Teflon tape
Old March 6th 08, 01:10 AM posted to rec.aviation.owning
Default Teflon tape
My mechanic is getting ready to install new (hideously expensive) fuel
valves in my Comanche and he indicated that he did not want to use
teflon tape on the pipe fittings. Any ideas why teflon is undesirable
for fuel applications? I thought that it was pretty inert.
-ifsc
Old March 6th 08, 01:13 AM posted to rec.aviation.owning
Capt. Geoffrey Thorpe
Default Teflon tape
Fragments can get into carburetor jets or injector orifices and block the
flow.
Geoff
Old March 6th 08, 12:07 PM posted to rec.aviation.owning
Denny
Default Teflon tape
When folks have questions like this, here is the source for many of
the answers:
http://www.tagpilotsupply.com/browse...Practices.HTML
denny
Old March 9th 08, 03:44 AM posted to rec.aviation.owning
David Lesher
Default Teflon tape
I have no idea if it's FAA Approved, but I used to use stuph called
RectorSeal instead of tape on the flare fitting on 0.25" steel sense
lines used on the pipeline. It was no problem with 700psi gasoline, etc.
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
Old March 7th 08, 09:29 PM posted to rec.aviation.owning
John Kunkel
Default Teflon tape
"Capt. Geoffrey Thorpe" The Sea Hawk At Wow Way D0t C0m wrote in message
news:tfydnWk_eoK72FLanZ2dnUVZ_uWlnZ2d@wideopenwest .com...
flow.
The only way tape fragments can enter the system is if the tape is applied
incorrectly, another case of a fine product getting dissed because of human
error.
Old March 7th 08, 11:27 PM posted to rec.aviation.owning
Default Teflon tape
"John Kunkel" wrote in message
flow.
human error.
Yes, if you leave 2 threads uncovered at the end, the tape will not enter
the system when you assemble it. But, the next time you disassemble it, bits
may be left on the threads which may then get pushed into the sytem when you
re-assemble.
I ain't diss'n nothing. I've used miles of the stuff myself.
Geoff
Old March 8th 08, 07:36 PM posted to rec.aviation.owning
John Kunkel
Default Teflon tape
news:saadned3As_EUkzanZ2dnUVZ_qGknZ2d@wideopenwest .com...
message news:tfydnWk_eoK72FLanZ2dnUVZ_uWlnZ2d@wideopenwest .com...
the flow.
applied incorrectly, another case of a fine product getting dissed
because of human error.
bits may be left on the threads which may then get pushed into the sytem
when you re-assemble.
Like I said, human error.
Wax, Teflon, Wx? Guy Acheson Soaring 31 July 10th 17 10:35 PM
ATC Tape Steffen Braasch General Aviation 20 May 3rd 06 04:27 AM
Gap Tape TJ Soaring 0 October 22nd 05 04:18 AM
FS Teflon wire at Dayton RST Engineering Home Built 1 May 12th 05 01:56 AM
Teflon gap seal tape... Marc Ramsey Soaring 10 April 3rd 05 04:35 PM
