Slips and skids
Old March 15th 08, 08:38 PM posted to rec.aviation.piloting
William Hung[_2_]
Default Slips and skids
I have heard definitions for both, but I'm still confused. Anyone
care to elaborate?
Wil
Old March 16th 08, 12:49 AM posted to rec.aviation.piloting
WingFlaps
On Mar 16, 9:38*am, William Hung wrote:
I have heard definitions for both, but I'm still confused. *Anyone
care to elaborate?
In a skid the ball is deflected to the outside of the turn and in a
slip it's to the inside. Since you "step on the ball" with the rudder,
it foillows that a skid occurs when there is too much yaw in the
direction of turn (like a car rear end breaking away) and a slip when
there is not enough.
Hope this helps.
Cheers.
Old March 16th 08, 04:23 AM posted to rec.aviation.piloting
care to elaborate?
Hope this helps.
Cheers.
Heh.
Except when the control system is misrigged like a plane I flew
recently. In order to get a coordinated turn, I had to give "top"
rudder in a turn. That's wrong.
Of course the actual rudder must have been bottom, but, it was bad.
If you want a great explanation (and a GREAT) book on flying, get Rich
Stowell's "Emergency Maneuver Training". It has nice drawings
illusatrating rudder and aileron positions in both slip and skid. Plus
an explanation about why your life depends on knowing the difference
when you're in the pattern or otherwise low to the ground and at
relative high AoA.
Old March 16th 08, 07:42 PM posted to rec.aviation.piloting
Is that the one in which I suggested a broken rudder bar spring?
Anything come of that?
Dan
Old March 16th 08, 10:32 PM posted to rec.aviation.piloting
* * Is that the one in which I suggested a broken rudder bar spring?
* * * Dan
Yeah, I think so. Another person also emailed me private and said the
same.
The chief pilot and other instructors at the FBO got an email from me.
Never heard anything back. Maybe they checked it out and decided I was
wrong; or maybe I found a problem and they don't want to comment on it
in a traceable way. I think I'll switch to their 172, rather than fly
that 150.
On the other hand maybe they have fixed it and I just don't know about
it.
Old March 16th 08, 11:03 PM posted to rec.aviation.piloting
Bob F.
Let's see what is it that you are experiencing. Before flight with the
plane sitting on level ground (at least as much as you can tell). Is the
ball centered? As you taxi and make small heading changes, does the ball
move freely in the raceway? In the practice area. Slow to 60 Kts, pitch
up and add full power, maintain 60 kts. You should immediately notice the
ball go right and you will need right rudder to center the ball. Keep the
plane from changing heading. Be sure to keep the wings level. Now notice
as you enter into a left turn, you DO NOT need to step on the left rudder
(you only maintain enough left rudder pressure to keep slack out of the
cable system) until you have released all the pressure from the right
rudder, then as you increase bank further you can add left rudder. In fact
you MIGHT not need left rudder at all. Keep the ball centered all the time.
Is that what you are seeing?
Now, In a glide situation, things should be more symmetrical. Lower the
nose, reduce power to say 1200 rpm, maintain 60 kts. As you bank right and
left the rudder pressures required to keep the ball centered each way should
be about the same. Do you see this effect? Please report if you know, or
try it the next time you go out.
Regards, BobF.
Dan
same.
that 150.
it.
Old March 16th 08, 05:38 AM posted to rec.aviation.piloting
Roger[_4_]
On Sat, 15 Mar 2008 13:38:20 -0700 (PDT), William Hung
care to elaborate?
To me the easiest analogy is to think of a road that has a steep
banked turn covered with ice. If you go around it too fast you will
"skid" to the outside. If you go too slow you will slip down hill to
the inside.
In the case of the airplane too much rudder to the inside will make
you fell like you are being pushed to the outside and the plane will
be skidding to the outside.
Not enough rudder and the nose will drop in the turn. so you add
rudder to raise the nose and you feel like you are pressed against the
lower side of the plane which is now slipping down hill.
Wil
www.rogerhalstead.com
Old March 16th 08, 05:57 AM posted to rec.aviation.piloting
Are you sure?
I think the more bottom rudder you give in a turn, the more the nose
will appear to move lower against a given horizon. All the rudder does
is pull the plane around an axis from ear-to-ear. So if you give too
much bottom rudder, the nose will appear to drop in a turn. If you
give top rudder, you'll have the nose "rise" against the turn.
The classic case of skid is when too much bottom rudder is given, the
nose swings around the ear-to-ear axis, yawing past coordinated turn;
and if the pilot pulls back on the elevator to "raise" the nose back
up, it increases AoA, things could be getting dangerous ...
Old March 16th 08, 01:41 PM posted to rec.aviation.piloting
Bob F.
You guys are talking about airplanes. You have to think about all the other
factors associated with engines, like "p" factor and torque, and then wing
wash in and out, offset rudder, etc. Then consider the differences in
shallow, medium and steep turns (please look up the definitions, if it's
unclear) where control forces are again difference. It is helpful to take
some glider lessons which removes some of these variables.
In an airplane, holding top rudder in a turn was probably not your
imagination. In one direction this is normal and you can experience it also
in one end of the Lazy eight exercise. I think it is also a commercial
written exam question and It will almost certainly come up on the commercial
oral. Hint: Think "P' factor, low speed, high angle of attack, high power
setting. I'll leave it to you guys to discuss this further.
BobF.
"Roger" wrote in message
news
On Sat, 15 Mar 2008 22:57:41 -0700 (PDT),
Are you sure?
I phrased tht badly but it is an anology. Stick with the car on the
sliper y road:-))
Looking for Wing Tip Skids [email protected] Soaring 2 June 23rd 07 02:48 PM
slips to landing in PTS BB Soaring 6 April 17th 07 05:58 AM
Slips and spins in FSX? Chris Wells Simulators 0 December 14th 06 08:24 PM
About forward slips Mxsmanic Piloting 77 November 2nd 06 11:35 PM
High skids vs low skids JKimmel Rotorcraft 0 February 8th 06 01:15 AM
