STF question
Old March 15th 08, 12:49 AM posted to rec.aviation.soaring
Ramy
Default STF question
We know flight computers are taking into account the polar, MC setting
and the current sink/lift to determine the speed to fly, but AFAIK
they don't (or at least my 302 doesn't) take into account the head/
tail wind component. As such, they will often command too slow speed
when flying in headwind, unless the pilots manually increases the MC
setting, which is not easy to determine. This is especially critical
in final glide against strong head wind. I would think it would be
straight forward to incorportae head/tail wind into the STF
calculation, or at least make it optional. Any thoughts why not?
Ramy
Old March 15th 08, 01:45 AM posted to rec.aviation.soaring
toad
Standard STF theory says that the head/tail wind does not matter for
cruise flight. Does wind influence best speed for final glide ?
Todd Smith
3S
Old March 15th 08, 01:51 AM posted to rec.aviation.soaring
Gary Emerson
Todd Smith
3S
It's two separate issues. Speed to fly AND altitude required. Speed to
fly is NOT dependent on HW/TW. HW/TW will affect Altitude required.
Old March 15th 08, 03:29 AM posted to rec.aviation.soaring
Ramy
Todd Smith
3S
It's two separate issues. *Speed to fly AND altitude required. *Speed to
fly is NOT dependent on HW/TW. *HW/TW will affect Altitude required.
HW/TW also effect speed to fly to achive best glide over the ground.
The rule of thumb is to add half the wind speed to the best glide
speed. I am also not sure it doesn't matter for cruise flight. If you
have a 50 knots head wind you will not make any progress unless you
fly very fast. From what I understand from cambridge manuals they do
not take the wind into account for speed to fly.
Ramy
Old March 15th 08, 04:03 AM posted to rec.aviation.soaring
Eric Greenwell
Ramy wrote:
Todd Smith
3S
I have a 302, and I'm sure you are right, because "speed to fly" does
not depend on the wind. If you want to know the "speed to fly to achieve
the greatest distance over the ground into a wind", then you can (1) use
your rule of thumb, (2) use the MC setting that gives a theoretical
cross-country speed equal to the wind (another rule of thumb), (3) let
Winpilot (or perhaps one of the others) figure it out for you.
If you have a flight computer, you might be able to find the best
speed/MC setting by watching the arrival height for a point in front of
you while you adjust the MC from 0 upwards. I haven't tried that, but it
sounds good.
* Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4
* New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more
Old March 15th 08, 04:31 AM posted to rec.aviation.soaring
Jack Glendening
The "airspeed to fly to produce the fastest time over a given path"
(for a given thermal strength) _does_ depend upon the wind. Simple
MacCready theory does not include wind effect but can be modified to
include it. Whether the 302 includes that effect I do not know. I do
know that wind effect is included in the STF calculations (including
that of airspeed) used for my BLIPMAP viewer "Track Average" popup.
Jack
Old March 15th 08, 10:02 AM posted to rec.aviation.soaring
Dan G
Todd Smith
3S
speed.
I thought it was add half the windspeed for a headwind, but take off
half for a tailwind? Or is it had half whichever direction you're
heading?!
Dan
Old March 15th 08, 10:31 AM posted to rec.aviation.soaring
Jack Glendening
Below is an illustration of the wind speed effect on a flight leg,
comparing a BLIPMAP Track Average "optimal flight" calculation for a
headwind of 20 kt to one with no head/tail wind (for a LS-3 polar). The
former requires a larger airspeed between thermals and a larger amount
of time spent thermalling to make progress. And of course the ground
speed is lower, but note that it is _higher_ than one would get by
simply subtracting the headwind from the "no headwind" groundspeed -
this is what is gained by using a higher airspeed when a headwind
exists. For this example the "add half the headwind" rule of thumb
would give an airspeed higher than optimal. (I suspect the column
formatting will be lost in this posting, so the numbers in order are the
leg distance (km), tailwind (kt), climb rate(m/s), leg time (min),
average groundspeed (kt), between-thermal airspeed (kt), and
percent time spent thermalling.)
---- Optimal-Flight-Avg ----
-- Tail Clmb Gnd Air Thm
-- Dist Wind Rate Time Spd Spd Pct
-- km kt m/s min kt kt %
-- 45 -20 1.4 43 34 85 60
-- *** WITH NO HEADWIND ***
-- 45 0 1.4 32 45 80 44
Old March 15th 08, 04:40 PM posted to rec.aviation.soaring
Eric Greenwell
Todd Smith
3S
speed.
heading?!
The approximate answer is "Add some fraction of the headwind". Someone
suggested one half; I generally increase the MC about 1 knot, which has
a similar effect.
For a tailwind, the best distance will be achieved by flying somewhere
between the max L/D speed and the minimum sink speed, so I set MC to
zero (best L/D). If it's a really strong tailwind, I'll fly slower than
it indicates (closer to minimum sink). In the olden days, I could rotate
the MC ring to a negative number, but my 302 doesn't allow that!
Old March 16th 08, 04:46 AM posted to rec.aviation.soaring
Andy[_1_]
Todd Smith
3S
Ramy
One more question... john smith Aviation Photos 12 October 6th 07 07:32 PM
MRA Question [email protected] Instrument Flight Rules 3 April 16th 06 02:19 PM
I want to ask you the most important question of your life. The question is: Are you saved? It is no gasman Soaring 0 August 26th 05 06:39 PM
Good morning or good evening depending upon your location. I want to ask you the most important question of your life. Your joy or sorrow for all eternity depends upon your answer. The question is: Are you saved? It is not a question of how good Excelsior Home Built 0 April 22nd 05 01:11 AM
Question about Question 4488 [email protected] Instrument Flight Rules 3 October 27th 03 01:26 AM
