all has gone well using regular baffle seal and silicone P strip. However there are several places of extremely irregular shape that I cannot seal with the baffle seal or P strip. Some of the guys around my field have advised that the tricks of the trade are to stuff the tough spots with either dry fiberglass cloth or steel wool. I am not thrilled with either trick, although I concede that they would work. The dry glass cloth is going to be difficult to secure in place and frankly would look like a bunch of rags stuffed into the crevices of an otherwise nice installation. The steel wool is, well, steel wool. In no time it is going to be corroded and nasty and it is obviously a bit on the abrasive side. And I don't think it would seal very well, to boot. So I'm looking for suggestions of something I can stuff into an oddly shaped hole in contact with the cooling fins on an engine. I like the idea of silicone foam as it will take the heat and it's very conformable, but before I spend the big bucks I thought I would cast a wider net to see if there is a simple trick that I have not thought of. Thanks in advance and take care-- Steve. Post some photos. Let's see what we are actually looking at first... |
On Feb 29, 9:35 pm, "Steve S." wrote:
Folks: I am in the process of sealing up a plenum project. So far all has gone well using regular baffle seal and silicone P strip. However there are several places of extremely irregular shape that I cannot seal with the baffle seal or P strip. Some of the guys around my field have advised that the tricks of the trade are to stuff the tough spots with either dry fiberglass cloth or steel wool. I am not thrilled with either trick, although I concede that they would work. The dry glass cloth is going to be difficult to secure in place and frankly would look like a bunch of rags stuffed into the crevices of an otherwise nice installation. The steel wool is, well, steel wool. In no time it is going to be corroded and nasty and it is obviously a bit on the abrasive side. And I don't think it would seal very well, to boot. So I'm looking for suggestions of something I can stuff into an oddly shaped hole in contact with the cooling fins on an engine. I like the idea of silicone foam as it will take the heat and it's very conformable, but before I spend the big bucks I thought I would cast a wider net to see if there is a simple trick that I have not thought of. Thanks in advance and take care-- Steve. You can close off just about any odd hole if you carefully cut baffle strip or aluminum sheet to fit the opening. Stuffing miscellaneous junk into places like that is ugly and can cause trouble if it gets out and into or onto places where it doesn't belong. Watch the silicone foam. If it sticks to a large area of the head or cylinder it might cause a hot spot by keeping the air off it. Dan |
Engine Baffling Supplier | Mike Spera | Owning | 6 | January 25th 08 12:02 AM |
Patching Baffling, 3/32 C-Sunk Rivets, 1100 Aluminum? | jls | Home Built | 3 | February 3rd 04 12:15 AM |
