Teaching Incremental Flaps in the Pattern
Old March 4th 08, 03:22 PM posted to rec.aviation.piloting
Default Teaching Incremental Flaps in the Pattern
I just read an interesting argument by Lew Gauge in his E-185 Bonanza
book.
Some background -- the older Bonanzas (straight 35) have a "Flap"
switch. There's no increments unless you stop the motor as the flaps
are being dropped. Apparently it's hard on that design to start-stop
the motor.
Lew said there's no reason to teach incremental flaps in small
airplanes -- and that multiple flap applications just add to the
workload with no advantage-- apply 10 degrees, trim, apply 10 more,
trim, etc.
His argument is that if the sequence is always the same -- gear down,
trim, flaps down, trim -- the approaches will be consistent and reduce
the likelihood of a gear-up landing (since the descent profile with
15" MP and full flaps gear up is very close to 15"+ full flaps + gear
down).
The more I think about this the more it makes sense, except in the
partial flap case (though an argument can be made that there's no
reason to ever go partial -- but that's another topic).
I'm sure this will be contentious, but isn't that the point?
Dan
Old March 4th 08, 03:57 PM posted to rec.aviation.piloting
Darkwing
book.
the motor.
trim, etc.
down).
Dan
I think there are advantages to incremental flaps in the pattern because you
are in different phases of flight in speed and angle of turns. By the time
you turn final you need to be at basically landing speed and established on
a stabilized approach, if you jam all the flaps in and try to get a nice
angle for the approach with a stabilized airspeed you are just creating more
work in a shorter amount of time.
Old March 4th 08, 04:06 PM posted to rec.aviation.piloting
book.
the motor.
trim, etc.
down).
Dan
OK, but the counter argument is -- Why have different airspeeds?
In a model 35, Vle is 100 MPH (pretty slow). So I get the airplane to
90 on downwind, drop the gear midfield. At the numbers drop full flaps
and turn to base at 80, to final at 80, and then slow to 65-70 on
final (depending on winds). The slowdown on final requires very little
power-attitude-configuration change (a little nose up trim), and thus
I can concentrate on good turns and traffic scans during the turn to
base, turn to final critical phases of flight.
The pitch change in the 35 as the flaps drop to full is negligible,
but the descent rate with 15" MAP goes from straight and level to 700
FPM with no speed change. Trim up to a descent rate is 500' FPM and
target airspeed of 80 MPH.
Dan
This
Old March 4th 08, 04:33 PM posted to rec.aviation.piloting
Kobra
book.
the motor.
trim, etc.
down).
Ask yourself this: Why not drop full flaps just as you enter the 45?
Simple. It's inefficient. Why slow the plane down so early? Why add sooo
much drag and increase your time around the pattern and for what gain?
I haven't heard of gear-up landings running rampant due to setting the flaps
more than once. I haven't heard any pilot ever complaining about the
workload in the pattern because of setting the flaps.
With full flaps on the downwind you're dragging the plane around the pattern
at about 70 or 80 KIAS. Everyone behind you is probably at about 90 or 100
on those legs. Seems very inefficient. Other than that I can't think of
any reason not to drop full flaps on the DW.
Kobra
Old March 4th 08, 04:41 PM posted to rec.aviation.piloting
Kobra
I didn't say you should drag it around on downwind.
A few points:
1) An ongoing problem with private pilots in the pattern is flying too
fast. Don't believe it? Go to the local patch and watch touch downs
1/2 way down the pavement followed by a high-speed roll to the last
taxiway.
2) Dropping full flaps at the numbers means you will turn base very
soon after that. This keeps the pattern tight and *reduces* the time
spent in the pattern.
3) Once on final a stabilized speed close to 1.3 Vso ensures a spot
landing, short roll out, and means the a/c is off the runway sooner
rather than later.
Seems reasonable to me...
Dan
Old March 4th 08, 05:07 PM posted to rec.aviation.piloting
Robert M. Gary
book.
When I first started teaching Mooneys I taught the traditional 4
points in the pattern with a different speed/configuration in each
part. After having a couple student pilots in the Mooney (yes its very
possible) I decided that all this configuration requires too much head
down time for the mortal pilot. So now I teach 100 knots on downwind,
flaps up, gear down. Abeam power to 2000 RPM, full flaps, 80 knots.
Short final we do slow to 75 knots though. For older, short body
Mooneys you just change knots for mph and the numbers still work out.
If you are solo with light fuel, just subtract 5 knots.
-Robert
Bob Gardner
I am reluctant to teach anything that should "always" be used. Flaps are a
tool, and we learn early on in life that there are many ways to use a tool
to achieve different results. If there is a problem with the flap motor in
that specific airplane, why apply the same thinking to all airplanes? Flap
extension is a balance between lift and drag....whether you want more lift
or more drag depends on the situation.
Bottom line: I don't like it.
Bob Gardner
book.
the motor.
trim, etc.
down).
Dan
Old March 4th 08, 05:14 PM posted to rec.aviation.piloting
Bob Gardner
If I came across as "always in every instance" it was unintentional.
As in any art, it's best to start with simple principles, and then add
the exceptions later.
Dan
Old March 4th 08, 05:23 PM posted to rec.aviation.piloting
Robert M. Gary
I agree with you in principle but from a practical point student
pilots need to start with very, very specific instruction before they
have the tools and expand into these types of judgements. If you don't
give students specific airspeeds to hit in the pattern they will
always have problems with landings. 9 times out of 10 when a student
pilot is having trouble landing all I do is sit in the right seat and
say "ok, what speed are you suppose to be at here?" and let them do
the rest.
-Robert
Old March 4th 08, 06:43 PM posted to rec.aviation.piloting
Bob Gardner
Would this specific instruction include full flaps abeam the numbers? With
any airplane? I think the "hard on the motor" argument is bogus. Beech
doesn't build airplanes with pre-loaded failure modes.
Bob Gardner
the rest.
-Robert
teaching emergency landings...How low do you go... gatt[_2_] Piloting 18 February 27th 08 09:57 PM
Aerotow - learning and teaching [email protected] Soaring 11 September 12th 05 09:53 PM
Teaching the aerotow Paul Moggach Soaring 5 September 12th 05 03:31 AM
Ground launch and the incremental vanishing of soaring Mark James Boyd Soaring 24 March 8th 04 10:50 PM
Teaching airworthiness Roger Long Piloting 28 October 2nd 03 09:08 PM
