Mounting Instruments with Lock Washers???
Old March 17th 08, 12:42 PM posted to rec.aviation.soaring
ContestID67
Default Mounting Instruments with Lock Washers???
Now, I have mounted many instruments with their accompanying brass
screws and never used lock washers. Then a friend asked why not? I
opened my mouth to spout the obvious answer, but no sound came out. I
realized that I have never used lock washers, never seen them used,
and have never seen a loose instrument. Hmmmmm.
- Lock washers are used everywhere when vibration is an issue.
- An airplane is certainly a vibration prone environment.
So I hazarded these ideas;
- The screws, and nut, are (non-magnetic) brass and somehow brass
stays "stuck" better because brass is softer than steel.
- A brass lock washer wouldn't keep its "bite" as it would flatten
over time.
- I don't have any more good ideas.
So, why is it that we never use lock washers when mounting
instruments? And why don't the instruments vibrate loose? Please
keep the answer this side of a physics lecture.
Thanks, John
Old March 17th 08, 02:02 PM posted to rec.aviation.soaring
SoaringXCellence
screws and never used lock washers. *Then a friend asked why not? *I
opened my mouth to spout the obvious answer, but no sound came out. *I
and have never seen a loose instrument. *Hmmmmm.
over time.
instruments? * And why don't the instruments vibrate loose? *Please
Thanks, John
They don't vibrate loose because there is no vibration! Without the
engine there are no serious vibrations except when rolling on a rough
surface.
In most of the power plane installations I've seen they use a brass
nut-clip that fits into the back of each instrument hole and IS a lock
nut.
In my Grob the nuts used on the instruments are plastic insert lock
nuts. That's the way it came to me.
Mike
Old March 17th 08, 02:18 PM posted to rec.aviation.soaring
BB
surface.
I wouldn't be so sure about the "don't vibrate loose" part. On all
three gliders I've owned, two new, instrument screws have slowly
backed out. Eventually you will see empty holes in the panel and hear
funny rattling noises under the seat pan. (Don't ask how I know!)
Checking instrument screws, the screws that hold the glare shield in
place and so forth has become part of my annual.
John Cochrane
Old March 18th 08, 12:18 AM posted to rec.aviation.soaring
surface.
John Cochrane
I don't know about anybody else but every time I trailer to a contest
I find a whole bunch of loose screws - instrument mounting,
glareshield, panel mount, seat pan, even my boom mike. It's now a
ritual for me to tighten them all when I first arrive at a new
location.
9B
Old March 17th 08, 04:22 PM posted to rec.aviation.soaring
Coriolis effect: http://en.wikipedia.org/wiki/Coriolis_effect
And snapping smartly into left hand thermals keeps them tight. You
have been doing that I hope?
Thanks, John
Old March 17th 08, 05:05 PM posted to rec.aviation.soaring
bumper
Finally an answer that makes sense! Thank you, thank you, thank you! For
years I've been wondering and now I know why. Once all my instruments fell
out when I snapped smartly into a right hand thermal - - had me baffled.
bumper
Old March 17th 08, 06:53 PM posted to rec.aviation.soaring
You only had to ask! ;-)
Bob
bumper
Old March 17th 08, 07:06 PM posted to rec.aviation.soaring
Andy[_1_]
you!
This is also the reason captive nuts are common in instruments.
Without them the nuts would loosen for thermal entries one way, and
the screws would loosen if you turned the other way. Good pilots
just adapt and fly fast without turning. Less adept pilots resort to
loctite, stiffnuts, or periodic security checks.
Andy
Old March 17th 08, 07:54 PM posted to rec.aviation.soaring
nimbusgb
On 17 Mar, 19:06, Andy wrote:
you!
Andy
Ever heard of Loctite?
Old March 17th 08, 07:58 PM posted to rec.aviation.soaring
Bob Kuykendall
...Less adept pilots resort to loctite, stiffnuts, or periodic
security checks...
Well, he _did_ mention it in the quoted post...
Bob K.
Mounting 396 Paul kgyy Piloting 40 August 24th 07 08:47 AM
Mounting my GPS Charles Talleyrand Piloting 8 November 19th 03 11:51 AM
