Ammending logbooks
Old March 5th 08, 10:46 PM posted to rec.aviation.piloting
Edward A. Falk
Default Ammending logbooks
OK, new question: I put my logbooks (25 years worth) into a spreadsheet
program, and turned up a few errors in the process; mostly due to
misreading my own handwriting. In some columns, the error is as much
as 10 hours. Most of the errors are in my favor. Interestingly, there's
not a single mistake in the total flight time column.
How can I correct my logbook? One way might be to simply put the
corrected values at the bottom of the page next time I total up, but
I worry about having to explain the discontinuity to the next
examiner who's good at math.
Or should I put an entry into the logbook that says "these values
correct for errors in previous pages."?
-Ed Falk,
http://thespamdiaries.blogspot.com/
Old March 5th 08, 11:13 PM posted to rec.aviation.piloting
Bob F.
"Edward A. Falk" wrote in message
-Ed Falk,
You can do anything you want. Just do it clearly and don't make it look
like you are covering anything up. I know that's not your intention. Also,
I'd initial all changes and make a note in the back of the log what you did.
That said, there is NO requirement anywhere in the regulations that say you
have to keep a total, running or otherwise, in your logbook. So, I don't
even add them up anymore. Let the spreadsheet do the work. You only need
to make a tally when asked such as with an 8710 application, insurance form,
etc. And it does not have to stay in your log. BTW, you can put anything
you want to in you logbook, backseat time, conversation time, all kinds of
experience you want to keep track of. The question is "what rows do you add
up to answer the questions on forms or by the examiner?". If you want to
keep track of other experience, that's your business. It's your log. Just
don't try to count it towards anything. (the extraneous stuff, that is).
BobF.
Old March 5th 08, 11:32 PM posted to rec.aviation.piloting
Dan[_10_]
On Mar 5, 6:13 pm, "Bob F." wrote:
"Edward A. Falk" wrote in ...
-Ed Falk,
BobF.
Excellent advice.
The only hours that must be logged are those required for a rating or
proficiency, or dual given as a CFI.
Dan
Old March 5th 08, 11:55 PM posted to rec.aviation.piloting
Bob F.
"Dan" wrote in message
spreadsheet
there's
-Ed Falk,
Also,
did.
you
need
form,
anything
of
add
Just
BobF.
Excellent advice.
Dan
Absolutely right. I noticed you said logged, not tallied. It's interesting
about the CFI logging and often brought up at CFI refresher clinics. Do you
realize and the Instructor has no choice when he gives instruction to sign
your log? There's no vote! It is improper to ask "do you want me to sign
your log book", He must. One the other hand, there is no requirement for a
student to even have a log book (In many situations). There is also no
requirement to have a log book with you, so what's an instructor to do.
Well, when I run into the situation, I grab a scrap of paper, make the
notations and say "here, this is now part of your logbook". The only out
is, there is no TIME required to make the entry after instruction... today,
tomorrow and year from now... Anyhow, a small discontinuity in the regs.
BobF.
Old March 5th 08, 11:59 PM posted to rec.aviation.piloting
Dan[_10_]
Dan
BobF.
Hmmm..
I thought the only *required CFI log* is the CFI's own log of dual
given (to be kept 3 years).
In the case of the student with no log book -- the CFI cannot
comply...?
Dan
Old March 6th 08, 12:08 AM posted to rec.aviation.piloting
Bob F.
Dan
interesting
you
sign
sign
for a
today,
BobF.
Hmmm..
Sec. 61.189 - Flight instructor records.
(a) A flight instructor must sign the logbook of each person to whom that
instructor has given flight training or ground training.
and while we are at it:
(2) The name of each person that instructor has endorsed for a knowledge
test or practical test, and the record shall also indicate the kind of test,
the date, and the results.
This one means that when I recommend a candidate for a written test, I need
to track him down, get the results and record it. This one is often
overlook and I'll bet 90 % of the CFI's miss this. The "out" here is,
always do the sign off with your Ground Instrutor Certificate number, which
I always do. Guess what... no records required.
comply...?
That's the point I tried to make.
Dan
BobF.
On Mar 5, 3:46*pm, (Edward A. Falk) wrote:
OK, new question: *I put my logbooks (25 years worth) into a spreadsheet
misreading my own handwriting. *In some columns, the error is as much
as 10 hours. *Most of the errors are in my favor. *Interestingly, there's
How can I correct my logbook? *One way might be to simply put the
* * * * -Ed Falk,
* * * *http://thespamdiaries.blogspot.com/
If you end up with an examiner who adds up all the columns in 23 years
worth of log books my suggestion is to find another examiner who is
sane, rational and lives in the real world...
With that said your last idea to "correct for errors" is probably the
best way to address this issue.. YMMV.
Old March 5th 08, 11:43 PM posted to rec.aviation.piloting
Peter Clark
On Wed, 5 Mar 2008 15:13:31 -0800 (PST), "
* * * * -Ed Falk,
Don't they basically do that if you apply for an ATP?
Old March 5th 08, 11:58 PM posted to rec.aviation.piloting
Bob F.
"Peter Clark" wrote in message
-Ed Falk,
Mine just asked me "Is all the required time there?" I said "yes", and that
was the end of that. And believe me, I spent a lot of time going over my
log making sure everything was correct. For an ATP, your log is checked at
the time of the written. I believe it's still that way.
BobF.
Peter Clark
On Wed, 5 Mar 2008 18:58:57 -0500, "Bob F."
-Ed Falk,
OK, thanks. I guess it's another thing that varies from examiner to
examiner, you hear horror stories of people getting out calculators
and going through years of books line by line.....
Changing Logbooks Steve Foley Piloting 21 April 12th 07 03:04 PM
Electronic Logbooks daniel.bascomb Piloting 19 December 21st 06 08:42 PM
Falsified logbooks? Close to home... Dave S Owning 1 April 6th 06 10:40 PM
Logbooks? der flieger Products 0 April 13th 05 02:44 PM
NR abbreviation in logbooks Jeremy Lew Piloting 11 November 19th 03 03:46 PM
